Question about Westinghouse L1975NW Monitor
Monitor goes black
If my hand bumps into the side of the monitor, the screen goes black. I have to move the monitor back and forth before it comes on. And ever since this first happened, it doesn't seem like my resolution is as good. I tried adjusting settings but it did nothing.
The controls on the side of the monitor are touch sensitive, rather than traditional buttons. You're probably accidentally brushing the power control. This would explain the power turning off if your hand bumped the right side of the monitor (where the controls are). You may need to tinker with the brightness and contrast settings to get it back where you wanted, or reset to the manufacturers defaults.
Posted on Sep 30, 2008
    Champion:
  • 293 Answers
Hi...there, It's could be 2 things...either your cables inside is lose or one of your caps is leaking fluid from the inverter. Turn off the power and open the back casing to check all the cables are secured. Good luck!
Posted on Aug 07, 2008
Screen comes on for a second then goes black. It
its just ur monitor setting or the setting in ur pc for stand by mode or power saver mode.
if u still could not figure it out pl say me which system u using(platform)
Jun 01, 2010 | Computers & Internet
I have a new DELLS2209W Monitor. On occasion my
I want you to try something next time this happens, instead of rebooting the computer, just cut power to the monitor. Then switch it back on.
Does the screen come back up?
Comment back and let me know
Mike
Dec 19, 2009 | Dell Computers & Internet
Computer screen is flashing
dell monitor will work fine and then go black with an internal blue light flashing from the bottom of the screen up. I have checked wires they are ok. I am able to get it working sometimes if I move the position of the screen back and forth or up and down the on button will stop flickering and it will come back on. HELP!
Jun 24, 2009 | HP f2105 21" LCD Monitor
Screen stays black on startup of toshiba satellite L300
have you tried either switching between external and internal monitor usally Fn + F5 on toshiba or try plugging a monitor into the back and see if it displays.
if you get a display on the external monitor then its probably a screen or inverter fault if you donot get a display to an external screen then it is likley t be the graphics on the board itself.
hope this helps
Feb 22, 2009 | Toshiba Satellite Pro L300-EZ1501 Notebook
Gateway monitor problem
Does this monitor has a reset to factory specs on the menu? If so then select it.
Jan 05, 2009 | Gateway FPD1760 17" LCD Monitor
Black screen on the right side of my acer 5630
You need to give me a few more details,is the screen blurry on one side,and brighter on the other?,two, are you using a some special graphics software that might not be ment for your computer,you should plug a monitor into your laptop to see if it gives the same affects,and press the window or function key, and one of the monitor symbols on your keyboard at the same time(,they are coloured the same as the function key),to change your main screen to a plug n play one,if the screen comes up with the same affects then it is a software problem,you might have to uninstall the software that is causing the problem,or two if is comes up perfectly,then it might be a hardware problem,you might have to bring your laptop to a pc mechanic to be degaussed,this puts a charge on your laptop screen and it costs more to do than replace one,most plug and play monitors can degauss them selves,others need to be done manually,unfortunately laptop screens have to be taken apart to be degaussed,i know its silly.if its not blurry then it cant be hardware problem.its one of your graphics settings.
Nov 25, 2008 | Acer Aspire 5630 Notebook
Problem with FPD1760 Gateway monitor
sounds like the LCD inverter gone bad.
you might get lucky in finding one on EBAY.
yeah gateway sucks on customer service.
Jun 18, 2008 | Gateway FPD1760 17" LCD Monitor
FPD1775W
Use these steps
1. Rightclick on the Desktop
2. Click Properties
3. Click ScreenSaver Tab
4. Click Power
5. Turn on Monitor - Never
6. System Stand by - Never
7. Click Apply
Thank U
Apr 16, 2008 | Gateway FPD1775W Monitor
1inch black line down right hand of screen
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Jan 15, 2008 | Computers & Internet
Screen goes blank when I move the mouse
please be specific, your question is not understood properly??
Oct 26, 2007 | Dell E173FP 17" LCD Monitor
Westinghouse L1975NW Monitor Logo
79 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
Alun Cox
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
