Question about Frigidaire GLTF2940ES Front Load Washer
Frigidaire model # FRT22RGCW3
I have water dripping from the roof and upper back side of the fridge compartment. It drips onton the upper shelf. What could it be.
BNewberry
  • 93 Answers
SOURCE: freezer control is set at
if its less than one year old you should be able to call for warranty service and have your machine fixed for free.
go to www.frigidaire.com and search for servicers in your zip code. If you have no luck with that let me know, i can further assist you.
Posted on May 15, 2008
ngfam1
  • 639 Answers
SOURCE: washer won't fill for the rinse cycle
For this problem you should call service.
If it's 10 years old or more, better off replacing it with a newer machine which will be much more efficient!
Try :
A&E Factory Service
1-800-905-9505
Nation wide / 7days/24 hours
Good work
Please give me a solution solved rating in this site
Thank You
Neil
Posted on Aug 24, 2008
  • 298 Answers
SOURCE: Water keeps dripping after it dispenses water thru the door
When you push the button, the CLICK you hear when the water flows is the Water delivery solenoid opening to let water thru, then snapping shut when U R done. The Spring is weak (prob wrong type, size, strength at factory) or the valve seal is cracked, torn, hardened or crushed.
Since all this is inside the door, you will either have to take it apart to see/fix/replace.
Quick fix: turn down the water pressure coming in(?)
Call Mr. Handyman to fix.
If under warranty - they might fix this for you for free
If this is a factory defect, there might be a recall in place for repair/replacement parts
Googlee both - Make/Model + Dripping Valve + Recall
Good Luck!
Posted on Jan 17, 2009
  • 1214 Answers
SOURCE: water dispenser dripping
The seat in the door valve has probably failed or has some trash in it.
Posted on Jan 20, 2009
  • 30 Answers
SOURCE: Water drips from evaporator fan channel Frigidaire FRT17G4B
It sounds as if this is a top mounted refrigerator. (freezer on top) If this is the case, check to see if you need to defrost the drain. You could also have a problem with the door seals. Remember the air coming out of the vent is freezer temp minus a few degrees. It could be that the moisture is condensing in that area.
Posted on Feb 01, 2009
How do I reset fridge model #106.51132210 it drips water from top and freezes on top shelf of fridge side
I'm not sure if resetting will help, but the easiest way is to just flip the breaker off and then back on.
Dec 04, 2014 | Refrigerators
Why is condensation in fridge?
Good afternoon friend, thank you for your post!
I understand that your Frigidaire refrigerator has moisture forming underneath the bottom panel of your freezer and that is causing water to drip onto your shelves. Would you be able to provide me with your model number that way I could research additional information for you please? You can locate your serial tag (which lists your model number) on the inside cabinet of the fresh food compartment normally on the left side of a top mount. On a side by side it can be found on the right hand side. I look forward to your response. -Matt
Jul 16, 2014 | Frigidaire Refrigerators
Our GE PSC25PSTA fridge drips water from the icemaker
I have this model also for just over 3 years and it developed the same problem. The issue turned out to be the unit was in defrost mode too long caused by a failing control circuit board (found in the back under a panel cover). The board controls all refrig functions. This was replaced and the unit works normally now. The board costs around $200 plus the service call ... still cheaper than a new refig.
Feb 09, 2010 | GE Refrigerators
Water is collecting on the top shelf.
You will have to empty your fridge and remove the back panel.clean it out by pouring warm water mixed with Baking soda into the drain at the back of the freezer compartment and let it drain into the drip pan at the bottom of the refrigerator. In the refrigerator section, find the screws that hold the control console securely to the roof of the refrigerator. Usually there are two of them towards the front. The front part of the panel will drop down and then you will see a plug to separate so now you can remove the entire control panel and sit it on the floor or kitchen table. Now you will see the hole going into the freezer section and the other hole going to the defrost pan under the refrigerator. I am suspecting the tube on the rear of the console which is on the floor or the table right now is either cracked or not fitting snuggly in the hole at the rear of the refrigerator. If you do not find any cracks, take some putty and wrap it around the end of the tube and then reinstall the console/control panel making a secure and tight fit into the hole.
Aug 23, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Kitchenaid ice maker dripping and freezing down freezer shelfs
Tube sometimes freezes because of minerals in it hold one droplet at a time until buildup freezes solid. Replace tube first. Water valve allowing some droplets through can also cause this. Tube first-less expensive.
Aug 22, 2009 | KitchenAid Superba Architect KSCS25INSS...
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Hi, I can help you. The drain is plugged in the freezer section. Could I get the model #?
Some models need an after market drain heat strip added.
Please let me know and I can get you through tis.
Thanks
Vic
May 30, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Feb 01, 2009 | Frigidaire FRT17G4B Top Freezer...
Water drips into refrigerator
sounds to me that maybe your draain lin is clogged up in your freezer compartment above your refrigerator. Look for a clear tube that should be runnig down either on thre outside or on the back wall and clear it out after you make sure that its not frozen. if it is then use either a light bulb or hair dryer to thaw out. Thanks for using FixYa.
Dec 25, 2008 | Refrigerators
Frigidaire GLTF2940ES Front Load Washer Logo
54 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
