Question about Toshiba TP50G60 50" Rear Projection Television
Toshiba TP50G60 Convergence Problem ??
I have a 50" Toshiba Theaterview (TP50G60) with the following problem. After turning on the tv set for several minutes (15-20 minutes), I seem to have a convergence problem. The image will be unfocused with greenish outlines. If I turn off and back on, the problem goes away. The same thing will happen a few minutes later. In some cases, I can go several more minutes without it recurring. Almost as if this happens when the set heats up. Has anyone experience the same problem? Thanks gain I have a Toshiba TP50G60 Rear Projection TV I moved it the night before and now the convergence is off. I can move the Red with the Remote but the Blue will not move up or down only left to right. Could it be that something is loose in the back ? If so how do I fix it ?
    Brigadier General:
  • 3,614 Answers
It was on the video output module, check bad resistor near the video output module..
let me know
Posted on Aug 07, 2008
Have an older Toshiba theaterview TV, when turn on, we have no picture, no sound, just black screen and blinking red light that just continuously blinks.
Theaterview suggests a rear projection--in that case it most likely is in the convergence circuit--unsolder chips (convergence) and see if set turns on.
Some of their regular TV sets (picture tube) if the light is just blinking means the same thing=shutdown because of a short/problem but a model number would tell me which you have.
May 23, 2012 | Toshiba Televison & Video
My Toshiba 50 inch projection screen TV isnt displaying
If you are capable of some basic troubleshooting you can determine what's wrong but you won't likely be able to fix it yourself. If you remove the TV's back panel, you can locate three plug connectors for the convergence correction yokes. You pull the red, blue, and green connectors and then plug the TV back in and hit the power button. If the TV comes on, its a failure of the convergence output ICs and will cost $350-450 if you call in a service company.
michtech
Feb 14, 2009 | Toshiba TP50G60 50" Rear Projection...
Blue doesn't work
replaced the blue crt drive pcb or the large transistor on the crt driver pcb.
Jan 08, 2009 | Toshiba TP50G60 50" Rear Projection...
Toshiba TP50G60 Big Black Square Covering the screen?
try the closed caption adjustments. i had a tv that did the same thing and the captiong did it. turn caption off nd try.
Oct 09, 2008 | Toshiba TP50G60 50" Rear Projection...
Picture goes out when floor jars the TV.
Check for bad solder connections around where the tuner attaches to the chassis. Look for cracks with a magnifying glass solder should appear shiny with no circular cracks.
Feb 09, 2008 | Toshiba TP50G60 50" Rear Projection...
TP50G60 bad scrambled picture - shuts off after 1 minute
This does not sound to me like a convergence roblem. It could be a shorted picture tube. That would put the set in a shutdown condition. Normally in Toshibas , the picture remains on with a convergence problem. Here is something you can try, but you must be very careful. Remove one crt board at a time from all three tubes. if the set stays on after one of the crt board are removed , then that is the shorted picture tube.I cannot caution you on how care full you have to be trying this procedure. Scrivitron
Jun 29, 2007 | Toshiba TP50G60 50" Rear Projection...
Televison & Video Logo
283 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
