Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Bissle carpet cleaner
How did you get our carpet cleaner to release water? I have the same problem.
  • timcarol Aug 22, 2008
    We have the same problem. I have looked at the suggestions on the Bissell web site and followed there suggested steps but still can not get a water flow --
    -Make sure there is a full tank of water.
    -Check for
    the black or red tank gasket on the bottom of the tank and tank
    assembly. If the gasket is lodged in the base of unit or has been lost,
    reattach the gasket by pushing the rounded portion of the gasket over
    the lip on the autoload assembly.
    -Check the valve on the bottom of the tank and tank to make sure water will come through when the X valve is depressed.
    -Check
    if the small rounded window tabs on the floor nozzle are locked in
    their mating slots and not inadvertently lifting the tank up out of
    place.
    -Check the handle screw on the back of the unit. The screw head should be bottomed out in the screw hole.
    Unit may have lost prime. To prime, replace the full tank into unit and
    hold the trigger in for 30 seconds with the unit turned off. Turn unit
    on to check for spray.
    -Check the pump belt to ensure this is
    intact. The belt is located on the side of the machine. Pry up the belt
    access panel for access to pump belt. If the belt is broken, refer to
    user guide for replacment or FAQ.
  • peggyb1021 Sep 12, 2008
    I am sooo frustrated. This is the 2nd Bissell I have owned and had problems with the first one but gave it another try. I did everything that was suggested, yet I have no water. I think I should have went with the Hoover like I wanted to.
Yeah....I did all that too....nothing!!! I called to have mine repaired. They said it sonds like a clogged heatercord?? I tired to look up what that was...can't find anything about it!!! ERRRRR!!!
Posted on Aug 31, 2008
Hoover brush and wash instruction manual
Hi there! To prepare for cleaning, put the solution and water in the top tank. While cleaning, all the dirty water gets sucked into the bottom tank. To clean squeeze trigger to release cleaning solution and slowly push carpet cleaner forward, this equals one wet stroke. Continue to squeeze trigger and slowly pull carpet cleaner back toward you (second wet stroke). Release trigger and slowly push carpet cleaner forward over area just sprayed with solution (dry stroke). Then slowly pull carpet cleaner back toward you without squeezing trigger (dry stroke). To avoid saturating the carpet don't do more than 4 wet strokes over one area. Always end with dry strokes. Here is a link to view the instruction manual if needed.
http://hoover.com/file/604/
Hope this was helpful!
Jun 19, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you need and a manual you can view:
Bissell 7901 Belt and Manual
Mar 01, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
How to release and withdraw water solution to clean carpet.
Problem resolved by contacting a local retailer who provided instructions.
Dec 30, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Why isnt my carpet cleaner releasing or putting any water out onto my carpet
I believe we own the same model or one that operates like it. If so, then yours has a "bladder" for the clean water, it has to be almost full sometimes before it will release any. Check the nozzle on the bottom of the tank body and on the cleaner for anything that might clog it up.
I think it will also release water only when you pull the cleaner toward you and hold the trigger down long enough as well...it does not release when moving forward.
Also check the bottom of the cleaner and clean off anything stuck to it...it gets pretty dirty and that is where the water comes through.
Dec 26, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Water will not come out when i push on trigger button. So water does not come out. I have taken it apart and cleaned it. The problem seems to be in the triggerI push on the handle to release the water.
order the part from bissel see if that fixes sound like you know what wrong just need get part number from bissell.
Could be some kinda pump also thats bad not pushing out the water.
I got bissle heated one black it only problem the seals rot out the soap dispencer. if you want be cheeper on washing things you can water down dish soap ore laudry deterget on there unit and cost allot less 17 bucks for bottle soap water
Jul 24, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Instructions or manuel was not included.
i downloaded the manual for your machine, but not sure how to access it for you,but i do know about the problem, the tank that sits down on the front of the steamer and it has 2 clips that you push in to lock the tank is where your dirty water is put in when you are cleaning your carpets. the tank above ,the one where you put your solution and water in is what is used to shampoo your carpet. on the handle is a trigger (black) button ,this is the button you push in to release your solution onto your carpet. release the button to extract the water from your carpet,moving your steamer in a back and forth motion. the trigger button is the only button on the machine and is only used to put the water /cleaner located in the upper tank on your carpet, releasing this button and moving your steamer back and forth over the shampooed part with extract your dirty water into the tank that sits below the solution tank. go on www.hoover.com and click on carpet cleaners ,scroll down to find yours and click on manual. and the owner manual will download and you can print it out for future reference, i hope this will solve your problem, sandy
Nov 29, 2008 | Hoover F5810 SteamVac Upright Vacuum
My bissle proheat carpet cleaner/vaccuum has become clogged with the cleaner solution. As a result the cleaner solution does not reach the carpet when in operation. I had this fixed before at a local...
Take apart the handle (a few screws) unclip the small clear hoses, use a pipe cleaner or small screwdriver to clear the hose from the crystalized cleaning solution that is blocking the hose. Put it back together and it will be like new. ALWAYS run plain water through your machine when you are done using it to rinse it out.
May 01, 2008 | Vacuums
Bissle will not let water out if Bladder
Check the vale at the bottom of the tank. Push it in and see if water comes out ok, also check to make sure the seal is on the valve asm. Check the pump belt to see if it broke. Could have a bad pump. Is the top cover seated against the base in the back, if it is raised up, then it also raises the tank so it can't work.
Apr 12, 2008 | Bissell 1699 ProHeat Clear View Upright...
Hoover Steamvac F5892-900 leaving lines on carpet, does not seem to spray
Is the cleaner sucking up the water like it should? If not , check that the filter on the inside of the lid has a 1/4 in. gap between the filter and the top of the lid. Either that or the water isn't completely being shut off when you release the trigger, in whcih case you would probably have to take it in for service.
Jan 31, 2008 | Hoover F5892-900 SteamVac Upright Vacuum
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
103 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
