Question about Saeco Easy Espresso Machine
Saeco Easy The red lamp for the water filter is continuously blinking. We never used an aqua prima filter but we entcalc very often. A prssion on the blinking button for 5 sec as recommanded made no change.
  • hb9ox
    hb9ox Aug 07, 2008
    Hello! mirran, many many thanks for Help. It worked on the first try! You are really a Guru!. I tried since days to solve the problem without success. I am very happy to have discovered this Site per chance.
    hb9ox
  • 515 Answers
Press the button in the upper right corner. When the light flashes, release the button.
Make sure the brewing unit, dregsbox and driptray is in position.
Try to open the steam knob and make a cup of water.
Hope this will help you.
/Mirran
Posted on Aug 07, 2008
  • Mirko Blas
    Mirko Blas Aug 07, 2008
    Nice to know your machine is working again.
    I hope you will get a long nice time with your machine, that is a great machine.
    Make sure to descale it regulary, the most problem with these machine are the calcium.
    Have a nice day.
    /Mirran
SOURCE:
What ventelite mean
This can happen if there is not water in the system to prime it. If it has been out of use for a while, or if the water tank was low and you used most of the water for the last shot, steam, or hot water drink. With the machine off, fill the water tank, turn the machine on, and immediately, before heating up, run water out the steam wand. This will fill the system and clear the Ventilate message. Sometimes, if you use an aqua prima water filter, they can slow the water flow enough to trip the machine into sensing a lack of water. Be sure to change the filters on time.
Jan 17, 2015 | Saeco Magic Comfort 103467 Espresso...
I have a Saeco Incanto S Class rondo I think it is an older version as very manual no computer. It has a flashing red light on left side (where coffee comes out) it has a ~~ on it. The machine still...
That light indicate that you need to change the water filter in the tank. The water filter is either an Aqua prima
or intenza filters. If you are not using the filter I would suggest to just reset the light. You can reset the light by holding down the water button under the coffee brew button. Looks like a water drop.
You can also download the manual at www.CeriniCoffee.com
Apr 11, 2011 | Saeco Incanto Rondo Fully Automatic Coffee...
How do I change the aqua filter in the Saeco Vienna Automatica machine?
it is not a filter but a water softener and no need to replace. You need to pass thought it 2 spoon full of salt desolve with water and then flush it with water for 15 min until the salt will be cleaned. You can do this one time per month so to avoid any scale build inside the machine.
Dec 05, 2009 | Saeco Vienna SuperAutomatica Coffee...
Gaggia aqua prima filters
See this related problem. You need to open the steam valve on the right and let out some of the water/steam.
Oct 05, 2009 | Gaggia Titanium Espresso Machine
Seaco Easy wont work/Warning light blinking always
Try descaling the machine. If there is no water getting to the brew unit then it might be blocked, if you checked the brew unit then the blockage might be at the boiler or one of the lines.
Jun 03, 2009 | Saeco Easy Espresso Machine
Manual for the EASY SEACO coffemachine
This is giving message to replace the Aqua Prima water fileter. Hold the steam button for 5 seconds until the light goes off to reset the alarm. http://www.saecosupport.com/DisplayMessageEasy.html
Jan 14, 2009 | Saeco Easy Espresso Machine
Saeco royal professional aqua prima water filter
I think there should be a gasket in the watertank that the filter goes over.
/Mirran
Sep 25, 2008 | Saeco Royal Professional Espresso Machine
Blinking small red light.
I had that problem, it is the filetr reminder. I used Reverse Osmosis water so I dont use a =fileter, but the machine doesn't know that. If I recall the manual was wrong on which button to push an hold. I dont remember which was was right (could be the steam button). but one of them does make the light go out in about 5-10 sec.
Feb 20, 2008 | Saeco Easy Espresso Machine
Saeco Easy Espresso Machine Logo
250 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Pierre Laplante
espressofixr
Level 1 Expert
Ray Murphy
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
