Question about Sharp Office Equipment & Supplies
Code u2-22 printer sharp ar-m355n - Sharp Office Equipment & Supplies
Benimur
  • 6966 Answers
SOURCE: printer all in one sharp ar-m155
Hi again,
Sorry but not the wire, I was referring to where the wire is attached, both ends. This would either be a clip-on or sandwiched between 2 small plates held together by a screw. It is not uncommon for this clips or plates to be tarnished or have burns. They have to be cleaned, if not current will not flow freely to the corona wire. The purpose of the wire is to draw the toner from the drum onto the paper, it uses static electricity to coat both the photoreceptive drum and the paper with a layer of positively charged ions. If the corona wire is not getting full charge or no charge at all, this is the primary reason the warming up is taking too long.
Additionally, try to enter service mode; try #, *, CA, #.
To reset the developer counter press 24, Start, 5, Start.
To exit press reset 3 to 4 times or turn main power off/on.
Would appreciate further updates.
Posted on May 03, 2008
SOURCE: driver sharp ar-5220
Driver Sharp AR-5220 Please.
Posted on Dec 05, 2008
SOURCE: Sharp AR-5316 photocopier & printer driver
Sharp AR-5320 photocopier/printer is in share network. for each printing command ,its asking to install driver.and its taking more time for printing..
Posted on Jan 11, 2009
  • 190 Answers
SOURCE: error code Sharp AR-M 257
The F2-04 error code you are getting is that you are using the wrong toner.It may be form sharp,but it toner chips is different.Only the chips swapping at the toner back can help you.
Posted on Jan 27, 2009
  • 62 Answers
SOURCE: sharp ar-m350u error code h5-01. How do I fix
vheck this link out http://www.fixya.com/support/t1570580-remove_h5_01_error_code_sharp_arm550n
Posted on Apr 15, 2009
Have a weird problem on a Sharp AR m455n the screen stuck on the sharp logo any ideas?
Sometimes this would happen when a bad print job got sent to the machine. I'd make sure to delete all of the print jobs in everyone's print queue on their computer then reboot the machine to see if it comes back up.
Copier Collin Houston TX Copier and Imaging Expert
Aug 18, 2014 | Sharp Black Toner Cartridge For AR-M355N,...
How do I set up an address to the frequently used addresses tabs on sharp ar m355n?
on the web page(accessed by typing the machines' IP address into a web browser)
click destination, the username is admin, and the password is Sharp
then put a check next to the person's name, and click edit
then check the "Frequently used" box on the page and click submit.
Skelton Business Equipment Houston Copiers
Jun 19, 2014 | Sharp AR-M355N Copier
Sharp copier USB connection not recognized
WHAT OS U USE?
TRY THIS LINKS......
http://www.solvusoft.com/en/update/drivers/copier/sharp/ar-m355n/sub-models/
http://iprinterdrivers.info/download-driver-for-sharp-ar-m355n-printer.html
http://www.sharp-world.com/products/copier/downloads/index.html
AND ALWAYS U CAN GO FROM -CONTROL PANEL- TO -DEVISE MANAGER- AND FROM THERE U SEE THE PRINTER DOUBLE CLIK ON IT AND U SEE INFO OF DEVISE(PRINTER) LIKE DEV ID (DEVISE ID) COPY THE ID AND GO THERE
https://devid.info/ AND JUST PASTE AND FOUND THE DRIVERS
Oct 13, 2017 | Sharp Ar-m355n Copier Printer Scanner Fax...
Sharp m355n error code L3-00
L3-00 means that the scanner (the light under the glass) isnt moving correctly. You can reset it by pressing clear, interupt,0, interupt, 14,1, start button. Good luck
Jan 23, 2014 | Sharp AR-M355N Grayscale Copier
I have a sharp AR-M355N machine and I keep getting error code F2-00, what does this mean, is there a specific fix for it
This code is Toner Control Sensor open/trouble.
Check connection of the toner control sensor.
Check connection of connector and harness to the main PWB.
Check for disconnection of harness.
If all is fine, replace the sensor.
Nov 09, 2010 | Sharp AR-M355N Copier
Error code L4-02, what is the error?
In the Sharps, a L4 error is some kind of motor error. Not sure about L4-02 on the 355.
Aug 25, 2010 | Sharp AR-M355N Copier
I have a AR M355N and it gives me "finisher out of service." Do I need all the trays installed to clear this?
Maybe? Most likely the problem could be with the stapler unit not finding HP. Did you have a error code before the finsher could not be used?
May 27, 2010 | Sharp AR-M355N Copier
How to fax?
You access the fax functions (if optional kit is installed) by way of the Image Send button on your panel. Press Image Send, then press the FAX key on the screen. dial as you would any fax when the number is dialed and the document is in the feeder, press the start (copy) button and you are faxing...
Les Olson Company, Sharps #1 ind. Dealer in the USA. Selling Sharp in Utah and Las Vegas with 7 locations to serve you.
Feb 03, 2009 | Sharp AR-M355N Copier
840 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
