Question about Crosley Dryers
I for got what cables go where in my crosley dryer i have a cde6505w model i change d\the harnes and i for got how the wires go and where they go can u please help me out
  • 958 Answers
Look closely at the sockets, they design them not to be interchangeable. so one by one you can insert them hopefully you can put them all together.
tnx 4 using fixya..
drcool
Posted on Aug 07, 2008
My model # cde6505w crosley dryer is heating and turning and runs fine except that it makes a loud noise while it is running. it almost sounds like a metal to metal noise any suggestions
Hi cswsuzy...
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer if you have to.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer by removing two screws located on either side of the top of the dryer housing and unplug the door switch.
This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.Now is a good time to replace the front felt seal on the drum if it needs to be replaced. Be sure to use a good grade of weatherproof cement on the seal to glue it to the drum, sometimes the glue is furnished with the seal.
Now is also a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots they will make a thumping type of noise or if there is too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil, or a light lubricant like Vaseline.
Reassemble the dryer.
Plug back into your electrical receptical.
This should solve your noise problem.
This is a FREE answer, Please take time to rate me
Jul 16, 2011 | Crosley Dryers
Crosley dryer model # cde22b6v. Timer switch works but dryer will not turn or heat. I checked connections. Belt is good. Motor turns free. What do you think I need to check?
door switch, bypass by taping the wires together. here are some other things to check:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Mar 30, 2011 | Crosley CDE6000 Electric Dryer
How do i hook up a 4 post plug to a 3 post plug
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Sep 09, 2010 | Crosley CDG6000 Gas Dryer
How can i tell the hot wires from the neutral wire on the dryer?
heatman101
Sep 04, 2010 | Crosley Dryers
Crosley Model #CDE22B7V. Clothes dryer only gets
I used to work for a Crosley dealership. The number one problem is gonna be the blower wheel.709b43d.jpggo ahead and pop the top(after unplugging the machine) f11ef2b.jpgGet the front off and then get the drum out. Clean out all the lint. 31001043 is the part number
Apr 01, 2010 | Crosley Dryers
I need to change the plug on my dryer
Unscrew the screws in the plug, pry it apart, Mark the wires with marker or whiteout, and finally replace the wires.
Mar 25, 2010 | Crosley CDE6000 Electric Dryer
Need a wiring diagram for cde6000
There should be one iside the machine or hidden somewhere. Look under the control panel. Usually they are there. Let me know if you need any other help
Mar 29, 2009 | Crosley CDE6000 Electric Dryer
Just Stopped Working
Use a putty knife and press against those spring clips holding down the top.f23fbc9.jpg
Check the door switch for continuity. Let me know.
May 08, 2008 | Crosley CDE6000 Electric Dryer
Dryers Logo
47 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
