Our printer will not pick up the paper and send it through
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
Clean tires with alcohol, if really smooth then they need to be changed
Posted on Aug 07, 2008
HP Pro 8500 printer will not feed paper keep getting "load paper" error even though paper in tray; found small white "gear" in tray.
If the gear is broken, you most likely need to replace the pick up roller which is extremely hard or almost impossible. You may try to see if the error is really with the broken gear, or you if you just have a dusty roller that picks up paper by checking if the rollers is actually spinning when it is trying to pick up the paper.
To see what the issue is with gear or roller, try the following:
1. Remove the output paper tray and paper from the loading tray.
2. Send a copy job or print job through.
3. have a flashlight to shine light on the pick up roller and se if it spins. Try touching with your hand to be sure.
4. If the roller spins, put some alcohol on a cloth or paper towel and clean the rubber rollers.
5. Wait a few minutes, load paper and try sending copy job again.
If the roller is not spinning, then you have a problem with gears for sure.
http://www.303electroncs.com/
our eBay parts store: 303Electronics eBay Stores
Mar 30, 2017 | HP Officejet Pro 8500 Wireless All-In-One...
How do I get my HP2575 printer to pick up the paper in the paper tray?
Hi jtheiss,
When you send a print or copy to the printer does the pickup tires attempt to pickup the paper?
Apr 12, 2012 | HP Photosmart 2575 All-In-One InkJet...
OfficeJet Pro 8600 will not pick up glossy photo paper from the tray
I tried everything that was suggested on the HP forum but then tried something not reccommended there and it worked. Not only remove tray 2 from the printer properties but force the print to tray 2, when you this it sets the Quality from normal or Best to Custom. Once I done that it worked... Just disabling the tray 2 is not enough.
Mar 26, 2012 | HP OfficeJet Pro K8600 Printer
It sends a message of paper jam but the real problem is that it wont pick up the paper to print it And then send the code 075-134
Most printers have rubber wheels that pick up paper. These sometimes get caked up with paper dust and stop picking up paper. Take a cloth with rubbing alcohol and wipe the wheels. Once they're clean, try printing again.
Apr 22, 2011 | Office Equipment & Supplies
Same problem. Printer runs but wont feed in any
observe if pick up mechanism function as when you send printing job. if yes, may pick up roller already worn out and need replacement.
Jun 02, 2010 | HP Officejet 5510 All-In-One Thermal...
Paper stucked inside
Open the top cover.
Pull out the toner / developer units and look for paper under neath.
In the rear, pull open the access door.
remove the paper tray and look for misfed paper.
Dec 12, 2009 | Kyocera Mita FS-820 Laser Printer
It is sying i have a paper jam but there is no paper in it
There are two types of paper jams:
1) A jammed piece of paper at or near a sensor. Or a shred of paper is stuck under a sensor.
2) A paper feed operation that does not send paper into the printer will get reported as a jam it the paper does not reach a sensor in the time that is allotted to reach the sensor. The printer knows that the page is late and suspects a jam occurred prior to the sensor.
To determine if there is a “Pick” problem in the tray, place a mark (line or scribble) on the top sheet in the paper tray. Send a print operation to the printer. If a jam is reported, check the tray. If the marked page is still in the tray then you know the paper pick failed.
There are dozens of reasons for paper to fail to pick. The simplest fix to try is to remove the paper and fan it to remove any possible static charge causing the paper to stick together.
Don
Dec 12, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Brother HL-2040 Flashing Paper LED
Try send one paper manually, then it will pick up paper from the try automatically.
Feb 06, 2008 | Brother HL-2040 Laser Printer
Paper jam in a Dell 1710
This is a terrible terrible printer. Aside from taking the printer apart it seems like your only option is to pick the paper out bit by bit with needle nose pliers.
Dec 12, 2007 | Dell 1710 Laser Printer
42 people viewed this question
k24674
jasbo
jasbo
