Question about Sharp Televison & Video
I recently purchased a flat-screen Sharp TV with a built in DVD. I have tried everything to get audio, but cannot. The bar moves when you press the volume but no sound. I've tried the regular remote for the TV (I have Verizon FIOS), a universal remote and also purchased a SHARP remote-didn't have one because this was purchased at a discount off the floor. Can you help. Thank you. Michele
    Genius:
  • 1,011 Answers
Dear sir/madam,
first - try the volume on the TV itself, just in case the volume buttons on the remote aren't working. Also make sure there are no audio cables plugged into the jacks on the back of the TV.
If your TV has a setup mode (usually found on the remote control), go into the setup and check the audio settings. It's possible that it's set to send the audio to the audio output jacks instead of the speakers. This setup would typically be used in a home theater environment where the sound is sent to an audio system with it's own speakers, and therefore the TV speakers aren't used.
If it is, then change it to speakers instead of "line out" or something similar.
thanks
good luck
Posted on Aug 07, 2008
  • 3,037 Answers
Well, if you just purchased it and are sure that it isn't muted, on SAP, or MONO. Then I would just take it back to where you got it and exchange it for a different one which would be the easiest option. Let me know of anything else that you need or have questions on
good luck
  • Sharp Master
  • 19,396 Answers
First unplug TV power cord for two minutes to reset it.
Try pressing the mute button on the remote, if this does not work try plugging external speakers to test sound and to check if the external audio speakers are working and if a stuck audio jack socket is cause of the problem.
If it still does not work the TV is faulty, in this case see if you can get a refund or a replacement, and check your guaranty terms.
    Scholar:
  • 191 Answers
What i believe is that the audio cable inside the tv is not connected or may have been bad due to this reason you are not getting the real audio but you can see the bar moves when you increase or decrease the volume from the remote control get the unit opened and checked.
    Brigadier General:
  • 3,614 Answers
Just to be sure... did you check if you have set the volume in MUTE mode settings..?
  • micromaster
    micromaster Aug 07, 2008
    also i want to know if you watch on a regular channel, did you hear a sounds.?
What kind of audio system do I need to purchase for this set. The speakers are just terrible.
I changed my audio equalizer setting to "POP" and I got much more pronounced separation. Also, make sure the SURROUND is set to "ON" in your settings or simply hit the SURROUND button on the remote that came with the TV.
The "AUDIO OUT" jacks on this set apparently only work when the input is set to "TV". I wanted to hook a couple of external speakers up as well and found they would not work when hooked up to HDMI to a cable box. I mean how many people by a large flat screen like this if they don't want to view HD? Like about zero! The AUDIO OUT works only when TV is selected for INPUT
A work around is to use the headphone jack and hook a couple of external speakers up to that.
If you want to go for a higher end home theater sound bar system so that you can route both DVD and CABLE box through it via multiple HDMI's you can choose from SONY, Phillips etc.
I wrote to Sharp about the AUDIO OUT issue. It's rediculous that they only work when TV is selected for input. But you might try using the heaphone jack alternative if you find a set of speakers that sound good to you. Hope this helps.
Dec 24, 2010 | Sharp LC42SB48UT 42 in. LCD TV
Sharp 26"hdtv started with a 1/16" color bar that
If you mean the bar goes top to bottom, there are circuitboards that feed the info in small sections top to bottom. But usually one section will be one inch wide. It can also be the screen panel itself. Try a trusted tv shop
Nov 25, 2010 | Sharp LC26DV20U 26 in. LCD HDTV/DVD Combo
I purchased both this television and a Sharp surround bar. So far I have not been able to make the speakers from the surround bar to work. It does not seem to recognize that I have another source for the...
Unfortunately I have to ask where the red and white audio cables are connected on the tv because there is no mention of that in the problem. There is only one place where they should be connected and it is on the top left where it says analog audio out. See page 10 of the manual.
To make sure the sound bar itself is working instead of connecting it to the television connect it to one of your devices like your cable box/satellite tv box or dvd player. It would go right into the red and white output hole on the device.
Jul 08, 2010 | Sharp LC47SB57UT 47 in. TV
No audio, no video but program guide displays
1. You should check you cabling connections at the satellite receiver to the TV.
2. Check the mode you are in on the HDMI cable
3. Your HDMI should have 3 modes in the set up screen (HDMI 1,2,3)
Apr 19, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Flat screen to dvd connection help!
It depends on the TV.
On my Phillips TV this is switchable via the TV setup menu, and you get no sound with HDMI unless you change that setting.
The reason it's switchable is that the HDMI input is usually common with one of the component-video inputs (AV3 on mine). (cost saving move)
Thus if the menu is set to hdmi, then the audio goes thru hdmi. If it's set to 'component' then it goes thru the RCA patch cable.
Oct 07, 2009 | Televison & Video
No Picture
If your TV is a SHARP LC-45GD5U,
Try using the reset buttons on the back of the TV. It should be below your digital audio output port.
If that doesn't work, ( this is only a guess) the power supply for the LCD screen may have burned out.
Feb 15, 2009 | Sharp LC-45GD5U 45 in. LCD Television
Sharp 42" flat screen LCD T.V.
This could be 1 of three things! 1-main lcd panel
2-y sustain module
3-z sustain module
This is something you cannot do yourself my friend.
Feb 22, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Hooking up portable dvd player to sharp aquos tv
Audio and video out from the DVD unit go to the A/V In of the Sharp....Accordianman
Nov 24, 2007 | Sharp Aquos LC-15B4U-s 15 in. EDTV-Ready...
Polaroid HD flat screen TV with DirecTV
I have Polaroid TV Monitor HDMI LCD 15.4" no power light on TV, blank screen, the power adaptor is Ok 12VDC supply. I need suggestion; in any possible problem or parts busted?
Sep 09, 2007 | Televison & Video
Televison & Video Logo
87 people viewed this question
Top Sharp Televison & Video Experts
Dave Naylor
Dave Naylor
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
