Question about Samsung LN-S2651D 26 in. LCD Television
Samsung lcd tv
My samsung lcd is not working only sound is coming what is the problem
  • 2,071 Answers
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Posted on Aug 22, 2008
  • SUE Daniels Sep 15, 2013
    thanks for info
2 Suggested Answers
roety
  • 585 Answers
SOURCE: LCD TV LA40R81BM/XTL tv tick tick sound 5min then strat
Hi my name is Roety,
I can help you with your issue ,
This is most likely a power supply issue
I usually replace the swollen capacitors I can see
A repairman would charge about $300 to replace them for you.
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
Posted on Dec 15, 2009
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
Samsung Lcd tv-sound but no picture-comes back after being off for long
hi i have condensation in the back of my samsung lcd tv it turns on but it just flickers anyone can help thanks
Feb 29, 2012 | Samsung LA46A550 46 in. HD-Ready LCD TV
Samsung 27" lcd tv picture goes black, still have
0ne of 3 has failed:
(in order of probability):
1. Backlight inverter
2. Power Supply
3. Backlight
Please seek the expertise of an experienced TV repair technician - as they contain potentially lethal voltages that must be properly discharged before work can begin.
Thanks!(*&^%
Mar 19, 2011 | Samsung LN-S2738D 27 in. HDTV LCD...
Sound problem
you need to hook the cables up to the tv if you want sound to come through the tv.
Apr 09, 2009 | Samsung PPM42S3QX 42 in. HD-Ready LCD...
Samsung LN46B550 no picture only sound 3 days old
hey Adam i have a samsung that has been doing that.it would come on then after a few minutes the picture would go ou but the sound still worked.i found that one of the connectors that plugs into the LCD board had a broken solder joint were it connects to the back lighting .just unplug your lcd connections if its bad you'll know it because it will come out.
Apr 05, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
No sound from surround sound whilst tv on
YOU HAVE TO TURN VOLUME OFF ONTV AND PUT YOUR SURROUND SOUND ON AUX THATS HOW MINE WORKS
Jan 24, 2009 | Samsung HT-Q100 System
Can I still use my prologic receiver for my LCD TV ?
optical connection in tv is only input optical connection in receiver is only input will not work.need to connect rca jacks to tv's audio out jacks behind tv to any available input in receiver
Jan 04, 2009 | Samsung HTP-1200 System
Samsung lcd ln46a550pf3 no sound from hdtv reciever
ok your tv does not come with the very best sound, you have to get a receiver 7.1 or you can use the optical wire , that's if the system you are using has that option.
Apr 10, 2008 | Samsung LN-T4665F 46 in. LCD Television
Samsung LN-S2651D 26 in. LCD Television Logo
1,620 people viewed this question
Henry  Thomas
Henry Thomas
