Question about Video Game Consoles & Games
My console over heats - Video Game Consoles & Games
  • gawths5 Aug 10, 2008
    i shall try that thank you. gawths
    Sergeant:
    Champion:
  • 236 Answers
Try using compressed air to blow into the air vents.
Or use your vacuum hose on the air vents and the fans.
Posted on Aug 07, 2008
Rear vent controls not working
The rear blower motor switch and the rear floor console switch bezel are serviced only as an assembly.
  1. Disconnect and isolate the negative battery cable.
  2. Remove the rear floor console.
Rear Blower Motor Switch
  1. Remove the rear floor console switch bezel by releasing the retaining tab located at each end of the switch bezel and pushing it out through the front surface of the console.
  2. Disconnect the wire harness connectors from the rear blower motor switch and the rear heated seat switches.
  3. Remove the rear heated seat switches from the rear floor console switch bezel by gently prying the switches free from the back of the switch bezel.
INSTALLATION
  1. Install the rear heated seat switches into the back of the rear floor console switch bezel. Make sure that the switch retaining tabs are fully engaged to the bezel.
  2. Connect the wire harness connectors to the rear blower motor switch and the rear heated seat switches.
  3. Install the rear floor console switch bezel into the rear floor console by pushing it in through the front surface of the console. Make sure that the bezel retaining tabs are fully engaged to the console.
  4. Install the rear floor console.
  5. Reconnect the negative battery cable.
Feb 20, 2014 | Chrysler Pacifica Cars & Trucks
How do I get my playstation 3 concole to stop over heating and shuting down?
Hello sugarplum 29,
Unfortunately with a lot of consumer electronics, especially video game consoles, the internal components and heat syncs deteriorate over time. My suggestion to you would be to make sure your console is in a well ventilated location away from anything that could be keeping heat close to it. Also, make sure the room you're playing in isn't become hot from all the heat expulsion from any electronics on, as this may cause the problem. If the problem persists, you may need to seek warranty work or a repair.
Hope this helps!
Jul 07, 2013 | Sony Playstation 3 (PS3) Console
Something rattling in my n64 console
Well it might be those gray heat chips that are cAusing the problem so to fix this problem you need to use a heat gun and thermal paste to fix this problem
Dec 11, 2012 | Nintendo 64 Console
My N64 console keeps on frezzing during the middle of game play I don't think that shes over heating or is dirty because I just cleaned her out and play it with a fan blowing on it. Could it be the av...
Well video game consoles are sensitive to heat and its an over heating problem if the ac adapter smells burnt than its possible that the adapter isnt sending out the right signal to the system or if the voltage is off it will cause stalling. So try cleaning out the gamepacks and put the gamepacks in halfway instead of all the way in. Or there might be a problem with the console. Dust causes video game consoles to overheat 10 times faster than there normal heating rates.
Feb 10, 2011 | Nintendo 64 Console
Ps3 flashing red and won't go on-help
  1. 1ST OF ALL,UNSCREW THE CONSOLE TO THE MOTHER BOARD
  2. CLEAN BOTH PROCESSORS CAREFULLY
  3. THEN HEAT BOTH PROCESSORS WITH REWORK STATION IRON
  4. YOU ADD HEAT,****&SOLVER PASTE ON BOTH PROCESSORS.
  5. THEN ASSEMBLE THE CONSOLE.
  6. TEST THE CONSOLE
Jan 09, 2011 | Sony Playstation 3 (PS3) Console
My n64 keeps freezing every game i try works for a coiple minutes then freezes what do i do to make it work?
Well maybe the console needs to be cleaned out then dust causes videogame consoles to heat up 10 times faster than their normal heating rates.
Jul 06, 2010 | Nintendo 64 Console
0102
0102 Error in the "Digital Backbone" (CPU/GPU/RAM) is usually caused by a cold solder joint between the GPU and the mainboard.
There are two theories to fixing this. One deals with the "X" clamps that hold down the chips. The other involves re-Heating the chips. DO NOT attempt either of these if your console is still under warranty. If your console is still under warranty return it to the store where it was purchased or call Microsoft to have it replaced.
Thank you!
May 11, 2010 | Microsoft Xbox 360 Console
2 red light error heatsinks wont heat up
2 red flashing lights means your console overheated you just needed to let it cool and or check the fans and other cooling components, and by the sounds of it not heating up you have cooked the chips by trying to fix it so you console is basically a paper weight now, sorry
Nov 13, 2009 | Microsoft Xbox 360 Console
My Xbox keeps switching its self off after five minutes and then two red lights are coming on on the console. Do you know what would be causing this?
Yes I do . Some times when console take a fall or get bump hard
it will dislodged the heat sink from the C.P.U. breaking the thermal
seal . Then the console will over heat in 1-5 min .
The Fix is simple . open the unit up and press down evenly
and firmly on the large heat sink to re-seat it to the C.P.U.
leave it open turn it on and repeat if it over heats again ,
sometime it takes a few attempts .
Rob
Oct 08, 2009 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
19 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
