Question about Toshiba DKT-2010 Corded Phone
Extension phones Some extension phones don't ring.
  • pamfos Aug 08, 2008
    We, too have some extensions that don't ring when a call is coming in from "outside". It's not a matter of volume, some extensions ring for incoming calls, and some don't.
    Post Solution
    Work Queue
    --> Have the same problem?
    Have the same problem? Click Here
    X
    This Problem has been added to the Share Your Expertise Page under "My Work Queue".
    OK
    Clarification Request
    by mitelmike, posted on Aug 08, 2008
    When you say some extension phones don't ring do you mean if you dial their extension from your phone they don't ring or
    Work Queue --> Have the same problem? --> Have the same problem? Click Here
    X This Problem has been added to the Share Your Expertise Page under "My Work Queue". OK Clarification Request by mitelmike, posted on Aug 08, 2008 When you say some extension phones don't ring do you mean if you dial their extension from your phone they don't ring or
  • Michael Bowen May 11, 2010
    When you say some extension phones don't ring do you mean if you dial their extension from your phone they don't ring or that they don't ring on incoming calls. Let me know and I can help ...Mike
  • 31 Answers
These has to be programmed to ring your will need to csll your local dealer to come and program these phones to ring.
Posted on Oct 11, 2008
Phone not ringing in normal mode
I believe this is a programming issue.
To change the ringing assignments on extensions enter programming mode by pressing Feature **266344 and password 266344 if it hasn't been changed. You have to do this from an M7310 phone. The top two buttons on each side will move you through programming. The top right button is the SHOW button and the button below it is the NEXT button. The top left button is the HEADER button and the button below it is the BACK button.
Your first category should be TERMINALS & SETS. Press the SHOW button and using the dial pad enter the extension number. The display should show the extension number or name. Press SHOW three times and the display should show LINE ___.
With options to SCAN or LIST. Pressing SCAN will show the lines assigned to the extension. Use the CHNG option to change how the line is on the phone. RING ONLY - UNASSIGNED - APPEAR ONLY - AND APPEAR & RING. Change the lines you want to ring in NORMAL DAY MODE to APPEAR & RING for this extension and press SCAN to move to the next assigned line. Use this same method for any extension you want to change the ringing on.
Dec 18, 2013 | NorStar M7310 Corded Phone
HP LaserJet 3055 .fax not working
Direct Line:
1.Check telephone line.2.Make sure telephone line is connected in line in port not in extension.3.connect extension telephone phone to the device & check for the dial tone.
Dial the number and observe weather extension phone is ringing?
A. *If extension phone is ringing check display is there any message like "ringing".. wait till fax tone comes,if not check "basic fax settings"... if setting are OK .. Replace formatter
B. *Extension phone is ringing no message displayed on device replace "LIU" card..
If extension telephone is not ringing check telephone line..
No out going faxess:
*Check line is connected though EPABX , if connected Check..prefix setting..
*Check out going..
Best of luck...
Sep 06, 2011 | HP LaserJet 3055 All-In-One Printer
We have one incoming line that we don't want to ring. How do we program the Avaya System to stop ringing when a call comes in on that line?
At ext 10 or 11
press feature 00
LEFT intercom
LEFT intercom
Right intercom
enter extension number to change ringing on
the line buttons will light up if you touch the line it will change the flashing and the ring style.
Once done, press feature 00
Repeat for all phones.
Aug 03, 2011 | Avaya 700340193 Corded Phone
Panasonic kx dt 333 When the phone rings the red light doesn't flash to denote which line it's coming in on. Any idea how to resolve this?
Which means what? You have a solid red light on the line or you don't have the line at all. A TDA system rings by a process called ICD groups. You can have a phone in an ICD (600 by default) and tell it the number of rings to delay, not ring, or immediate ring, but that means that the line button will flash as the call is coming in. If you don't assign it to a group, it's really stupid and won't do anything but light solid red.
If you have access to installer programming, you assign the extension to the main ICD. If you don't you have to call your Panasonic installer or dealer.
Carl
May 11, 2011 | Panasonic KXDT333 Phone
Hi would like to know how to set an extension not to ring when any of the co lines is ringing since i have a fax machine connected to this extension and it is programmed to answer automatically
Ringing for each extension and line is done in Panasonic system programming commands 408-410 for Day/Night/Lunch. You turn off ringing for all lines to your fax extension and then just turn on one line for that phone.
Be sure to turn off or delay the fax line ringing to all the other extensions at the same time.
Carl
Nov 03, 2010 | Panasonic KX-TA308 Phone
How do I set phone to ring at my extention?
Partner, all releases.
Examples
Receptionist Call Routing. If you want calls to be answered by the receptionist first, set the lines at the receptionist’s extension to Immediate Ring and the lines at the users’ extensions to No Ring. (This is the factory setting)
Receptionist Backup. If you want all calls on a line to ring directly at users’ extensions -with the receptionist providing backup -set the line at the users’ extensions to Immediate Ring. Then set the line (or lines) at the receptionist’s extension to Delayed Ring. An incoming call that is not answered by a user within 20 seconds will also ring at the receptionist’s extension.
Programming
To change the way outside lines or pools ring at an extension:
  1. Press [ Feature ] [ 0 ] [ 0 ] [ System Program ] [ System Program ] [ Central Tel Program ].
  2. Enter the number of the extension to be programmed for Line Ringing. The green lights next to the line or pool buttons on the phone show the current Line Ringing settings for all lines assigned to the extension. (If a line is not assigned to a button, the green light next to the button is off.) The following ringing options can be shown by the green light next to the line button.
    • Immediate Ring - on steady
    • Delayed Ring - flashes slowly
    • No Ring - flutters quickly
  3. To change Line Ringing for any line, press the line or pool button until the button light shows the correct setting (the setting for the currently selected line or pool also appears on the display).
  4. Continue programming or exit programming mode.
Dec 01, 2009 | AT&T Lucent MLS-12D Phone
Incoming calls ring 3 times at main extension, then phone stops ringing at main & rolls over to ring at all other phones. Phone rings once at those extensions before going to voicemail. (We have...
Your voicemail thinks that it is ringing six times. The time that it takes to transfer to the extensions counts. Whiloe it seems that there is a lapse the system actually is using enough time to ring six times total. If you need longer ring time at the extension, take in account the transfer time and set it to pick up after 8 or 9 rings. It will actually only ring six. You just have to trick the system a little.
Jul 22, 2009 | Cell Phones
Lucent Partner 18D phone not ringing.
On extension 10 or 11
Press Feature 00
Left Intercom, Left Intercom, Right Intercom
Input your first extension that you want to ring.
Press desired line to ring until display say Immideate.
Press Right Intercom for next Extension.
Cheers.
May 19, 2009 | Lucent PARTNER18 Corded Phone
Stop ringing at certian phones when outside calls come in.
http://dstech1.com/programming-line-ringing/
Examples
Receptionist Call Routing. If you want calls to be answered by the receptionist first, set the lines at the receptionist's extension to Immediate Ring and the lines at the users' extensions to No Ring. (This is the factory setting)
Receptionist Backup. If you want all calls on a line to ring directly at users' extensions -with the receptionist providing backup -set the line at the users' extensions to Immediate Ring. Then set the line (or lines) at the receptionist's extension to Delayed Ring. An incoming call that is not answered by a user within 20 seconds will also ring at the receptionist's extension.
Programming
Jan 09, 2009 | Lucent PARTNER18 Corded Phone
Phone ringing.
On extension 10 or 11 press Feature 00
Left intercom, left intercom, right intercom
Enter your extension number
Press line buttons until its a fast blink and display say no ring
Feature 00
only transfered calls will ring
Nov 21, 2008 | AT&T Partner 18 Phone (315805B)
Toshiba DKT-2010 Corded Phone Logo
81 people viewed this question
Top Toshiba Lands Phones Experts
Oloyede Monsuru
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
