Question about Ricoh Aficio GX3050N Printer
Hello, we're getting an error code of 990 on a GX5050n inkjet printer. The printer is fairly new with only a dozen or so printouts. Thanks.
  • spowell32 Feb 17, 2009
    error 990
  • Anonymous Feb 18, 2009
    We have the same error code 990 on a fairly new Ricoh GX5050N printer. It would be nice if someone could help us all out with this.
    Thank you for assistance someone can provide.
Make sure printer is off. Then old down escape and online button at the same time. Continue to hold these two buttons down then turn on printer. Continue to hold those two buttons down (will take about 2 - 3 minutes). This should clear that message - worked for me!!!
Posted on Mar 23, 2009
  • janis_vogel
    janis_vogel Sep 06, 2013
    what is your online button?
I'm 99% all the responses on the error 990/999 are wrong. This error is due to a clogged waste ink line. These are great printers but they have some design weaknesses and this is one of them. I believe the waste ink coats the inside of the waste ink line and then a layer dries (the end of the waste ink line is open to the above the waste ink collector) then another, then another until the line clogs. You can put water inside the head cap when you have this error and the priming pump will not pull it thru to the printer and you'll notice no ink shows up in you waste ink collector. I was able to recover a GX3050sfn from this error by power cycling and chunks of dried ink showed up in the waste ink collector. Now the bad news, it does not seem to be simple task to clear the waste ink line, but I'm working on a solution. I've tried connecting an extension tube to the waste ink tube above the collector and pulled a vacuum with a 60mL syringe when the printer was powered on but no luck (this can clear epson waste ink line clogs because I've done that many times to fix C80s/C84s/C86s etc.). It is possible to prevent this from ever happening by creating a sealed bottled waste ink system (contact me at adaptive2009@hotmail.com if you want help with this). I should have a fix also very soon even if I have to disassemble the printer.
Posted on Sep 15, 2011
I have a flashing red light blinking on my HP Deskjet 990 cse...it's the far left light. How do I fix this? I shut off and restarted. Changed ink...no jams of paper.
Welcome to Fixya. Can you please refer to the link below and check which of the error you have. On the link below you will be able to see the meaning of the blinking lights and the resolution.
HP Deskjet 990 CSE
Thanks
Aug 07, 2011 | HP DeskJet 990cse InkJet Printer
Ricoh Gx7000 inkjet A3 Printer - what does 'error 990' mean?
Error 990 indicates a dirty sensor, so either a maintenance unit is dirty or you have a clogged print head. You can read more about this error on Richo website where you can see in the images what you need to clean.
Feb 13, 2011 | Ricoh A3 Gel GX7000 InkJet Printer
Error code 990 still after reset. what to do
Error 990 is an error message that has to do with the ink drying out on the maintenance unit. Unfortunately this is a fatal error and the printer will need to be replaced as the maintenance unit can only be fixed by a technician. You will have contact Ricoh for further information on possible replacement.
Apr 09, 2010 | Ricoh Aficio GX3000 InkJet Printer
Error 990 keeps blinking on machine
This is an error that has to do with the ink drying up on the maintenance unit. This cannot be fixed by the end user and must be fixed by Ricoh. Error 990 is a Ricoh defect in which the printer should qualify for replacement.
Feb 12, 2010 | Ricoh Aficio GX5050N Printer
Error code 350 error code 990 error code 540
Error code 990 indicates software problems yuo can check in SP7-403 for information.
Error code 540 will proberly indicate some heating trouble in the fix, you have to reset the machine with service code SP5-810.
Code 350 will disappear if you restart the copier.
Oct 09, 2009 | Ricoh Aficio 1035 Copier
I replaced the ink waste tank on my Ricoh GX3000 - then it asked for new yellow ink cartridge and I replaced that. Now I have an error code 990 and I can't get rid of it.
bonjour,
allume ton imprimante,puis retire toutes tes cartouches.
eteint l'imprimante.
rallume l'imprimante et remet les cartouches.
le code d'erreur 990 indique de l'air dans les tuyaux.
ça devrait marcher!
Oct 05, 2009 | Ricoh Aficio GX3000 InkJet Printer
Hello, got an old Aficio 1045 with headcrash. I
The 900 code is the software error code.Enter in theuser and SP modes and configuration the new duplex.For more information please answer.
Sep 28, 2009 | Ricoh Aficio 450 Copier
Have error code 990 on ricoh gx 3000 printer how do i clear this?
you can try pulling out and reseating the Waste Ink tank which is located behind the machine behind a plastic door cover (left side of machine as you are looking at it from behind). Turn the machine off and on using the main power switch. If the code comes back then you will more than likely need a new Waste Ink Tank.
Mar 23, 2009 | Office Equipment & Supplies
Ricoh Aficio GX3050N Printer Logo
1,931 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
