Question about Intel Motherboard
Red light and monitor will not start up
I forgot to say in my last question that when i switch on the computer it does not switch the monitor on ! ....Plus the green light and red light flash a bit periodically ...Then just the red light stays on .......
I put a new Graphics card in incase it was the built in graphics but still the computer will not turn on the monitor.....
I tried the memory card but that did not help....Thankyou
  • Intel Master
  • 3,051 Answers
You need to shut down the computer and pull the power cord off powersupply then remove the wire harness that goes on to the mother board then press the and hold the computer on button for 3 seconds then plug in the the harness back on the mother board and and plug in all power cords then try to turn on the computer it should give u a beep or the monitor should go from orange to green good luck e-mail me if u want [email protected]
Posted on Aug 09, 2008
SOURCE:
Monitor flashes logo and then turns black.with red lights on
Here's some tricks I would try. Something here, might help...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your monitor on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Aug 07, 2014 | LG Flatron Computers & Internet
Dell monitor repair
It matters greatly. If you get it backwards it may blow parts. Always examine things closely when dismantling. Take photos as you go or mark connecters with magic marker etc
Nov 17, 2013 | Computers & Internet
Red light flashes 5times continuously doesn't power on started last night
try unplugging it from the power outlet, hold and press its power on switch for 10 seconds, and test it again. you may also want to try another power outlet.
Aug 08, 2013 | Sony KLV-32BX300 SERIES BRAVIA LCD...
Screen won't turn on
You can try to do the monitor self test.
Monitor Self Test:
1. Physically test the monitor autonomously from the computer.2. Switch both the monitor and the computer off, and then disconnect the VGA cable le from the computer.3. Turn the monitor on, pressing the power button for about three seconds. The self-test screen will come up .4. If the image is clear, bright, and shows red, green, and blue, the monitor is working properly. Video issues may be due to the video resolution in the computer, and not the monitor.5. If the image is not apparent and intense or the colors are not accurate, then the trouble is with the monitor or some of the (OSD) settings. In this case, test your particular monitor's information for OSD.
It is always important to check the color of your power light for so you can distinguish if the monitor is defective. Getting red lights on the the power panel states that the power section of the monitor is faulty.
Dec 03, 2011 | Emerson Televison & Video
When computer is started no signal appear on the monitor.
If your monitor is working fine, my guess is you might forgot to turn on the monitor power switch which is located at the lower right bottom corner. try it
Sep 13, 2009 | Computers & Internet
Power on - blank (black) screen
Disconnect the monitor signal cable from PC and switch on your monitor. It should show some logo with Red, Green and Blue colors with a message similar to "No signal". If so, your monitor is working fine. Sometimes if the brightness and contrast is set to zero using controls present in the monitor, it will not show up anything. check wheather somebody set your monitor brightness and contrast to zero. If so incease them. As a last try connect to different PC and check before approaching a service center. I hope this will help you out. :)
Aug 21, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Power goes off
the power supply section of monitor is get faulty, check it to an expert.
Jul 16, 2009 | Proview PL926WBi 19" LCD Monitor
Monitor comes on for a few seconds then goes blank.
Your looking at profesional repair. It could be DC/DC convertor, Monitor unit or PC/IF unit. (last two are expensive)
Jan 22, 2009 | Sharp LC-M3700P 37 in. HDTV-Ready LCD...
Intel Motherboard Logo
729 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Ekse
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
