Question about Canon PowerShot A460 Digital Camera
Screen problems my screen doesn't trun on to take a picture. i can look at the picture i took, and the screen work when i take videos but not for pictures.??
  • elton_tasha Aug 09, 2008
    im not going to pay ...i'll just take it in ands they can fix it for free
  • Anonymous Mar 08, 2009
    same thing
The LCD screen might be turned off, I accidentaly did this once and all I did was go to menu - set up - reset all and it was fixed.
Posted on Feb 28, 2009
The camera took great pictures then all of a sudden the screen appears as a purple haze -- and the pictures come out as just a purple blurry haze. Adjusting brightness doesn't work. Yet, the shutt
If the LCD displays correctly on previous photos then the problem is more than likely a CCD or associated ribbon connector failure due to moisture/condensation or age/misuse. Good luck with finding a replacement part!
May 31, 2012 | Panasonic Lumix DMC-TZ3 Digital Camera
Engine wont turn over on my gv 2006
The 1st thing i need to do is clarify what you mean by "won't trun over" do you mean the starter motor spins the engine and it will not fire up or that the starter doesn't trun the engine over? If the starter doesn't turn the engine over do you hear a clicking coming from the starter solenoid when this happens? If so replace the starter solenoid the heavy electrical contacts are burned.
Dec 28, 2011 | 2006 Suzuki Grand Vitara
My screen keeps on freezing when i go to the internet to where i have to trun it off in trun it on whats wrong?
PS3 screen keeps freezing means hardware errors and need some maintenance. Do you know, send back to game shop is too expensive and waste your time. Learn the correct repair skills and fix it by yourself is the ultimate method. Here is the repair guide for you to learn :
DIY PS3 Repair Guide
Not only such screen freezing problem, you can repair other red and yellow light related issues as well.After you purchased the product, you will be guided to the step-by-step videos and ebooks for you to work with.
Jul 19, 2010 | Sony Playstation 3 (PS3) Console
When i trun the tv there is no picture nothing
If you have confirmed that the flourescent backing ligh turns on but the screen is black, the could be a problem with the main video board. Either it is not getting power of the video board is bad. When the TV is on make sure all voltages are present in the power supply low voltage section.
Jun 26, 2010 | Sanyo Televison & Video
Sony kv32v26 video flashes off/on/off/on/off/on/ audio is good
you have a bad crt if you open the set on the flyback you see 2button 1screen 1focus
you see the screen trun it up just a littet
you see it will stop but because if you trun it to far it will shut down. and you have line thur it .
just trun it a littet bet. hear what you are doing is trune up the screen livies up. but your crt is going bad. sorry to say that to you .
Jun 02, 2009 | Emerson EWF2004 20" TV
Kodak md853
hi! my sister-in-law gave me a MD853 camera last week from Canada. I used it over the weekend when we went on a trip and the pictures and videos i took were great. Last night, my daughter took a picture of me and when she took a picture of her brother, there was only white on the screen...like a moving white sheet with colored edges. I thought she destroyed it or something. I tried to use it but now the screen is all black...last night only the video worked but this morning everything is black. The other programs in the camera works so i suspect the problem must be in the lens. I'm in the Philippines and if I send it back to Canada for repairs it would just take a long time and it will be expensive to send it back. What can I do? I really love this camera... help!!!
Apr 14, 2008 | Kodak EasyShare C613 Digital Camera
Screen Problems with my Laptop
hi dear
1. That can be connection related problem. I check connection between the video cable and the LCD screen, try reconnecting the video cable. It’s necessary to take apart the display panel, unplug the video cable from the connector on the back side of the LCD screen and then plug it back in. In some cases reseating this connection helps. 2. If reconnecting the video cable doesn’t help, here’s what I do in this case. While the display panel is still disassembled, I turn on the laptop and wait until image appears on the screen. Then I move the video cable a little bit without touching the LCD screen. If moving/touching the video cable affects image on the screen, it’s possible that there is a problem with the cable. Apparently there’s a short somewhere inside the cable. In this case, replacing the video cable may fix the problem.
3. If reconnection the cable doesn’t help and moving/touching the cable doesn’t change image at all and the only way to get better picture is moving/touching the LCD screen itself, apparently there is a problem with the LCD and it has to be replaced.
oke
Posted by Laptop Freak on March 22nd, 2008 Filed in Video Problems, LCD Screen Issues, LCD Displays Lines -->
Mar 24, 2008 | Compaq Presario 700 470024-192 Notebook
Kenwood KNA-DV4100 will not trun????
I had a similar problem, and found that it was due to not having the vehicle speed sensor hooked up to the unit. Once I did that, it started to work again.
Jul 30, 2007 | Kenwood KNA-DV4100 GPS Receiver
Canon PowerShot A460 Digital Camera Logo
65 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
