Question about EliteGroup (L7VMM) Motherboard
RE: Won't even start
I found out the issue. The motherboard has blown capacitors on it. I researched the board online and found out that some other people had the same problem.
Thank you for your help,
A. Horton
  • 3,051 Answers
Ouch that hurts well i wish you well hopefully u get a new board and get the computer up soon best regards mike
Posted on Aug 17, 2008
SOURCE:
Msi g41m-p26 won start (no power)
The most likely solution is to replace any Capacitors that have blown in the onboard power circuit. Look for a Capacitor that has got a very bulging top in the region of the power connector.
Dec 05, 2012 | Computers & Internet
Board will not hold time, date.replaced battery 3 times
Hi! I believe that its a capacitor problem. Check the motherboard for blown or corroded capacitors, you will need to replace it. It wont really work properly if the capacitors are faulty.Hope this helps and have a good one!
May 20, 2010 | ASUS MB M3A32-MVPDELUXE/WIFI RETAIL...
Does not boot. Installed defective Power Supply
If you would let me know the booting problem slightly, i hope i can help you in a way or two.. Boot up failure, or file missing or restart problem, please let me know..
Apr 26, 2010 | Intel Desktop Board D845EPIL Motherboard
LG 42PX4MVH PLASMA TV - Sound but no picture.
You need the ysus board. This is a very common problem with LG's. If it is coming up with the fuse removed you are essentially removing the short from the power supply so that it can come up and deliver other voltages for sound and all. Check out encompassparts.com if you are going to try to repair this yourself. Thanks
Oct 24, 2009 | LG 42PX5D 42 in. Plasma HDTV
LG plasma have an amber light when turning on then green then red
After all the research I found out that the IC on the Z board is bad and new board was ordered and replaced. The plasma work fine after that and picture is excellent with the new board. This forum is great, without this I couldn't fix it myself. Thank you.
Sep 30, 2009 | Zenith P42W46X 42 in. Plasma EDTV
Samsung 50" plasma tv with no picture but has sound.
I just had a similar issue with my 46" Samsung LCD and fixed it myself for $5.11! I realize we have different tvs, but I bet it is the same issue ... crapped out capacitors.
I researched the problem online and most places, like samsung's site, referred me to call a repairman and called for the whole control panel or power supply to be replaced for anywhere between $400-$1000. I was like ... "screw that" ... I refuse to put in a fautly part in the place of a faulty part. So I continued to research.
That's when I stumbled on youtube. There are many how to videos on how to tackle this daunting task. I read that the issue was more than likely faulty capacitors and there is a very easy way to tell if it is in fact the capacitors that are blown. instead of having a flat top, faulty capacitors are crowned or even ruptured! When I opened up my TV I saw 3 blown capacitors!
So I bought 3 new capacitors all with the same uf and higher volts ... I think all three of my capacitors were 1000 uf and 25 volts. I kept the uf the same (recommended) and raised the voltage to 35 volts. It doesn't mean more volts, it just means it COULD handle more volts if it had to (which was the problem those cheap Samsung bastards screwed up on). This is a very common problem with Samsung TVs.
Anyway, I have never soldered before, but I did it. I warmed up the solder on the bad capacitors and removed them them slid thenew ones in and soldered them in and popped everything back together ... and PRESTO .... the damn thing works better than ever!
3 capacitors= $5.11
1 solder gun and solder= about $18
fixing an incredibly intimidating TV by yourself= PRICELESS!
Seriously ... don't be afraid to F up ... check it out on youtube and other place and save yourself a bundle. Source(s): I just fixed my TV!!!!!!!!
Jul 24, 2009 | Samsung 50 in. Plasma TV
Need to learn to take capacitors off the circuit board
Very carefully as we discussed in our expert forums this takes skill and it takes the right equipment as you can burn the thrid layer board and you will be without a TV. First you need a 40 watt iron, 60/40 rson core solder/you need wicking wire/ heat sink and a whole lot of experience. check this website www.badcaps.com even know he works on motherboards for computers this guy gives you tips I would follow them and heed to them if I where you!! Good luck with your repair!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 24, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Tops blown off
This isn't going to solve your issue, but my opinion is that if even if your computer is still running it is still an issue that they should look at especially if the board is still under warranty. I wouldn't say a thing about the computer still being able to run, especially if they will warranty it.
I have seen capacitors burn up, but not the tops blowing off. Even though the board is still working you may have a feature of some sort out, such as you onboard video or something. I almost bet that something is still wrong, and it would be a matter of time before you have more issues.
Oct 04, 2008 | Jetway 939GT4-SLI-G Motherboard
Power up
Dear Kresten,
it looks like the problem with either your motherboard or SMPS. So, it is advisable to find a repairman in your
area. You can get the repairman in fixya itself.
thanks,
Sep 22, 2008 | Asrock P4I45GV R5 Motherboard
Won't even start.. 0.o! (Reply)
Please mark me as FixYa! even if your mobo is DOA .
Thank you Horton
Aug 06, 2008 | EliteGroup L7VMM2 Motherboard
EliteGroup (L7VMM) Motherboard Logo
80 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Ekse
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
