Question about Humminbird NS25 GPS Receiver
Gps ns25 gps will not turn on the plug in power line has power
The wiring within the Screen unit seems to be very poorly done, there are 4 cables to the GPS side of things and these can contact each other as there is a portion of the wire where it enters the connector that is bare, and if these touch one another then you will get nothing.
Dismantle the head unit and check the cables, i would be inclined to shrink wrap the bare portion of each cable.
Hope that this helps, it might not be the answer, but it is worth checking.
adrian.
Posted on Dec 18, 2008
Why when i plug in my garmin device does it show a computer but no maps
Are you using a simple USB lead plugged into a USB power source? If so, the unit is (correctly) going into its USB mode.
You can also try different USB leads, some do not have the data line so act as just a power lead. It's the data line that signals the GPS unit to go into USB mode.
Regardless of the type of lead, your unit will charge like this and then, when the lead is disconnect and the unit turned on, will work normally off the internal battery.
If this is your experience, you will need either the correct GPS power source or a "USB power" lead.
Nov 05, 2016 | Garmin GPS
Gps ns25
Please check the mount and the wiring throughly as its a loose contact issue nothing else.
Aug 07, 2008 | Humminbird NS25 GPS Receiver
Moisture in antena
Hello there.
Please click here to find a replacement antennae for your Humminbird device.
Hope this helps.
Jun 05, 2008 | Humminbird NS25 GPS Receiver
Plugged humminbird ns25 gps antennae to my 898cxi humminbird but no gps signal
The NS25 uses a much different god receiver than what is available now and will not work with your 898. What you will require is a AS GRP receiver. https://www.humminbird.com/Products/AS-GRP/
Source: mikesreelrepair.com & Humminbird.com
Jan 11, 2014 | Humminbird NS25 GPS Receiver
In the start up mode as not connected can any body help
What happened since then. Have you solved it somehow? I have the same problem..
Apr 02, 2012 | Humminbird NS25 GPS Receiver
My gps model# c330 wont turn on is totaly discharge
Check to see if you are getting power through you cord. You should have 12v at the plug end to the GPS unit. If not, you may have a blown fuse or no power at the plug. There is a fuse in the male 12v plug for your GPS. Unscrew the end to check it.
Dec 19, 2009 | Garmin StreetPilot C330 GPS Receiver
My garmin 750 gps will not turn on when plugged into power source
A dead battery will cause the unit not to turn on, but it should turn on if connected to an external power source like an AC wall charger or DC car charger.
- Jim
SHARCNET-USA
Mar 05, 2009 | Garmin Nuvi 760 Car GPS Receiver
Hummingbird gps ns25
Hi!
here's a user manual/installation manual for your sounder:
NS25
If the depth sounder portion works, I would suspect the settings are off (check first) or the gps circuit needs repair.
Best of luck!
Mike
Sep 02, 2008 | Hummingbird Humminbird 1155C GPS Receiver
Zumo 550
Make sure that the bike's electrical connection to the GPS unit is actualy not having power once you turn the key off in the bike. This GPS turns on with external power. It is inherent in to its design.
In the case were you cannot have the bike's power source to the GPS turn off with the key, see if you can wire a small in-line switch in series with the GPS unit so that you have an external power switch. This should be easy to do.
The models I have used from Garmin have their own power switch. You should be able to use its power switch to turn it off.
Jerry G.
Jul 19, 2008 | Garmin zumo 550 GPS Receiver
Humminbird NS25 GPS
This is a common problem on lots of boats with any brand of electronics. Most likely it is being caused by a bad crimp in a wire connector, or by having too many connectors on a terminal in the power supply bus. Start at the power supply source and ground and replace any butt or terminal connectors with high quality heat shrink connectors (such as Ancor). Make sure that the connector is the right size for the wire.
On Humminbirds the problem could also be in the swivel mount that holds the power and data cables. The cables should be held in place by a metal bracket which is located under a panel held onto the swivel bracket by to small philips head screws. If any of those components are missing, the plug may be loose in the socket which could cause it to disconnect temporarily when the boat hits a wave. While you have it apart check the plug and the socket for corrosion.
I hope this helps. Please contact me if you have any more questions.
Feb 10, 2008 | Humminbird NS25 GPS Receiver
Humminbird NS25 GPS Receiver Logo
277 people viewed this question
Top Humminbird GPS Experts
Mike Marcotte
Mike Marcotte
Steve
Steve
Jerry Greenberg
Jerry Greenberg
Are you a Humminbird GPS Expert? Answer questions, earn points and help others
