Question about Dryers
Kenmore elite sensor smart electric dryer
Will the heating element go bad if you had a 120v going to the unit rather than 220v.
Email. gregory.bowers@pulte.com
  • 770 Answers
Yes the heating element needs 220v to work will it go bad by having 110v ...??No but it will not work for sure but it will tumbler
Posted on Aug 07, 2008
My Kenmore 500 Series electric dryer runs, but no heat. Elements never get warm. All thermal sensors show continuity. When I checked for resistance through the elements, I got infinite ohms. Perhaps I'm...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 10, 2010 | Kenmore Elite HE4 Electric Dryer
HE3 Dryer not heating
check the thermal fuse and also check to make sure you have 220v at the outlet.
Jul 23, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite will run, but won't heat
could be the thermal fuse or the heat element to start with.  also, check to make sure you have 220v at the outlet
Jul 08, 2010 | Kenmore Dryers
Heating element
Jul 08, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE3 electric Dryer Heating coils do not get hot, drum turns, controls work. What can be problem
most probably the thermal fuse or the element itself.  make sure you have 220v at outlet.
Jun 24, 2010 | Kenmore Dryers
I have a Kenmore Elite Model number 110.64992300. The dryer turns on and spins but does not heat. I have the bottom panel off am looking at the heat element. What should I do to test everything? I have a...
You need to make sure you have 220V first all the way to the dryer. Make sure you have no blocks (lint blockage). Check your thermostats for continuity. Make sure all the wires are disconnected when testing. If they show good check your heating element not only with the ohm meter but take it out and visually inspect it. They can be bad and show continutiy.
Jan 07, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer won't heat
The voltage first a unit needs 220v to heat but only 110v to run check for proper voltage at the plug first
Aug 15, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer runs but doesn't heat up when sttings call for heat.
You may need to do some troubleshooting. This can be done with the machine unplugged - you may have to activate the start switch, belt switch (if it has one) and the motor centrifugal switch manually.
Tip for troubleshooting 220v systems - clip one lead of a ohm meter to either L1 or L2 on the terminal block. It doesn't matter which one. According to the tech sheet (under console) follow the path for current from your clipped terminal, through the heating element, to the opposite terminal. All the readings should be less than 100 ohms, until you reach the failed part. Confirm failure by disconnecting a lead from the suspected part, and test only that part.
Live troubleshooting is sometimes slightly easier, but much more dangerous than the procedure described above. - It is definitely not recommended for beginners, or for professionals, if it can be avoided.
Mar 08, 2008 | Kenmore Elite HE4 Electric Dryer
HE 4 Removing Heating Element
post your email i will send you the manual on it.. also post the complete model number from the unit
Jan 12, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
177 people viewed this question
Top Dryers Experts
