AC Power Cord for Sanyo M7770K
I am looking for a power cord for the Sanyo M7770K radio/casette player. I lost mine and batteries get expensive.
Thank you,
Dojo Readhead
  • danita1 Dec 06, 2008
    I too have a Sanyo M7770K radio. It is black, and rectangular. Very retro, and I love it. The sound quality is fantastic.
    It calls for an AC adaptor that is: DC 9V.
    The thing is, I misplaced this adapter a long long long time ago.
    However, I have this different adaptor taken from a children's electric keyboard that I used to play with. It is a completely different adaptor, but it is still compatible with my radio. It says on the label:
    input: 120V AC 60Hz 11w
    output: 7.5 DC 600mA
    I have no idea what all that means! But it works with my radio perfectly! Though I am keeping my eyes open to find a DC 9V adapter so the electric keyboard has it's original adaptor. I wonder if they sell them in stores?
SOURCE:
  • 215 Answers
SOURCE: no power to unit
Remove the power plug and reopen the unit. Usually the socket will be soldered directly to a Printed Circuit Board. Look in the underside (where the solder joints are and you'll see the joints associated with the power socket. One of these is either a bad connection or the solder pad has lifted and broken the track on the PC board. If it's the solder pads give them a workout with a soldering iron if it still plays up scrape the protective lacquer of the PCboard Tracks and resolder them to the socket's solder joints. This should solve your problem. The best way to spot a bad connection is to reinsert your plug (making sure the other end isn't plugged into the wall socket) and lever the plug up, down, left and right. If there's anything faulty you'll see it. The solder joints will move very slightly and if the track is fractured you should spot that too. One other tip is that there is a switch built into the socket which will disable the battery power when you plug the unit into power. I have seen a few of these switches go bad but the chance of that is extremely small. I'd put my money on the socket's solder joints. BMW
Posted on Jul 14, 2006
SOURCE: need replacement power cord
on line radio shack sells the panasonic replacement cord as dircuit city does
Posted on Oct 01, 2007
  • 64 Answers
SOURCE: Power Cord for Creature II
I looked and the only thing I could come up with is to e-mail JBL and order a new one. Radio shack, Best Buy, or Futurehsop might be able to help but you have to call them with the model number or go to the store and check it out. Here's the link to JBL if you want to order a new one.
http://www.harmanaudio.com/search_browse/partlist.asp?BrandId=JBL&MarketId=HOM&Parts=CREATUREIIBLK/230
Sorry, wish I had a better answer but there isn't much out there for this.
Posted on Jan 05, 2008
SOURCE: power cord Cd player mod. #CD-1095
Answer below from:
http://wiki.answers.com/Q/How_do_you_get_a_cord_for_a_Durabrand_CD_player_model_cd_1095
You can purchase a generic power cord at Radio Shack. I had the same exact model and found that their catalog number 61-2875 was a perfect fit. It lists for $7.99. To be sure, take your radio in for an exact match. Good luck! :o)
Posted on Oct 25, 2008
SOURCE: need to replace lost power cord fpr back pack bantam 181100
the factory power transformer is 5V 1 A model TRX-022A input is AC100-240V 50/60 Hz 0.15A output DC5V 1A
Posted on Dec 29, 2008
I moved and lost the power cord to my sanyo flat screen tv model no. CLT1554. serial no. B5490687877576. I was wondering where i could get another one
Here is a link where you can purchase the cord from ebay.
http://cgi.ebay.com/12V-AC-Adapter-Power-Cord-Supply-Sanyo-CLT1554-LCD-/350425528490?pt=LH_DefaultDomain_0&hash=item5196fd38aa
If you want to research more for a cheaper price or different site, just simply search your model number and the product will come up.
Mar 06, 2011 | Sanyo Televison & Video
Lost AC plug-in power cord. Is it possible to
What fax machine?. if it looks like a computer power cord plug, that's what you need.
Feb 23, 2010 | Office Equipment & Supplies
Lost powercord
Go to www.sears.com the parts dept have make and model ready!
Thank you for useing us!
Dec 13, 2008 | TruTech PVS12701 Portable DVD Player
Power Cord
Please let me know when I can get the power cord & AC adapter. I moved and lost them and cannot use my television. Thank you R. Werkheiser
Nov 03, 2008 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Milwaukee Job site radio
Questions:
1. Does the AC cord look ok? Not damaged?
2. Have you tried another AC outlet?
3. Does the AC cord unplug from the radio?
When you operate the radio from the AC power cord, the radio uses an internal power supply consisting of a step-down transformer, rectifier, and filter that converts the AC to DC to operate the radio.
When you run the radio off of batteries, it powers the radio directly. In some radios, when you plug the AC cord into the radio, it activates a switch that disconnects the battery voltage to the radio so that the batteries wont be damaged from the voltage created by the internal supply.
The radio can be powered by either the batteries or the internal supply. You don't want either supply affecting the other, so that is why a switch is sometimes used.
Since the radio works fine off of batteries, that would indicate that there is a problem with the internal power supply. This could be a blown fuse, bad transformer or bad rectifier diode.
Good Luck,
- Jim
Jan 24, 2008 | GE Superadio III AM/FM
Lost power cord for Polaroid PDM-1058 portable DVD player
I've looked for the same thing and the only place I can find it is eBay for about $25
Nov 08, 2007 | Polaroid PDM-1058 Portable DVD Player
Noise with casette adaptor
Well Jill the problem you are having is called inducted noise. The lighter power adapter cord is inducting electrical current to the cord used by the cassette adapter thus creating the the noise you've been hearing. Do your best to separate the two cables as much as possible. I realize that your unit may have both cords coming out of th same side, and that's fine. the longer the run of wire, the easier it is to have induction issues. If the cords do come out on the same side, run one up and the other down away from the other cord. Do not coil the lighter adapter or cord either, it increases the chance of being able to induct noise. If your unit is to close to the lighter assembly you may need to move the unit to another location in the vehicle itself to help combat the noise issue. Other options include to shield the cassette adapter wire, i use aluminum tape for heating/ac ducts. The only other option i can see is purchasing a FM modulator which will transmit the units sound wireless-ly through an FM radio channel. You will want to check and see...i do believe most XM radios have a FM modulator built in. Hope this helps, and good luck.
Oct 03, 2006 | Delphi Roady XT XM Radio Receiver
476 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
