Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Violent and loud spin cycle Whirlpool Ultimate Care II
My washer spins very violently. It sounds as if the basket is slamming against the sides as it spins. Therefore, it is also very loud. It washes well and the clothes are always very well wrung out after the spin. But I'm sure this can't be normal and I'm afraid there is a problem that if I don't address may kill the washer all together. Thanks!
  • Anonymous Dec 27, 2008
    when in spin cycle it makes a loud rubbing sound and the agitater sounds like it is slipping then catching but if you hold agitater it will spin bt somes it will grap again making a banging noise.
Tilt backwards and check the balancing springs. one of them are broken
Posted on Aug 10, 2008
  • Whirlpool Master
  • 5,569 Answers
You may have one suspension point that has failed.
Open the back and using a flashlight, inspect the outer shell; the suspension should look the same at each point.
Don't know your particular machine but the suspensions are pretty primitive, some no more than heavy rubber rings at each point.
You're right that it shouldn't be ignored, as it can cause more problems and stresses the bearings abnormally.
Sometimes, this can be caused by running one very unbalanced load and not stopping the machine to redistribute the clothing to correct the imbalance.
This can cause a suspension point to become unhinged.
Posted on Aug 07, 2008
SOURCE:
Knocking sound, violent spin cycle led to not
my problem to just 3 days ago from yours! bearings are out, $600 getting a new one.
Jan 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer ultimate care II sometimes does not spin.
HI It sounds like the spin basket drive is going bad. If it was the lid switch, you would get no sound. Let me know if I can assist you further.
Thanks
Vic
May 16, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II Washer wont balance
Your basket drive is grabbing. the only way to stop that is to locate the clutch and the tube directly above it is your basket drive put a little white lithium up there. but not in the clutch. this will solve that problem. But if you do not know what you are looking for this will be difficult to locate.
Jan 22, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II spin cycle not functioning correctly
It sound like the basket is out of balance. When it spins open the lid and see if the basket is moving side to side and back to back. If so look under the deck and see if there is springs or rubber ties attached to the basket.
Jan 19, 2009 | Whirlpool LSQ9665JT
Whirlpool washer LSQ9549LW1- loud thunks at end of spin cycle
you can goto sears.com and goto parts, put in your model # and they have a parts and diagram that you can look at.. sound like your basket block (which holds your basket on the gear shaft) is loose.. or 3 bolts on bottom of washer the holds gearbox to frame is loose.. good luck
Dec 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirl pool washer bangs when in spin cycle
if new did you remove shipping strap in back..the unit cant lean more than 2 degrees..make sure clothes are even in tub..try to wash clothes alike..
Dec 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II GSW9650LWP Top load
sounds like the basket drive. it is kind of a big job.you need to take out the gear case and then the basket drive. you need a special tool to get it out. the agitator comes off forst there is a spanner nut that you must take off.
Oct 26, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Spin cycle noise
pull up and down on your basket to see if it has up and down play in it
kind of rock it side by side too
Dec 30, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Spin cycle
pull unit out from wall a bit no need to disconnect anything.CAREFULLY tilt unit back and have some one hold for you while you go under unit to check MOTOR COUPLING
Oct 25, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
168 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
