Question about Brinkmann Grilling
How do i install the rotisserie on my grill..it is a pro series 8534...there are no pre-drilled holes and there is no way of closing the lid on the pit while it is cooking,,there is a slot cut out on the left hand side of the pit lid ,but not on the right side....plus the brackets that came with the rotisserie are not offset to clear the lid...
    New Friend:
  • 72 Answers
Buy the Brinkmann Universal Rotisserie Kit model #812-7102-S for $49.95. It uses 2 screws to attach a bracket to the existing tapped holes in the grill. It was that easy! I purchased my grill and the Rotisserie at Home Depot.
Posted on Dec 02, 2017
SOURCE: Lost manual/instructions for rotisserie Brinkmann Pro Series 4435
http://www.brinkmann.net/Customer%20Service/OwnersManuals.aspx
Posted on May 21, 2009
TheMobilian
  • 8220 Answers
SOURCE: Keg-a-que flame cuts out when I close the lid
Must be some sort of air shutter on that puppy to alow for proper air to gas mix. Knock a few holes in that puppy. Where it the stack? I don't see it in the pic.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jun 06, 2009
SOURCE: Jenn Air 720-0061-LP Gas Grill Rotisserie Problem
Hi all ,
I just bought a jenn air 720-0336 gas grill from bj's . the rear rotisserie burner would stop working after a few minutes .
hear is the deal , the rear inferred burner gets to HOT . they did not put any insulation between the ceramic blocks and the metal bezel.My fix was to remove the unit , drill out the 8 rivets holding the bezel on , carfully remove the bezel and install a fire proof gasket , i was abile to find the proper stuff at my local coal / wood stove retailer.it comes in a white sheet about 1/8 inch thick .
use steel rivets to reassemble . good luck . this took a week of trial and error to figure out .
Posted on Mar 30, 2010
  • 4736 Answers
SOURCE: I have a stainless steel grill. The Rotisserie
The ignitor wire to the burners my have come loose or has lost full contact. Trace the wiring from the Ignitor Button to the main burners. Note if it loose or has come completely off. Also, check inside the grill at each burner to see if the ingnitors are covered with grease. If that's the case, clean them with alcohol and either a rag or a cotton ball. If all this fails to solve your problem, change the battery in the Ignitor Button with a brand new Alkaline type battery.
Hope this helps solve your problem. Happy Grilling!
Posted on Feb 12, 2011
  • 411 Answers
SOURCE: I have a ducane grill
Low and slow is always best for smoking.
Posted on Jun 25, 2011
How do i assemble the rotissery
Not sure what kind you have but most of the gas grills now have a slot for the rod and bolt holes to hold the motor to the grill if not the motor can swing back and forth and the weight will pretty much keep it in place ,but like I said they usually have bolt holes . They aren't set up for smokers though ,you'd have to rig it up by yourself if you are handy with a drill lol
Mar 10, 2015 | Ducane Grilling
What model rotisserie will fit a Weber Silver B 250000 model gas grill
You need the Genesis E/S-series rotisserie. It is part # 7519 and can be located at the page below:
Genesis E/S series Rotisserie
Sep 14, 2011 | Weber Genesis Silver B Grill
When using rotissery should main burner also be on?
NO, the grill will overheat with the lid closed. Besides, you will probably have to remove the cooking grates under the rotisserie , because a disposable drip pan should be placed under whatever your cooking.
Hope this helps and thanks for choosing FixYa.
Jul 29, 2011 | Ducane 30400040 Stainless Steel Grill
I just bought the Brinkman, and I am trying to figure out how to use the Rosterria. Can you help me?
Since a Rotisserie is an optional item for your model grill. I assume you have purchased one that is approved to be used on your model Brinkmann Grill Smoker. If not, I recommend that you Do Not use it. If it was approved, read and follow the directions that came with it regarding installation, setup and preparing to use the rotisserie.
The Rotisserie can only be used when you are not grilling anything else on the grill. Remove the grill grates directly in front of the rear infrared Rotisserie Burner. If you Don't, they will be in the way. In their place, you are going to use an aluminum pan (like a pie pan), as a drip pan for whatever you're cooking on the Rotisserie.Place that on top of the burner's flame tamers. Make sure the rotisserie motor is in place and you have electric power to it. Test the rotisserie spit, by inserting it into the motor's spit holder. If you have a Counter Balance, attach that near handle on the spit shaft just below the handle. If your rotisserie is missing the counter balance, you can not use the rotisserie.
Remove the rotisserie spit and place whatever you're planning to cook on it, following the directions that came with rotisserie kit. Make sure the spit forks are tightly embedded in the meat, whole chicken, etc. If a whole chicken, tie the legs together like a Thanksgiving Turkey around the spit..
Light the Rotisserie Burner and close the hood of the grill. Allow the temperature to reach a minimum of 250 degrees F, before opening the hood and installing the food loaded rotisserie spit.
Be careful, as the interior of the grill will be hot. Install the spit as you did earlier. Make sure it fits into both sides of the grill's hood correctly.
Turn the Rotisserie Motor ON and watch as the food turns. If it turns and then sort of bumps, when the spit turns around, adjust the counter balance to stop this. It should turn smoothly. Once all tha is completed, close the hood and allow the food to cook for whatever time, you would cook it in a kitchen oven. Rotisserie cooking is like smoking food. It's a low (temp) and slow (time) process. But, the flavor rewards are GREAT. Only check the food occasionally. The more you open the hood to peek, the longer it will take to cook. Each time you peek, add 10 minutes to the cooking time.
All of this, was sort of a thumbnail sketch of rotissering food. Search the web for recipes and techniques. You'll be amazed at what's out there.
Hope this helped you. Please let me know and Happy Grilling!!
Jun 22, 2011 | Brinkmann 5 Burner with Smoker 8101750S
I have all new burner element, starter and thermometer,,,because I had a MAJOR fire from deteriorating fire unit Now I used grill to rotisserie a chicken, cleaned everything and when using it to grill...
When you cooked the chicken on the rotisserie, did you remove the cooking grates and place a disposable drip pan on the flame tamers below the chicken? This will prevent the grease from dripping down into the bottom of the grill when you use the rotisserie. The bottom of the unit needs to be kept clean so the grease will run to the drip pan and not get caught in the bottom of the unit. When you are done cooking, if you will close the lid and turn the grill on high for 10 to 15 minutes it will help to burn off any grease build up and prevent fires in the future.
Jun 11, 2011 | Dynasty DBQ-30 (LP) Grill
Which is the right rotisserie for the Brinkman 8534 Gas Grill? Where can I purchase it and how much does it cost?
You can find and purchase the rotisserie on Brinkmann's website. Click on the Accessories tab and then enter the correct model number for you grill.
http://www.brinkmann.net/home.aspx
May 14, 2011 | Grilling
I have a brinkmann 8534 gas grill and i need to know how to put a rotisserie on it
Apr 12, 2011 | Garden
CalFlame 4-burner convection BBQ rear rotisserie burner does not work. Converted to natural gas. There is a spark but gas will not ignite. Held match to burner and it would light but would go out when...
Check the air shutter adjustment on the rotisserie burner. It may be starving for air. Also make sure the burner is properly positioned over the orifice. When it was converted, it may not have been put back into place correctly. Also, it's possible the orifice may have been re-drilled out at the wrong size for natural gas. If you know the rotisserie burner BTU rating, I can look up the correct orifice hole size to check if it's right. Douglas
Sep 12, 2010 | Cal Flame 5-Burner
Hi all ,
Aug 02, 2008 | Grilling
Grilling Logo
327 people viewed this question
Top Brinkmann Grilling Experts
Paul Carew
Douglas Dinnebeil
Douglas Dinnebeil
DocZachary
DocZachary
Are you a Brinkmann Grilling Expert? Answer questions, earn points and help others
