Question about Dynex Enhanced Wireless-G USB 2.0 Network Adapter
Cannot Find IP Address
I have a Windows Vista that uses the DYNEX Wireless G USB and a WESTELL Modem that the DYNEX uses and the USB cannot find the modem's IP Address. I have tried to turn off the modem and turn it back on and made sure that everything was plugged in, but I have still not found anything. This has been going on for months, so I have used a Windows XP laptop that uses the same USB and modem, but a couple of days ago the IP Address started having issues and we can get connected to the internet with it rarely, but every time it says we have connection to it, we will go on the internet and it will display that this page cannot be found everytime. We need help.
  • 4 Answers
Check the fire wall.
Posted on Aug 24, 2008
I need to find the clear modem setup pages
HI if your looking how to access your modem page this is what we can try
try to check for the ip address your modem is generating
you can use the default ip address of your modem-192.168.100.1
or you can check for the ip address which your modem generates ofr that
CLICK START>>RUN>>type in CMD>>PRESS ENTER>>BLACK WINDOW POPS UP>>type in
IPCONFIG>>PRESS ENTER..LOOK FOR THE IP ADDRESS(VISTA AND WINDOWS 7) LOOK FOR IPV4 ADDRESS...TYPE THIS IN THE ADDRESS BAR OF YOUR BROWSER(ex-internet explorer)
this should work..............have a great day
Apr 25, 2011 | Computers & Internet
Upgraded dsl modem to westell G-90-610015-20 and my linksys WRT54G router cant get an IP address. I just upgraded the modem from and older westell model, didn't change any of the settings and it can't get...
if you connect the computer directly to the modem, without any router , does it work?
Make sure that your computer will be online when connected to the modem.
If you are not online through the modem, then you should have the correct user name and password for the ISP.
Click Here for step by step solution
Oct 30, 2009 | Linksys Wireless-G WRT54G Router
Modem is giving wireless signal, yet I need IP address so I can make network secure. HELP!
Is there any computer connected to the wireless modem with the ethernet cable.
If not you will need to connect the computer to the modem to check the settings of the modem.
Does it have DHCP server. Do you have any computer online through the modem. If yes, check the IP address on that computer. You should have Private IP address on that computer.
Click Here for more info about networking
Oct 08, 2009 | Westell Wirespeed VersaLink...
Need to redo wireless setup betw linksys & westell
You will need to assign a different ip address to the Westell modem - I am assuming that both the router & modem are using the same ip address 192.168.1.1? If that is the case, then assign 192.168.1.2 to the modem.
Mar 15, 2009 | Linksys Wireless-G WRT54G Router
I have a dlink router and I want to connect my usb modem to it
is this an additional router?
Verizon are issuing modem with built in wired and wireless modem.
Try this;
How do I properly set up a D-Link Router with a Westell Modem? (#7125)
This FAQ is for setting up a BellSouth supplied Westell 2100/2200/6100 modem (Models A90-210030-04, B90-220030-04 and B90-610030-06/C90-610030-06, respectively) with a D-Link DSL router. Although actual screen shots vary throughout the DLink line, the instructions below are applicable to all models. Important Note: These procedures and pictures are based on the most recent firmware for the Westell. Other Westell firmware menus and screenshots are slightly different but the bridge options and functions are still available. It is highly recommended that you click here and update your Westell firmware.
This FAQ has 3 Major sections:
Section 1 - Overview
Section 2 - Westell modem configuration
Section 3 - D-Link router configuration information
Section 4 - Connections and power up
bred.gifImportant Note: Due to some known operational issues it is VERY important that you have the latest firmware on your D-Link router. Please go to the D-Link Support Site for firmware updates.
bred.gif The best configuration for networking a router with the Westell is to set the Westell to "Bridged Ethernet" mode and allow the router to do the routing and DHCP functions. The Westell is also a router with full DHCP functions and may not function correctly when connected directly to another router. Not changing the modem to Bridged Ethernet will result in double NAT'ing, increased latency, possible IP conflicts, or possibly a network that doesn't work at all.
bred.gif Before proceeding both the modem and router should be set to default. Despite what the help desk tech tells you, resetting the Westell does not put it into Bridged Mode.
bred.gif The BellSouth Installation CD and Connection Manager are not required to use this configuration.
bred.gif Since BellSouth assigns static WAN IPs via your username the configurations shown are applicable to both dynamic and single static IP customers. Select dynamic PPPoE regardless of your setup.
bred.gif You must connect the Westell directly to the computer's NIC to make the necessary changes before you connect the router, because you will be unable to access the modem interface after you connect the router. The reason is that the modem interface is 192.168.1.254 which is a local IP. By default, most routers do not have the capability to route a local IP out of their WAN port (where your Westell is connected). Additionally, they may be on completely different subnets. After you have made the changes to the Westell you can then connect the router and configure it for use with FastAccess. There are several alternatives around this problem. One method involves extra equipment (second NIC and a hub) and major configuration changes. The second method requires you to utilize the router as a simple switch and use the Westell's PPPoE and DHCP functions. Click here for more information.
bred.gif If you encounter any problems simply reset the Westell, connect it directly to your NIC, restart your computer, log into the Westell interface, and start over again.
bred.gif More information about the Westell is available here.
Section 2 - Westell Configuration
bred.gifStep 1
Verify that your NIC card is set to "Obtain IP Address Automatically". Completely power down the Westell and the computer(s). Power up the modem and press the reset button on the back of the modem. After the modem has fully initialized connect the Westell to the NIC and then power up the computer.
bred.gifStep 2
Open a browser session and enter 192.168.1.254 in the URL address field to access the Westell interface. If you are unable to access the interface make sure your NIC is set to "Obtain an IP address automatically". This may require you to reboot the computer (or release/renew) to obtain a proper IP.
bred.gifStep 3
Click on Broadband DSL Line from the top menu. Click on Configure Connection from the right menu. Select "Bridged Ethernet" from the Protocol pull down. Click on Save and restart the connection at the bottom. This will automatically restart the modem and the interface will return after the changes are saved. Note: functions like NAT, DHCP, IP Passthrough, and username and password will be disabled or irrelevant and can not be selected. After the modem has restarted, power down both the computer and the modem then physically disconnect the Westell.
Section 3 - D-Link Router Information
bred.gifStep 4
After the PC is powered down connect one of the router LAN ports to the computer NIC and power up the router and then the computer.
bred.gifStep 5
Use the following steps to configure your D-Link DI-604 Router. Important Note: You must use the username@bellsouth.net format for your username. If you do not add "@bellsouth.net" after your username you will be unable to connect to the internet.
Section 4 - Connections and Power Up
bred.gifStep 6
Power everything down and physically connect the Westell, the router, and any computer(s).
Westell 2100 shown. Pictures by Andy Houtz
bred.gifStep 7
Power up the network equipment in this order:
•Westell Modem (wait till the Ready light is a steady green)
•D-Link Router
•Computer(s)
Open a browser session and go surfing!
bred.gifAdditional Imformation
•You should check your tweak settings to optimize your new network. Reminder: If you are required to change your MTU, make sure that it is identical on all equipment (PCs and routers) in the network. For more information about changing MTU on a D-Link please click here.
•The 6100 has an "Internet" light that is green whenever there is an active PPPoE session initiated by the Westell. Since you are using the DLink to establish the PPPoE session the light will stay off. This is normal.
Mar 13, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Westell model 327w router
if this is the first time you're trying to connect your laptop with the gateway, if this is a windows operating system, you have to go to your wireless zero configuration so that windows can automatically configure the wireless connection of your laptop. you cann see that by clicking on start, and then run, and then type in the box services.msc, and then search for wireless zero configuration click on start if the service has not yet started. if this doesn't work check your built in wireless adapter, uninstall and reinstall it. try to access your westell by typing in 192.168.1.1 in the internet explorer address bar. the default username and password for that is admin and password. you can configure the wireless settings in the modem by going here. the WEP key for your wireless connection can be found below your westell modem/router. if i'm not mistaken this is the westell 327 versalink right? you can also find out if your laptop is connected to your modem by checking your computer's ip address. it should be 192.168.1.xx. if it's like this, your laptop is connected to your 327w. if it's a 169.xxxx ip address, you're not connected to the modem. the best way to configure your laptop and modem wirelessly is to configure it while you're connected using an ethernet cable.
Oct 21, 2008 | NetGear DG834G Router
SMC Barricade g SMCWBR14-N Wireless Router... router Configure with Westell 327W
it seems that the router capability of both devices are conflicting with each other so below are the steps that you can try to setup the two devices to work with each other.
i assume that you are using pppoe connection from at&t and you are using a connection manager. if so, with the current setup that you have right, you need to disable the connection manager on your computer (network connection, disable at&t connection) and set the connection of your web browser to "never dial a connection". check now if you will be able to connect to the internet instead of being prompted for a password. if your problem is still the same, try the steps below.
configure the westell 327w the way it was before (when it works properly when hard wired to the computers but the wireless sucks) but disable the wireless capability. change now the ip address of the smc router from it's default (192.168.2.1) to an ip address which is on the same segment as the ip address of the westell 327w (ex. 192.168.1.2 if your westell 327w is using the ip address 192.168.1.1). disable the dhcp of the smc router (note:make sure that you have configured all the settings that you want to configure with the smc (i.e. wireless settings, port forwarding, etc). then connect the westell to one of the LAN ports of the smc (note: with this setup, the wan port of the smc should not be used) and power cycle everything and check if this setup will work.
hope this'll help you and just ask me if you have other concern.
ciao!
Oct 08, 2008 | SMC Barricade g SMCWBR14T-G Wireless...
Westell 6100 dsl modem
I use a Westell 6100 modem....internet goes out periodically and is not red...just blank....in a few minutes it comes back on....and later out it goes again....
Dec 02, 2007 | Westell Wirespeed LiteLine 6100...
Failure to acquire IP address
How is the DHCP setting of the modem configured?
Nov 03, 2007 | Dell Dimension 4700 PC Desktop
Dynex Enhanced Wireless-G USB 2.0 Network Adapter Logo
106 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
