Question about Alesis Sr 16 Stereo Drum Machine
Problem with lights on the drum machine display.
I have a drum machine which is proberbly about 10 or 15 years old but it has just developed a problem. When I hit the power button, the lights on the display come on for a split second but go off again straight away. I have checked the fuses and the transformer and they seem to be OK but there is no power on the output side of the circuit board. The transformer is a 240V in and 24V output and is center tapped. It has 1 black wire which is the center tap wire and 2 yellow wires which are the 12V power. There is power going into the circuit board at the termination of these wires but not on the output side of the board. Output wires are 1 black ground wire and 4 other wires. The first wire is -8V and has power but the next wire is +8V and has no power as well as the other 2 wires which are 5V and 3V respectively.
Does any one know what the problem may be? Like I said earlier, the fuses are OK and I think it might be either the 2 Capacitors or one of the diodes or resistors, but I am just not too sure.
Thanks in advance.
Ned,
I had the same problem with my SR-16. It was mfg in 1994 which puts it at about the same age as your machine. When I would turn it on the display would flash on for a split second then go off.
The solution was to change the internal lithium cell.
It has three pins that are connected to the cell which are soldered directly to the main circuit card. As soon as I replaced the cell the unit returned to normal operations. The only thing that did not remain was the user patterns that were previously reprogrammed.
I was able to order the battery from Mouser Electronics. Mfg P/N BR2325-1HG. This is not a difficult replacement, but does require some soldering/de-soldering skills to accomplish. Hope this helps.
Echojoe
Posted on Jul 05, 2009
I am dealing with the similar situation on this unit. What I did was this (warning: this can mess up your unit):
You are having a power distribution issue. Something has shorted or opened, and temporarly messed up the software. Open the unit, and without going near any power items on the board (i.e avoid op amps, transformers, capacitors, etc), play around by touching some of the low-voltage contacts between the controller chip, the software chip, and the sound chip. Keep rebooting with the on/off switch, and the software has a built-in hard boot for when it goes out of range and eventually it'll boot up nicely. This is also a way to "bend" this unit - I was getting some great sounds and loops while doing this.
The problem I am now expericencing is that none of the pads work. This is not a result from the above explination, but is the same problem. It pads start working when I start jumping, but I have to start jumping closer to the power sources and I'm scared I'm going to fry the unit.
I like the open resistor concept. Can you please elaborate on how to test for your explination with basic home equipment, musicdude? Should I simply start testing all the resistors to see if they are open? I cannot find a service manual anywhere on the internet, only the user manual. Perhaps I can upload an image with what I've discovered.
Posted on Nov 19, 2008
Sr-16 will not load patterns from cassette player does any one know the problem,,
h, sharp
Posted on Oct 23, 2008
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 10 Answers
It possibly is an open series resistor feeding the positive tap to all 3 positive regulators, but without specific knowledge of this machine, I can't be sure.
Posted on Aug 07, 2008
I have a 1990 Alesis SR16 drum machine which has not been switched on for over 10 years. I now wish to use it again but all data including factory presets have been lost. How do I re instate them
How do I reinitialize SR-16?
Power on while holding: "ERASE" and "PLAY".
Evidence: All User songs and patterns will be empty.
Note: Clears memory
Clears the SR-16's User Songs and Patterns, but leaves the Preset Songs and Patterns intact.
Feb 15, 2015 | Alesis Sr 16 Stereo Drum Machine
ALESIS SR-16 won't save patterns
Really Quick.
Two problems are unrelated.
Assume older unit.
Needs memory battery,
and new display.
Nov 08, 2014 | Alesis Sr 16 Stereo Drum Machine
Roland r8 has flashing green light
Are you using the correct AC adapter? An aftermarket unit will do this if the power is insufficient, or the polarity is wrong (- / +). If you're using an aftermarket unit, it may not be providing the right amount of Amps and Voltage to the unit; causing the display to blink. You can try this cord to help: http://www.powerpayless.com/ac-power-adapter-for-roland-r-8-r8-drum-machine.html
Jan 13, 2013 | Music
Simmons sd9k LCD/brain issue?
The display is usually held against the circuit board with 2 or more strips of multiconductor rubber. it may just need the clamping tabs tweeked to make a more secure contact. If the drum set fell, it could have shifted the circuit board in relation to the display. Parience and careful observation will allow you open it up and make that tweek.
Dec 16, 2012 | Simmons SD9K Electronic Drum Set
Affichage presque invisible
try adjusting contrast, and try a different lighting source. If you have a polarized light source currently, try orienting it 90 degrees from where it is. That type of LCD relies on reflected lighting and it uses polarizing filters, so you may be at maximum contrast, but the current lighting is being absorbed by those polarized filters. Plus LED lighting, if not the right light frequency too- it gets absorbed. I have a clock in front of me that is exactly that way
Feb 05, 2012 | Alesis Sr 16 Stereo Drum Machine
Sr-16 drum machine need part
The pot is PROBABLY an audio taper so check the suffix on the old one.
Many pots you can find at Digikey.com or Mouser.com.
You MAY have to cut the shaft length
For an exact replacement you will probably have to go to Alesis.
4.7 K is NOT a standard value for pots. 5K ohms is.
Apr 04, 2010 | Alesis Sr 16 Stereo Drum Machine
Alesissr 18 drum machine lcd does not display
Check if there is a contrast setting... Unfortunately, sometimes the setting can;t be viewed when contrast is too low. Read your manual and find how to get into that mode if it exists and turn it up.
Jul 16, 2009 | Alesis Sr 16 Stereo Drum Machine
Need foot switch for this machine.
What you need is 2 unlatched switches 1 for the stop start function and one for the drum fill function.
I bought mine from my local music shop for £15 ea
Apr 21, 2009 | Alesis Sr 16 Stereo Drum Machine
I,ve lost my factury presets. is there any way to reload them?
Go to www.Alesis.com, undersupport clickdocuments and downloads.Click drum machines then All. The various drum machine models are then displayed to the right. Under HR-16 for instance you can download the manual in pdf and the presets in sysx. The manual should walk you through the procedure. You will have to replace the internal memory battery. They are easy to replace and cost about five bucks. Good Luck!
Mar 11, 2009 | Alesis Sr 16 Stereo Drum Machine
Where can i buy the proper volume pot for my alesis sr 16?
If you are willing to pay actual cost for shipping, I have an SR-16 with a broken screen that i could send you to salvage parts from. I bought it, I believe in December of 07 & other than the squished screen, I believe it to be in great shape. I just bought another one instead of fixing this one, so I certainly don't need it. Email me if you are interested. My guess is that USPS shipping would be like 2 or 3 bucks,as long as you are in the states.
Dec 03, 2008 | Alesis Sr 16 Stereo Drum Machine
Alesis Sr 16 Stereo Drum Machine Logo
243 people viewed this question
Top Alesis Music Experts
Michial Gueffroy
Bernie Scott
Level 1 Expert
Will Halftowaite
Are you an Alesis Music Expert? Answer questions, earn points and help others
