This should be the wire combination for your car:
nstant 12V+
Orange
Switched 12V+
Yellow
Ground
Black
Illumination
Gray
Dimmer
Brown
Antenna Trigger
Pink
Antenna
Right Front
Speakers
Left Front (+)
Tan
Left Front (-)
Gray
Right Front (+)
Light Green
Right Front (-)
Dark Green
Speakers continued
Left Rear (+)
Brown
Left Rear (-)
Yellow
Right Rear (+)
Dark Blue
Right Rear (-)
Light Blue
To reprogram the
radio there is 4 digit code. That code has to be inserted, once these code is inserted,
your car radio will get into its actual setting where you can set/select your
radio setting.
Many
a time's radio asks for the code after car battery is disconnected.
On
some cases to retrieve the code its mentioned in manual or else car
dealer is other option to get car radio code.
For
more help on car radio problems, I suggest you to go through these
troubleshooting links, these will help you: -----
Click
the link below: ---
http://schematicsdiagram.blogspot.com/2011/12/how-to-wire-new-radio-on-1990-toyota.html
http://schematicsdiagram.blogspot.com/2011/12/radio-stereo-wiring-diagram-for-1991.html
http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-radio-on-acura-car-models.html
http://schematicsdiagram.blogspot.com/2011/12/where-is-radio-fuse-located-on-2007.html
http://howtobyme.blogspot.com/2011/12/how-to-reset-radio-code-after-car.html
http://schematicsdiagram.blogspot.com/2011/12/can-car-radio-code-block-passkey-anti.html
http://schematicsdiagram.blogspot.com/2011/12/after-market-stereo-wiring-for-1999.html
http://schematicsdiagram.blogspot.com/2012/01/chevy-car-radio-doesnt-allow-to-switch.html
http://repairhelpcenter.blogspot.com/2012/01/no-power-to-radio-on-2005-toyota-scion.html
http://repairhelpcenter.blogspot.com/2012/01/lexus-rx330-radio-has-power-but-no.html
http://technoanswers.blogspot.com/2012/01/radio-goes-on-and-off-while-driving.html
http://technoanswers.blogspot.in/2012/02/lincoln-town-car-radio-stereo-wiring.html
http://technoanswers.blogspot.in/2012/02/radio-wiring-diagram-for-1997-lincoln.html
http://technoanswers.blogspot.in/2012/01/how-to-remove-cd-player-from-dash-on.html
These details will help you thanks.
Click
the link below: ---
Cigarette
lighter, Remote central locking, and Radio stopped working
http://whoisbyme.blogspot.in/2012/07/cigarette-lighter-remote-central.html
VW passat radio off safe
mode? VW radio CODE?
http://schematicsdiagram.blogspot.in/2012/03/vw-passat-radio-off-safe-mode-vw-radio.html
How to wire new Radio on
1990 Toyota Celica?
Radio Stereo Wiring Diagram
for 1991 Chevy 1500?
How to remove radio on
Acura Car models?
Where is Radio Fuse located
on 2007 Dodge charger?
How to reset Radio code
after car battery is died?
Can car radio code block
Passkey anti theft system ?
After Market Stereo wiring
for 1999 Chevrolet Silverado 1500?
Chevy car radio doesn't
allow to switch to the XM Band to get the radio ID?
No power to radio on 2005 Toyota Scion Xb?
Lexus rx330 Radio has power but no sound?
Radio goes ON and OFF while driving?
Lincoln Town Car Radio stereo
wiring?
Radio wiring diagram for 1997 Lincoln Town Car?
How to remove cd player from dash on 2003
Lincoln Aviator
For Radio related problem,the help links are below.Click the link below to go through its procedure:-----Car radio works but CD player not working?http://technoanswers.blogspot.in/2012/02/car-radio-works-but-cd-player-not.html-----------How to reset Radio code after car battery is died?
------------- Can car radio code block Passkey anti theft system ?
How to wire new car Radio?
Radio Stereo Wiring Diagram?
How to remove radio on Car models?
Where is Radio Fuse located?
----------- After Market Stereo wiring?
car radio doesn't allow to switch to the XM Band to get the radio ID?
No power to radio Scion Xb?
Town Car Radio stereo wiring?
Radio wiring diagram for Car?
How to remove cd player from dash?
This will help.
Thanks.
