Question about Saeco Royal Exclusive 30153 Espresso Machine
Saeco Royal Exclusive 30153... FILL WATERTANK
Tells me to FILL WATERTANK when its full. Any ideas.. thx Marty g
  • martymg Aug 07, 2008
    Thanks.. yes that was soooo easy.. someone cleaned it and miss-placed that magnet. thx mg
    New Friend:
In my case, the magnet was covered with limescale and did not rise! Thank you for advice!!! :)
Posted on Jul 16, 2013
  • 515 Answers
Hi Marty,
Make sure the magnet in the water tank flow up when you fill the water tank with water.
Posted on Aug 07, 2008
  • Mirko Blas
    Mirko Blas Aug 07, 2008
    Nice to know your machine is working again:-)
    Have a nice day
    /Mirran
SOURCE:
The water light comes on and stops the machine from working even if water is full
There's a float (with a small magnet) in the watertank. This float should go up when the tank is filled with water.
So the float can be stuck in the bottom position, or the sensor doesn't work.
You can test the sensor.
  • Take the left cover off: two screws on the back, slide the cover backwards, then lift the bottom up and pull the toppart out downwards.
  • On the main board there's a plug right at the top, that's the cable from the watertank-sensor. With the watertank removed it shouldn't conduct.
  • Now fill the watertank, check whether the float is going up, put the tank back in the machine.
  • The sensor switch should be conducting now. It it is, then the problem is in the control board.
Hope this helps!
May 28, 2015 | DeLonghi Esclusivo Magnifica ESAM3300...
Our Comfort machine won't brew and constantly displays, "Fill Watertank" even with the tank full. In order to brew, one has to remove the water tank then gently lower it only partially down in place. As...
Hi
The magnet in the water tanks is either upside down or has sunk to the bottom of the tank. It should float to the top of the cage it is in and it should have a flat top not rounded. If its rounded side up the magnet is upside down. This is what would cause your problem.
Sep 22, 2010 | Saeco Magic Comfort Plus Espresso Machine
My Excle file password i forget how can i open?
http://www.freewordexcelpassword.com/
www.petri.co.il/excel-password-recovery.htm
Those are password removalhow to sites
May 09, 2010 | Saeco Royal Exclusive 30153 Espresso...
Screen says 'Fill Watertank' when watertank is clearly full.
Sounds like the sensor that detects system water levels has failed.
If you can see it inside try cleaning it or ask Miele for some advice via their website
Apr 14, 2010 | Miele CVA615 Espresso Machine
I have a saeco royal exclusive and the messages are in french. now it says on the display "retrater purger" and it doe not work any more
Hi
Push and hold the menu button. When it changes in the window, use the up or down arrow button until you come to a window that has something like "lingua, or spreka", and then push the menu button again. Use the up arrow to scroll to "English". When you have the astric(*) in front of English push the menu button again. You have selected English and then you can push the escape button to exit. Some machines have exit in the scroll bar, so it depends on your machine.
Oct 22, 2009 | Saeco Royal Exclusive 30153 Espresso...
I have an Incanto s class de luxe and it is telling me to fill the watertank and it is already full?I have turned it off and back on, and it is still not registering that the watertank is full?
Hi
There should be a grey cylinder in the bottom of the water tank that will rise and fall with the level of the water. When the tank gets low the cylinder will sink and the water light will come on. If the cylinder is missing the light will come on also. If the magnet in the cylinder is bad the light will come on. Some time it takes replacing the water tank.
Aug 18, 2009 | Saeco Coffee Makers & Espresso Machines
Coffee is just water
you have to put ground coffee beans in, too
Jun 22, 2009 | Saeco Royal Exclusive 30153 Espresso...
When i turn the machine on the screen says fill watertank. ventilate. the tank is full. i replaced the water level sensor. it still doesn't work. the magnet in the watertank is floating. any other ideas?
gnet goes in the slot. Flat side up. There is a cap that is rectangular in shape that holds the magnet from floating out. We use a tiny drop in the corner of the cap( I mean tiny) in place. That should correct your message.
Jun 04, 2009 | Saeco Vienna Digital Coffee Maker,...
Saeco Royal Exclusive 30153 Espresso Machine Logo
812 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Pierre Laplante
espressofixr
Level 1 Expert
Ray Murphy
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
