Question about Hoover Fusion Plus Cyclonic Upright Vacuum Vacuum
HOW DO I EMPTY THE DIRT CUP? Just borrowed this vacuum from my mom for my new apartment and can NOT for the life of me, get the dirt cup to come out! I pressed the release button on the top (the bigger of the green buttons) which i was guessing is the release, but nothing happens, cant even get the darn clear part to move AT ALL....PLEASE HELP!!!!!!! (hoover plus! Fusion)
2 Suggested Answers
SOURCE: Hoover Mach 3 (Fusion): Dirt Will not enter dirt cup
The dirt in my vacuum keeps getting stuck into the hose and dosent reach the chamber, its a constant problem even if i clean out the clog!!
Posted on Sep 02, 2009
How do you empty it?
http://www.homedepot.com/catalog/pdfimages/e1/e1548aa7-3a91-42bc-b2c0-1b405ef54686.pdf
This owners manual shows you how to empty. If you dont have access to Internet:
1. Depress the dirt cup release button and pull nozzle away from unit.
2. Hold nozzle over a wastebasket, Grasp filter and gently pull out.
3. Shake excess dirt and debris out of dirt cup. Brush the dust and dirt off the filter or shake inside the wastebasket. IMPORTANT do not wash filter.
4. Gently push the filter back into the dirt cup.
5. To reattach dirt cup: Align bottom first and rotate nozzle up until it snaps into place.
Good luck.
Apr 20, 2016 | Dirt Devil Red Versa Power Stick Vac
WHY IS IT SO HARD TO ASSEMBLE THE DIRT CUP INTO THE VACUUM
Good seal between the cups ensures that the vacuum cleaner has full suction. Check that there is no dirt or damage on the lip of the filter cup causing it to be jam up and be hard to assemble.,
Apr 08, 2015 | Hoover U5180-900 Vacuum
How do i clean canister of dirt devil featherlight bagless caniter vacuum
Hi there! To clean the canister or dirt cup, first remove the dirt cup from the vacuum. Twist off the dirt cup lid. Remove the pleated filter and empty the dirt cup. Tap the filter against the trash can until the dirt stops falling. If the filter is really dirty it may need to be replaced. The filter should be replaced every 6 months. I have included a link where you may go to purchase a replacement filter if needed.
Thanks! Hope this helps!
F1 HEPA Filter
May 18, 2014 | Dirt Devil Featherlite Bagless Vacuum...
Bissell powertrak revolution dirt not going into cup
If the unit is not blocked between pickup and filter have a good look at the filter to see if air is passing through it---paper throwaway or foam filter the can be washed?
The ones that can be washed etc will have instructions right on them.
Nov 02, 2012 | Bissell 6591 Power Trak Revolution Bagless...
Can not get the dirt cup off of my eureka altima 2993
I have a similar model but I believe the solution would be the same. My dirt cup wasn't coming out after turning the lever so I wedged a butter knife between the clear dirt cup and the grey plate under it and pried the two apart. With the knife pushed in between the two pieces came apart easily. Now the cup slides out with no problem. _395.jpg
Dec 30, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
I can not get the dirt cup out to empty it.
Just slide the dark gray release tab, located just below the cup, all the way to open position, and then pull the Easy Empty Cup toward you.
Jul 10, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
There is a black clip at the top of the dirt cup which holds the dirt cup in place on this vacuum. Pull back on this clip with one hand and with the other you will be able to remove the entire dirt cup assembly. Once the dirt cup assembly is off remove the lid, and take the bottom portion to the trash can and dump. Tap the side of the cup slightly to remove excess dirt. Romove the dirt cup filter inside and do the same. Replace the fiter and the lid and put it back on to the machine. You should replace the dirt cup filter every 6 months to a year. Part is below:
F1 Dirt Devil Replacement HEPA Filter Style F1, Dirt Devil Part 3-JC0280-000 Cost $ 15.95
Apr 27, 2010 | Dirt Devil Featherlite Bagless Vacuum...
Bissell easyvac filters
Replace Filter
As you vacuum, dirt and debris are deposited in the Dirt Cup
while air passes through the filter before being returned to
the room. This process enhances the vacuum path while
dramatically reducing dust, dirt, and potential allergens from
the air you breathe. Replacing the filter periodically enhances
vacuum power and air quality. To replace the filter:
1. Remove the Dirt Cup.
2. Grasp the filter frame and pull it straight from the Cup.
Empty the Cup.
3. Replace the filter. Push new filter into place at the top of the
Cup, place the small tab at the bottom of the Cup into the
slot at the bottom of the Canister cavity, then press the upper
portion of the Cup into place until the lock button snaps
into place. Use only BISSELL Style 6, #32047 Filters
[package of 2] in your BISSELL EASY VAC™ Model 3101-0.
4. EASY VAC™PLUS Model #3102-0 features a high efficiency
3M Filtrete™ Filter. To keep your cleaner operating at peak
efficiency and to remove irritating allergens from your
home, you should change the FILTRETE™ filter every six
months. Use only BISSELL Style 6, #32046 Filters [package
of 2]. The cup-shaped filter lifts out from the top of the
Dirt Cup, and the new one fits into place.
You may purchase these filters
by calling
BISSELL Consumer Services
1-800-237-7691
Monday - Friday 8 a.m. — 7 p.m. EST
Saturday 9 a.m. — 2 p.m. EST
or from the BISSELL website —
http://www.bissell.com
Jun 29, 2009 | Bissell 3102-0 EasyVac Upright Vacuum
I have acquired an old Regina Electrik Broom
Hi jmathe, Looking at the back (business side) of the vacumn: Underneath the white plastic dirt cup, please find a cast aluminum latch, that secures the part you will empty. To remove the white plastic part, turn the aluminum latch handle downward, and to your right, while you are holding on to the dirt cup with your left hand. I usually wear a dust mask, and empty the dirt into a small grocery bag, to tie shut, before placing it in the trash. To replace the dirt cup, turn the cast aluminum handle back to where it was before, handle pointing left. The more often you empty the cup, the longer your Regina Electrik Broom will last. Mine is forty-five years old. Allow the motor to cool, often, as well.
Jan 07, 2009 | Regina ElectrikBroom RG100 Vacuum
Hoover Fusion Plus Cyclonic Upright Vacuum Vacuum Logo
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
