Question about Cameras
Hello the battrey on my sony camera died but the lense stayed out, i put a charged battery back in it and tried to turn it back on and nothing is happening
  • 797 Answers
It may make a difference which kind of camera you have.
Define the camera.
Posted on Aug 07, 2008
SOURCE:
Nikon s9300 - When I turn it on, the lense fully extends, but the screen stays black. I have to pop the battery out, then put back in for the lense to retract. Battery is fully charged and even tried
When the battery is fully charged, please put it in again. That means, if it is still in, remove it once again.
Switch it on, and even if you don't see a thing try to make a picture.
Then press the display button several times, to see if anything comes on the screen again.
If the camera does not respond after that, you should go back to the dealer, of contact Nikon.
Dec 21, 2013 | Nikon COOLPIX Cameras
It wont stay on. when i press the power button the led light blinks red. the camera is off but the lens is sticking out
It looks pretty much as battery problem, try using a new and charged one. Low charged (bad)battery can do strange things to eletronics
Oct 12, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
Altinator dose not charge when battry is low
time for another battery. Have a load test done on battery. Then have someone fullfield the alternator to see if its operating correctly
Jul 13, 2009 | 1987 Toyota Land Cruiser
I own a sony cybershot dsc w35 when i switch on the screen displays "turn the power off and on again" help?
Hi. I had exactly the same problem with my Sony Cyber-Shot DSC-W7. The problem started after while lense was fully open, the battery became 100% empty. I did not have access to new batteries and did not have my charger with me so I put the camera on my car seat and went home. After charging the batteries, I turned the camera Off and the lense retracted 100%. Later on I tried to transfer some pictures to my PC. After connecting the camera to my PC with the dial in the P position and lense fully open I turned the dial to play in order to transfer photos. After transferring the pictures, I turned the camera off and disconnected from the computer.
I turn the camera on to take new pictures next day, The lense would go up, and and turn with lense fully open. It would never close. The screen was black with a message "Turn the camera on and off again". I tried 30 times or more and the same thing would happen again.
Here is what I did to fix my camera and it has been working normally since then.
1- I cleaned around the outside of the lense with lent free cloth
2- I used dust OFF to get raid of the remaining small dust particles from around the lense.
3- While turning the camera off, I pushed (down, up and turn) the lense in (NOT TOO Hard) by my hand. If you push the lense too hard, you may damage the mechanicall moving parts of the lense.
4- After a few tries, the lense retracted 90% +. I then pushed the lense a little harder all the way in, the way it normall retracts. The lense cover also closed 100%.
5- I turned the Camera on and off a few times. It was opening and closing exactly the way it used to. My Cybershot has been working okay since then.
I read a lot and here is what cause my lense to malfunction.
While lense was fully open and battery died, some small particles got on the lense and prevented lense from fully opening or closing.
In summery: two things could have caused your camera lense to malfunction.
1- if you had dropped your camera hard, some mechanical parts may have got damaged or dislocated. In this case you have to open the lense and replace the damaged part, clean and put it back on the camera. This is too risky for most ordinary people. You would most likely make it WORST.
2- If you did not drop it, most likly, some how some small dust particles got on the outside of the lense and they prevent the lense or the lense cover from fully opening and closing. If this is your case, please follow exactly what I did and your camera would be back to normal.
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 25, 2009 | Sony Cameras
Lens keep extended in an out
Jun 25, 2009 | Sony Cyber-Shot DSC-S500 Digital Camera
My Sony Cyber-Shot DSC-W55 camera does not turn on properly. When I press the gallery button, everything runs smoothly. When I press the on button, the lens opens and closes several times, making a little...
Jun 25, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
My camera won't turn on
I had exactly the same problem with mine. Here is what I did to fix it.
put new battery in
1- Clean around the lense
2- While turning the camera off, press the lense in (up and down with lense movement) NOT too hard. Try that a few times until the lense either retract 100% or almost 100%. If almost 100%, press on the lense a little harder so that the lense be in 100% (like it normally closes)
If you turn your camera on and off a couple of times, your camera will work as it does normally.
GOOD LUCK!!!!!!!!!!
Jun 14, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Digital camera wont turn on
I just answered another question similar. Try that.
http://www.fixya.com/support/t244396-wont_turn
If it HelpsYa, please choose FixYa! ThankYa! =)
Nov 30, 2007 | Fuji FinePix A360 Digital Camera
Error message
*&%[email protected]#%^&*&^% !!"It's working!!!! Turn your camera on and put it near your ear. Did you hear a softly motorized sound in the lenses area and the green LED is flashing? If you hear this sound do this. Do it under your own responsability. (any way your camera does not work). When you turn on the camera wait until the lenses come out, in that moment grab the lens with your hand and don't let it go back. The camera will turn off but the lens will stay out. With the camera off push in the lens with your hand. Turn on the camera and that's it. I had to do it 2 times, but now my camera it's working again. This system error could be caused because the lens get out of it rail and the camera can not set the focus system.
Oct 18, 2006 | Panasonic Lumix DMC-LC33 Digital Camera
Sony camera turning itself off...
You can't use regular alkaline batteries in this camera. Alkaline batteries only supply 1.5 volts. The camera uses 2 in series for a total of 3.0 volts from alkaline. However, the camera requires 4.2 volts to operate correctly. This camera has high power requirements, so you'll need high end lithium or nickel hydride batteries that can supply the higher voltage and current this camera requires. It's a power hog, and regular alkaline batteries are too weak to run it. The menus will work on alkaline, but once you try to turn the camera on in capture mode to take a shot, the current requirements to operate the camera motor, LCD, zoom, memory stick, etc, all it once is too great a draw for alkaline to handle. Either use the external power supply, or get Lithium batteries. Make sure the batteries you get are 2.4 volts and not 1.5 volts. Get the ones with the highest current rating you can find.
Aug 31, 2006 | Sony Cyber-Shot DSC-P72 Digital Camera
Cameras Logo
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
