The proof copy of the Owner's manual includes the specs for the TH-L32EA and is available from:
http://www.panasonic.com.au/Support/Customer+support/Downloads+and+documentation . Enter the model number under keywords and then click search (do not use the drop down menus).
Specifications
Power
Power rating AC 220 - 240 V, 50 / 60 Hz 0.33 A
Normal (Home) mode 42 W
Standby condition 0.2 W
Display
panel
Aspect Ratio 16:9
Visible screen size 80 cm (diagonal)
698 mm (W) × 393 mm (H)
Number of pixels 2,073,600 (1,920 (W) × 1,080 (H))
Sound
Speaker 160 mm × 42 mm × 2, 8 Ohms
Audio Output 20 W (10 W + 10 W )
Headphones M3 (3.5 mm) stereo mini Jack × 1
PC signals
VGA, SVGA, WVGA, XGA
SXGA, WXGA ······ (compressed)
Horizontal scanning frequency 31 - 69 kHz
Vertical scanning frequency 59 - 86 Hz
Receiving Systems /
Band name
PAL B/G Reception of Off air broadcasts
Digital TV 7 MHz VHF / UHF (Australia) free-to-air TV broadcast reception
PAL 60 Hz
M.NTSC
NTSC
Playback of NTSC tape from some PAL Video recorders (VCR)
Playback from M. NTSC Video recorders (VCR)
Playback from NTSC Video recorders (VCR)
Aerial - Rear Standard Belling & Lee connector
Operating Conditions Temperature : 0 °C - 35 °C
Humidity : 20 % - 80 % RH (non-condensing)
Connection Terminals
AV1
Input
AUDIO L - R RCA PIN Type × 2 0.5 V[rms]
VIDEO RCA PIN Type × 1 1.0 V[p-p] (75 Ohms)
COMPONENT Y 1.0 V[p-p] (including synchronisation)
PB/CB, PR/CR ±0.35 V[p-p]
AV2
Input
AV3
Input
Audio
Output AUDIO L - R RCA PIN Type × 2 0.5 V[rms] (high impedance)
Others
HDMI1 - 3
Input TYPE A Connectors • This TV supports "HDAVI control 5" function.
PC Input HIGH-DENSITY D-SUB 15PIN R / G / B: 0.7 V[p-p] (75 Ohms)
HD / VD: TTL Level 2.0 - 5.0 V[p-p] (high impedance)
DIGITAL
AUDIO OUT PCM / Dolby Digital, Fiber optic
Card slot SD Card slot × 1
USB 1/2 USB 2.0 TYPE A Connectors DC 5 V, Max. 500 mA
ETHERNET 10BASE-T / 100BASE-TX
Dimensions (W × H × D) 769 mm × 514 mm × 207 mm (With Pedestal)
769 mm × 480 mm × 75 mm (TV only)
Mass 11.0 k Net (With Pedestal)
9.5 k Net (TV only)
(See page 73 of the manual for the specs as a table - I used Proof 2)
I hope this helps.
