Question about HP DeskJet 5652 InkJet Printer
My hp 1315 all in one had paper jam
I removed paper and it still says paper jam
    Novelist:
  • 180 Answers
1. Remove any loose paper
a. remove any loose paper from the In tray and Out tray
b. press the cancel button (x) on the product control panel to clear the paper jam
2. Clear the jam from the back of the printer
a. press the Power button to turn off the product
b. unplug the power cord from the back of the product
c. remove the rear access door. turn the knob one quarter turn to the left, and then pull the door away from the product
d. gently remove the paper
3. Clean the rollers with a lint free cloth that is moist with water
4. Try printing again
Posted on Aug 07, 2008
Printer jammed and paper was removed but now it says paper jam and won't print from a command from the computer
hi go into control panel find printer settings u will have to clear any printing commands in c whats printing........good luck
Sep 04, 2015 | HP PSC 1315 All-In-One InkJet Printer
My hp 1315 check paper is blinking
un clip the back door there might b a jam of paper that u cant see but printer can detect once u have done that u must !! pres enter 2 reset it after u have replaced the rear door of course
Sep 28, 2012 | HP PSC 1315 All-In-One InkJet Printer
I have a 1315. It has a paperjam error the light will not go off. the jam is cleared.
Sometimes clearing a paper jam is more about just pulling out the jammed paper. Here's the HP official solution for how to resolve a paper jam on that printer.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01577197&cc=us&lc=en&dlc=en&product=374568
Sep 14, 2010 | HP PSC 1315 All-In-One InkJet Printer
Hp psc printer paper feed is jammed with an piece of paper.
The small gear located in the paper feed assambly is break or fail, need replacement parts to repair it.
May 22, 2009 | HP PSC 1315 All-In-One InkJet Printer
Hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
my printer no function cant print
Jun 17, 2008 | HP PSC 1315 All-In-One InkJet Printer
Paper jam
ok i dont no if its and hp or what type you did not list sometimes when a paper jam is because the paper is not straight going in and check the back of the printer its a release that removes and there you find were jamed paper is check that try a differt type of paper if not go to the website of the printer and look at the suggestions
Apr 06, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1315 paper jam.
does it turn on or doesnt pick up the paper?
Oct 28, 2007 | HP PSC 1315 All-In-One InkJet Printer
HP DeskJet 5652 InkJet Printer Logo
64 people viewed this question
Ben Johnson
