Question about NAD T743 Receiver
Turns itself off
My T743 has started to turn itself off randomly from time to time. Any ideas what could cause this? The red power button is on but it is impossible to turn it back on without unplugging it.
  • GoneNAD Oct 05, 2008
    I have exactly the same problem. Can anyone help?
  • ianp30 May 04, 2009
    I opened up the receiver, found D756 and verified that I have diode 1N4004, but my receiver still randomly powers off. The difference between when I power off and when it powers itself off is when it powers itself off the volume is almost turned way down. This problem is getting worse. Do you have any more advice?
Mine got fixed, had to replace the front panel PCB card that includes the control processor: 350€...
Posted on May 03, 2010
  • Robert McComb Oct 12, 2011
    Agree with this solution - mine had the same symptoms and the equally costly fix.
NAD Technical Bulletin T743-H2005-06 describes the problem "Unit may shut down, shortly after turn on".  Reason: There is a diode on the standby board that maybe operating intermittently.  Solution: Locate and identify D756 on the standby board.  Change only if the diode is a 1N4148.  Change from a 1N4148 to a 1N4004 or equivalent.
It is located near a transformer and some fuses.
Posted on Oct 29, 2008
  • Richard Gilpin Jul 29, 2012
    I found the diode at D756. I could not tell what its number was. I pulled it out and replaced it with a 1N4004. The NAD would not then start up. I replaced the diode with another brand-new IN4004. Still nothing. The orange ready light on the front stays on, but the unit never turns on when I push the power button. But I think I have done something because the unit does not now report "overheat." I am not an electrician, but I am confident that I installed the 1N4004 properly. Any more suggestions? TIA
Samsung la32s81b
Probably the power supply is failing or has failed.
Oct 24, 2017 | Televison & Video
My NAD T743 will not switch on. I haven't used for a couple of months and it was working just fine before. Now I tried switching it on using both the power button on the amp itself and the remote, to no...
Hi, have you checked the power button in the back to see if it got pressed by accident? It's a round button located right under the speaker inputs in the back.
Apr 11, 2010 | NAD T743 Receiver
1991 gmc sonoma random loss of power
could be the crankshaft sensor causing the timing to be off if it has a coilpack type distributor or if it has a gear driven distributor then it could be either the distributor itself or possibly just cap and rotor
Feb 13, 2009 | 1993 GMC Sonoma Club
Power on T743
Just had my t753 in bits... sounds like its overheating to me. Check that the fans on the bottom still turn and aren't clogged up with dust. Make sure that it has plenty of ventilation.
hmm, also try unplugging everything and leaving it on and see if it still freezes? ie check you're cabling is ok, there are no shorts from bare speaker wires etc...
Could try resetting it too? (in each case hold the buttons for 5 seconds then release)
- Firmware version: hold video 6 and tone control
- Reset DSP: video6 + tone defeat
- Reset completely: video6 + right source button (this will wipe all settings - hold for 5 seconds, release and then unplug from the wall or turn off with the rear power switch)
Nov 23, 2008 | NAD T743 Receiver
OVER HEAT
To reset the the T743 hold down the video 6 and the source up buttons for 3 seconds. then power up from the back button
Aug 18, 2008 | NAD T743 Receiver
Assistant
is this electricity pocket plugged up to a timer ? or take the tv back to the shop... lost the receit just look for the same tv on computer
Feb 20, 2008 | Toshiba 28N33 28" TV
TURNS OFF BY ITSELF
my tv starts turning a red color and then turns off by itsself then i have to unplug it to turn it back on every 5 mintues or so.
Nov 14, 2007 | Toshiba 46H84 46" Rear Projection...
NAD T743 Receiver Logo
1,724 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
