Question about HP Compaq nx6310 Notebook
Unable to delete or fomat hard drive.
Step1
Right-Click on the “My Computer” icon either on your desktop or in the Start Menu and select “Manage.”
A new window titled “Computer Management” comes up. Select “Storage” from the left hand side by clicking it once, then select “Disk Management(local)” from the right side by double-clicking it.
Now in the lower part of the main frame (right side) of the window you should see a nice visual of all your hard drives. Each line is a different drive. Each box on a line (with a colored bar at the top and a size displayed in MB or GB) is a partition on the drive. Partitions are separations of space on a drive. Unless you are doing something specific that requires multiple partitions, you only want one partition per drive.
Step2
First you must delete any existing partitions on the drive you are going to format. Do this by right-clicking on the partition's box and selecting “Delete Partition...” Since you already know that you will be deleting everything on the drive, and have already backed everything up, you can safely say yes to any warning the computer presents you with.
If there are multiple partitions make sure you have saved everything off them since they might each have different drive letters (i.e. “D:” or “F:”). Then repeat the above step for each of them. If you only want to format one partition that is OK and you can continue to the next step without deleting the other partitions.
The box for the drive to be formatted should now have a black bar at the top of it and should say “Unallocated” under its size (see picture). Right click on it and select “New Partition...” The New Partition Wizard comes up.
Step3
In the New Partition Wizard click next. On the next page make sure “Primary Partition” is selected and click next. Now make the size equal to the maximum (it should already be set to it), and click next again. On the next page the computer will automatically choose the first available drive letter for the new drive. However, if you like you can choose another drive letter from the drop-down menu, and then click next.
Finally the New Partition Wizard asks if you would like to format the new partition and if so what format. Choose “NTFS” as it is faster and more secure. Leave the “Allocation unit size” as “Default.” In the “Volume label” field enter whatever name you want the drive to have. Simple is better. Avoid using spaces. Lastly, if the drive is brand new and has never been used before check the “Perform a quick format” box. If the drive has been used before leave this box unchecked. Leave the “Enable file and folder compression” box unchecked and click next. Then on the next page click finish.
The wizard will now spend a little while formatting the drive. On old or large drives this may take a while. Do not close the “Computer Management” window until it finishes. You will know it is done when the word under the size of the drive changes from “Formatting” to “Healthy” and the name and drive letter you chose for the new drive show up. After it is finished you can proceed to use your newly formatted drive.
This is one of the few steps that i followed from the internet on eHOW.com but in vain. I still unable to delete or format my hard drive due to corrupt & infected hard drive so help me.
  • Richard Finch May 11, 2010
    Which drive or partition are you trying to format?
    Genius:
  • 1,124 Answers
1) You cannot format the OS partition using Windows “Computer Management”
2) If you are trying to format another partition or another Drive in your computer and you can not do that thru “Computer Management”, then you can format your drive using a Windows Cd or any Partition Utility tool. (Using that you also can format your main (OS) partition)
Posted on Nov 19, 2008
External hard drive cant format into ntfs but only exfat
The propriety NTFS file format is used by the Windows operating system to format internal as well as external hard drives. You can format an external hard drive with the NTFS format using the built-in program included with the Windows operating system. The procedure is straightforward and does not require any additional software. An NTFS-formatted external hard drive can then be used with any PC running a version of Windows that is later than Windows 3.
Plug the cable attached to the external hard drive into a USB port on the PC. Right-click on the "My Computer" icon on the desktop. Select "Manage" from the drop-down menu. Click on "Device Manager" in the left column of the window that appears. Click on the "+" icon next to "Disk drives" that is in the column to the right of "Device Manager." Right-click on the icon of the external hard drive. Select "Properties" from the pop-up window. Click the "Polices" tab at the top of the window that has replaced the pop-up window. Click the "Optimize for performance" button below "Policies." Click "OK" to close the window. Right-click on the icon of the external hard drive in the center column of the window that is still open. Select "Format" from the pop-up menu. Select "NTFS from the "File system" drop-down menu in the new window that appears. Click the "Start" button at the bottom of the window. Wait as a progress bar appears at the bottom of the window and fills in from left to right. Click the red "X" at the right corner of the window once the progress bar has completely filled in. format usb memory stick to ntfs http://www.online-tech-tips.com/computer-tips/format-usb-ntfs/
Overview and history of ntfs format http://www.pcguide.com/ref/hdd/file/ntfs/over-c.html
Apr 02, 2013 | Maxtor OneTouch III Mini Edition 120GB...
How fix it:''windows was unable to complete the format''
You have to be the computers administrator to change any values on any hard drive on your computer
click start control panel user accounts on the users tab click the name of the computer administrator you must have full control
click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
click start click on my computer you should see your usb drive
right click then select format
another way is to control panel administrative tools computer management disk management right click on your drive select format
hope this helps
Nov 08, 2012 | Computers & Internet
Can't access files on hatachi xl1000
right-click on the 'my computer'-icon on your desktop and choose manage from the menu. on the left side of the subsequent window, click on device manager and try to find your hitachi xl1000. when found, select it and delete it. afterwards, reboot your computer and let windows deal with installing it as a new device.
Dec 27, 2011 | Computers & Internet
I have 250gb WD external HDD , but after connect while initial it gives "the media is write protected" i am unable to access partitions
Right click on your My Computer icon and select Manage,
Now click on Disk Management.
Here you can see your Hard Disc partition.
Write click on any drive and format it. It will remove your write protection.
But Make sure it will delete all data on that partition.
May 11, 2011 | Western Digital (WD3200JS) 320 GB Hard...
Cant delete all the songs on my mp3 player its a siren 3.8 gb . i want to start it over, can delete some on windowes media player, but cant get the rest off, S/N 22600600029104 this number is where the...
Connect to computer.
Right Click on my computer. Select Manage.
Select Disk Management.
Right click on the Mp3 Player.
Select Format.
Format the Drive.
Once you complete the format process,
Disconnect mp3 player.
Reconnect player.
You can now add all the new songs you want.
Feb 28, 2011 | Audio Players & Recorders
Internet explorer is not visible on desktop
Find a Missing Internet Explorer Icon in Windows XP
  • Step 1 Click the "Start" button. Click on "All Programs." Look for an icon called "Internet Explorer." Right-click the icon. Select "Copy" from the menu.
  • Step 2 Find a blank space on your Desktop and right-click on it. Select "Paste" from the menu. You should see a new icon called "Internet Explorer." Double-click it to make sure that it works.
  • Step 3 Open "My Computer" on your Desktop if you were unable to find the Internet Explorer icon in "All Programs." Double-click the "C:" drive. Double-click "Program Files." Open the folder named "Internet Explorer."
  • Step 4 Select the "iexplore.exe" icon and right-click on it. Choose "Create Shortcut" from the menu. Scroll down to the bottom of the window. Right-click the "Shortcut to iexplore.exe" icon. Click "Copy."
  • Step 5 Paste the icon to your Desktop. Open it to make sure it works.
  • Step 6 Click the "Start" button and select "Search" from the menu if you are unable to find the "iexplore.exe" icon in your Program Files folder. Search for "iexplore.exe." Locate the file. Right-click it to create a shortcut. Paste the shortcut to your Desktop.
  • Find a Missing Internet Explorer Icon in Windows Vista
  • Step 1 Click the "Start" button. Select "Run." In the "Run command" box, type "regedit.exe."
  • Step 2 Look for the key ""HKEY_CURRENT_USER." Click twice to open it.
  • Step 3 Navigate to "Software" and open it. Open "Microsoft," "Windows," "CurrentVersion," "Explorer," "HideDesktopIcons" and "NewStartPanel."
  • Step 4 Open the "{871C5380-42A0-1069-A2EA-08002B30309D}" key on the right side of the screen. Change the value to "0" to show the icon on your Desktop.
  • Jul 14, 2010 | Microsoft Internet Explorer 8
    Turned off raid, unable to access 2nd 160 gig hard
    Right click on Computer in the Start menu. You should see manage.
    click on manage and you will see some selections the left one called disk management. click that and you should see all your drives. If you disable the Raid you may have to initialize the disk for windows to use it again. right click on the drive and initialize or if it shows up you may have to create a partition and then format.
    Mar 08, 2010 | Dell Dimension 3100 PC Desktop
    How do I remove a partition from windows Vista
    depending on what your needs are.
    to delete is go to the control panel then administration tools then computer management then double click on storage then disk management
    it should display all the storage media that's in your computer
    locate the partition down the bottom, right click then delete or format
    then if you want you can expand the existing partition by using the extend volume in the right click menu
    (make sure you back up your data on partition that is goin to be deleted)
    Oct 21, 2009 | Computers & Internet
    Window is unable to format my pen drive.
    first insert your pendrive.Now right click on my computer.Go to manage option . select disk management. From that you must select your drive letter for your pen drive.Go to Action menu near to File menu.Fromthat select all tasks and select formatting.Then again goto all tasks and select change drive letter and paths.select the drive letter and your problem is solved. thanks for asking your problem.
    Nov 06, 2008 | Kingston Technologies 512MB DataTraveler I...
    Acomdata external hard drive
    No ned to check in that.
    The external hard drive can be fomatted by :
    Open the my computer, in the my computer or explorer window you should see the drive letter for the external drive.
    Right click on the drive you will get the popup menu.
    In that select the format option.
    But always use NTFS file formatting system.NTFS provides several advantages over FAT32, including support for larger ile sizes.
    Use the full format option.
    Wait for sometime, until the format is completed.
    Then you are good to go.
    Good Luck.
    Live, Love, Laugh.
    May 08, 2008 | Acomdata 250GB External Firewire HD 250 GB...
    HP Compaq nx6310 Notebook Logo
    102 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
