Question about Maytag Dryers
There is an odor inside the dryer that is very sweet smelling what could be causing this
  • 958 Answers
Inspect the drum, there could be something there that was stuck in the drum and producing that sweet smell. could be a candy.
tnx 4 using fixya.
drcool
Posted on Aug 07, 2008
Burning smell or smell stuck in the vent?
sweet smell from an electrical appliance is ozone cause fir high voltage discharge ( like the sweet smelling air after a lightning strike
take it in for a proper diagnosis
May 31, 2017 | Microwave Ovens
Hello. When our Rinnai direct vent wall heater lights on it smells of gas. I do not recall smelling this before. It is a sweet smell not a sulfur smell. The filter is clean.
If it's a sweet smell. it's not gas. Gas smells like rotten eggs. There may be something inside the heater that's causing this odor. Remove the cover of the heater and look for some foreign that shouldn't be there. Perhaps, a dead mouse.
Feb 16, 2011 | Rinnai Heating & Cooling
Dryer makes a funny smell in the house and makes the cloths smell a lil funny as well???
I would need to smell the odor but a couple things will cause this. One being built up lint that is smoldering so I would definitely investigate inside for this. Also (more common with gas dryers) is when customers are painting or staining and varnishing in the house. This will give clothes a kerosene type odor. Try to think back to when it started and see if anything was changed in the household routine at that time. Good luck, Eric
Aug 17, 2010 | Amana NDE2330AY Electric Dryer
Heater immediately fogs all windows and there is a sweet odor in the cab of 2003 Buick Rendezvous, defroster works fine, but will not clear the windows after heat is put on
Sounds like a possible heater core failure(hole in it) the smell indicates to me the coolant(anti-freeze) is leaking into the passenger compartment.
Check the carpet in front of the front passenger seat for moisture, this would confirm heater core leak.
Good luck !
Jan 28, 2010 | 2003 Buick Rendezvous
Burning smell during drying cycle, coming from the inside back left grate. The grate appears discolored.
Usually when a gas dryer overheats it's because of a defective cycling thermostat or a clogged vent system. Clean any lint from the internal and external ductwork, and/or replace the cycling thermostat . If you don't clean out the lint trap frequently, your dryer may have small lint fires inside the cabinet. The smell from these fires can leave a strong odor in the clothes drum.
Also, if there are any solvents, paints, lacquers, etc. in use in the house, your dryer may alter and/or amplify the fumes to an odor unlike the natural fumes given by the solvent, paint, etc.
Here's what to do:
  • First, clean all of the lint from the inside cabinet and ductwork of your dryer.
  • Have a qualified appliance repair technician inspect the dryer for damage caused by any lint fire.
  • Move all containers of flammable liquids at least 50 feet away from the dryer. Gas dryers have a large flame when operating properly and can ignite the fumes of any flammable liquid or gas.
  • Then, try to clear the odor, by running a couple of loads of old rags or towels.
Jul 11, 2009 | Whirlpool WGD6200S Gas Dryer
Bad smell inside dryer
that's because it's brand new. See if it goes away in a month. After a load has dried leave the door open for a bit. What does it smell like?
Feb 27, 2009 | Kenmore Dryers
Chemical odor
Hi serena38,
I'm Harvey the Master Plumber.
Your question is: You have a sweet chemical odor in our boat cabin, it leaves a sweet taste in your mouth. You cannot find the source. The fridge does not work. You can smell the odor stronger when the A/C is turned on or when the boat is closed up with the A/C off. Help????
Great, I live on a boat! I can think of two reasons for this. The first and most likly is electrical. Look carefully at the components especially the capaciter, it's on or near the motor. If it is leaking or out gassing, replace it. Wire corrosion can cause a wire to slowly give off fumes. These kinds of problems are common on a boat so look very carefully i.e. testing meter is helpfull here. I've already expirienced this and it sure was hard to find. Less likely is a freon leak. You won't smell the freon itself but if the oil is a little burnt, that can be smelly indeed. You will need a special leak detector for that. Anyway my money is on the electrical.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | Kenmore 53642 / 53644 Side by Side...
you might want to vacum the lint filter and the all the fan blower area some thing in the dryer is dead .
May 10, 2008 | Dryers
Dryer smells hot
hi ,
run a load in fluff no heat and see if the smell develops again, if it does then I would suspect the motor or belt. generally most dryers are serviceable from the rear, the whole back panel usually, make sure you unplug it of course. make sure your not overloading your machine with clothes. It should never be more than half full ever. a slipping belt causes a burnout smell like when a car spins its tires at the races, if thats it you might need a new belt or your idler pulley may need to be bent a little so the belt runs tighter, study it
J
Jan 23, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
