Question about Microsoft Xbox 360 Console
What i need to connect xbox 360 to pc
Hi, i want to connect my xbox360 drive to my pc via the sata way, my pc does not have a sata port, i found this on ebay and was wondering if this would solve my problem http://cgi.ebay.co.uk/3-Port-SATA-PCI-Card-IDE-VIA-VT6421A-For-Xbox360-Pc_W0QQitemZ270263000870QQcmdZViewItem?hash=item270263000870&_trkparms=72%3A12%7C39%3A1%7C66%3A2%7C65%3A12&_trksid=p3286.c0.m14.l1318
cheers in advance
  • haggis0073 Aug 07, 2008
    my drive is a Hitachi 59dj GDR-3120L, does that mean it will not do
  • 37 Answers
The VIA VT6421A chipset is the exact chipset you need to connect your 360 to PC, so yes that card will work perfectly.
Keep in mind if your thinking of flashing your dvd drive, I think this chipset designed to only work with the TS-H943 and Phillips model.
Posted on Aug 07, 2008
  • Folro
    Folro Aug 07, 2008
    I'm unsure, i've only dealt with the TS-H943 models. However I hear 360mods.net has good tutorials and video guides that should hopefully help you better than I can.
    The only thing I could fine on my own was you definitely need a X360 USB with Connectivity Kit v2 to flash Hitachi drives.
Tip
How to resolve Xbox 360 disc read errors. Xbox will not play disc.
Is your xbox360 having trouble reading disc? In this guide I will provide some common solutions to help you fix your disc read issues.
1)Remove any memory devices or usb flash drives.
2)If the disc you are using is excessively scratched, this can cause the xbox to have trouble reading the disc. You can use a damp soft cloth to try and clean the disc. Grab the disc by the edges and using a soft damp cloth lightly wipe the disc from the center going outward.
3)Try removing your Xbox hard drive and then play a disc. Turn off the console. Locate the hard drive on the top of your system(depending on how you have it positioned). Press the release button on the hard drive.
If your system can read disc without the hard drive attached then you may need to replace the drive.
4)Clear the Xbox360 cache. Clearing the cache may remove updates to certain games. Keep this in mind.
Go to System Settings in the My Xbox menu. Select Memory, highlight your storage device and select Clear System Cache. Try and play the disc.
If after the above steps you are still having trouble. You may want to contact Microsoft Xbox live support to have your system serviced. You can find the support information in the link below,
Xbox Support
Regards,
G33k
Visit the links below for other technical articles
Connect your Nintendo Wii to the internet
Connect your Xbox 370 to the internet
Connect your Nintendo DSi to the internet
Connect your PlayStation 3 to the internet
How to access Windows 7 God Mode
Tips to clean and speed up your computer
How to configure a wired/wireless home connection
How to access facebook when it is blocked at school
Extensive list of device driver links for common electronic devices
Keywords
xbox 360 disc read errors, xbox 360 disc read, 360 disc read errors, xbox disc read issues, xbox 360 disc read issue, xbox 360 scratched disc, xbox360 disc not playing, xbox360 cant play disc, xbox360 disc will not play
on May 14, 2011 | Microsoft Xbox 360 Console
How can I flash my xbox 360? it wont recognize the new dvd rom drive.
Disconnect all cables from the Xbox 360 and remove the faceplate from the front of the console. Lift the plastic tabs on the outer shell and remove the plastic casing from the machine. Unscrew the Torx size 7 screws and lift open the metal cover. Unplug both the power and SATA cables from the rear of the DVD drive and lift it out of the console. Replace it with the new DVD drive, and connect the power cable to the unit. Connect your SATA cable to the DVD drive and a free SATA port on your computer.Turn on your computer and open a web browser. Download JungleFlasher and run the program. As of September 2010, JungleFlasher is the most stable and up-to-date flashing program for Xbox 360, and it is also the only program capable of flashing Xbox 360 drives from within Windows (earlier programs used MS-DOS). Click "Flash .BIN to DVD" in the program's main menu and select your Xbox 360's DVD drive. The program will flash the new DVD drive for use with your Xbox 360 console.Turn off the computer once the flashing process is complete and disconnect your SATA cable from the DVD drive and your PC. Reconnect the Xbox 360 SATA cable to the new DVD drive, then close the metal cover on the console. Rescrew the Torx size 7 screws and replace the outer plastic shell on the Xbox 360. Return the faceplate to its original position then reconnect all external cables and accessories to the console. Power on the Xbox 360 and the replacement DVD drive will function normally.
Feb 27, 2011 | Video Game Consoles & Games
How can you hook up to a lap top and do I have to buy anything
all you need is a router with more than one port plug them both in and goto your xbox settings and click connect to computer
Mar 10, 2010 | Sega The Club - Xbox360 for XBox 360
Xbox to pc connection
how do u connect the ethernet to ur lap top or do u have a wireless adapter?
Jan 14, 2009 | Microsoft Xbox 360 Controller
My wireless XBOX 360 says ''not connected'' when I test XBOX LIVE
hi,
in this case you need to do a port forwarding,which is something like opening the specific ports on router so that xbox will communicate with internet
for that we need to know the ip address of xbox and port numbers for xbox.contact microsoft for knowing the port numbers and their range,so we can do a port forwarding on your router
Dec 29, 2008 | Linksys WRT160N Wireless Router
Maxtor hard drive xbox 360
The maxtor hard drives will work with an Xbox360 but in only one case, your xbox hard drive is linked to work only with your console and if you swapped hard drives the xbox wouldn't read it so to answer this you need to reset your Xbox 360 copy protection serial number i.e. Flashing your Xbox or Chipping it, once your Xbox is Flashed or Chipped you can use a maxtor hard drive through the SATA cable port in your Xbox
Oct 13, 2008 | Maxtor Hard Drive
Xbox 360 wireless adapter not connecting 2 pc
u need a wireless router linsky is about the best out there
Sep 20, 2008 | Microsoft Wireless Network Adapter Xbox...
Conection inalambric
The XBOX 360 can only be connected via an RJ-45 ethernet wire to the router unless you purchase the wireless adapter. The adapter can be bought at any accessory store such as walmart, Target, Gamestop, etc.
Jul 27, 2008 | Microsoft Xbox 360 Console
to play copied dvd's ( i think thats what you typed ), you will need to do a few things, including taking your xbox apart, and connecting it to your computer. You will also need to flash your dvd drive.
Quick NEED list:
1. SATA Cable
2. SATA Card
3. torx screw driver
4. torx 8 and 10 bits
5. Flash / Pen drive (USB)
To do this, your computer has to have some kind of SATA port. You can buy a SATA card for $25.00 at your local computer hardware store. Also make sure you pick up at least an 18 inch SATA cable. Now once you have both of these, then you will have to take your x-box apart.
Dont know how to take your 360 apart? Click on the link below
http://www.llamma.com/xbox360/repair/Xbox-360-Disassembly.htm
Heres a good tutorial on how you flash your dvd drive too:
http://venomousfire.blogspot.com/2008/02/how-to-flash-benq-xbox-360.html
hope this helps
Feb 10, 2008 | Microsoft Xbox 360 Core System Video Game...
Microsoft Xbox 360 Console Logo
89 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
