My printer is out of order. The ink system has failed. Unable to print. Error: 0xc19a0020. I turned the power off then on again but the problem is also the same. Please help me. I have a HP Photosmart c5150 All-In-One.
  • postbo Aug 14, 2008
    Same problem. HP photosmart c5180
  • ideacity Nov 21, 2008
    My Printer has an Ink System Failure. Do These steps and it should get you back running. This was the conversation from the tech:
    Christina: Let us perform some steps to isolate the issue and find a fix for it.
    Christina: Please perform the following steps and let me know the message that will be displayed on the printer.
    Christina: A. - Press and hold the “*” key.
    B. - Press the “#” key and release both keys.
    Display should say “Enter Special Key Combo”
    C. - Press and release in sequence the “1”, “2” and “3” buttons.
    CustomerName: ok
    CustomerName: screen says "support" R0631M
    Christina: Fine.
    Christina: 2. Press and release the right arrow button until the display says “System Configuration Menu”.
    Christina: 3. Press and release the “OK” button.
    Christina: 4. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
    Christina: 5. Press and release the “OK” button.
    Christina: 6. Display should say “Hardware failure status: Clear. Press OK to clear”.
    CustomerName: yup
    Christina: 7. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
    CustomerName: ok
    Christina: 8. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
    CustomerName: ok
    Christina: 9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
    CustomerName: done
    Christina: Fine.
    Christina: 10. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
    CustomerName: done
    Christina: 11. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
    CustomerName: made a buncha noise, and it didn't print a diagnostic page
    Christina: Good.
    Christina: Is the error message still being displayed on the printer?
    CustomerName: nope
    Christina: Good.
    CustomerName: should I try to print something?
    Christina: Let us print a self test page to check the functionality of the printer.
    Christina: Press Setup menu on the All-in-One then scroll using the arrow key and select Print Report then select Self Test Report.
Here is the conversation from a tech. I had the same problem.
CustomerName: ok
Christina: Fine.
CustomerName: yup
CustomerName: ok
CustomerName: ok
CustomerName: done
Christina: Fine.
CustomerName: done
Christina: Good.
CustomerName: nope
Christina: Good.
Posted on Nov 21, 2008
  • tazztone Sep 22, 2010
    no 1 2 and 3 buttons... can't get Support to appear on screen :(
Hp-support says:
"Please perform the steps given below:
Step One: Power cycle.
1. Unplug the power supply from the wall outlet.
2. Unplug the power supply from the back of the printer.
3. Wait at least 20 seconds, then plug in the supply back into the wall outlet.
4. Plug in the power supply back into the printer.
5. Press the power button to turn the printer on.
Steo Two: Perform a reset in the unit.
1. Remove the power cord from the back of the product.
2. Press and hold down the OK and Help buttons at the same time.
3. While holding the buttons down, plug the power cord into the back of the product.
Verify the results.
If the issue persists, I wasnt to inform you that this could be a hardware issue."
but it did not solve my problem
Posted on Aug 14, 2008
HP Photosmart D7360 ink system has failed. How do I fix this?
with 2 new cartridges installed, shut the machine off and back on again.
Jan 06, 2015 | HP Photosmart D7360 Digital Photo Inkjet...
HP Officejet 6500A Printer problem. Ser.No.
Try reset the printer after you have cleaned the printheads. http://www.youtube.com/watch?v=31TbWMrTaFk
Sep 18, 2013 | HP Officejet 6500 AllInOne InkJet Printer
Showing error 0xc19a0020 Ink systme has failed. Unable to copy, recieve faxes, or print
The product displays a '0x ... ' error message. The exact text of the error varies by product, but it is usually preceded by the word 'Error .
Solution one: Reset the product
  1. Without turning off the product, disconnect the USB cable from the rear of the product. NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ).
    1. Remove the cartridges from the product.
    2. Wait for the 'Insert Cartridges ' message to display on the control panel.
    3. Disconnect the power cord from the back of the product.
    4. Wait 60 seconds.
    5. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
    6. Reinsert the cartridges, and then close any open doors on the product.
    7. If you receive a prompt to print a calibration page, do so.
    8. Reconnect the USB cable to the rear of the product, and then try printing again.
Mar 06, 2011 | HP Photosmart C6180 All-In-One InkJet...
Ink system has failed. Unable to copy, receive
normally in this scenario the whole printer needs to be replaced..
Oct 22, 2009 | HP Photosmart 3310 Printer
Ink system failure
Do this: Performing a power reset
  1. Press the On button to turn off the HP All-in-One.
  2. Unplug the power cord from the back of the HP All-in-One.
  3. Unplug the power adapter from the wall outlet and wait for 30 seconds.
  4. Plug the power adapter back into the wall outlet.
  5. Plug the power cord to the back of the HP All-in-One.
  6. Press the On button to turn on the HP All-in-One.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Sep 07, 2008 | HP Photosmart C7280 Laser Printer
HP PHOTOSMART 7180 ALL IN ONE
how to reduce the baud rate in all in one printer
Apr 16, 2008 | HP Photosmart 3210 All-In-One InkJet...
2,177 people viewed this question
k24674
jasbo
jasbo
