Question about Pelican Xbox Eclipse II Wireless Controller (XBECIIWICO)
Controller the trigger gets stuck & keeps firing till it run out of anno
  • 3 Answers
If you are a person who eats snacks and holds the controller with the same hand in most cases grime sets in and triger gets stuck or try and clean pad and contact area.
Posted on Aug 07, 2008
With 90 # air and PC nails. When I pull the trigger nothing happens. No air noise, no nailing, no movement - just dead. It's been oiled every use.
Most likely stuck trigger valve. Easy to check. Remove nails, remove trigger to expose the firing pin of trigger valve. Connect air and very quickly depress the firing pin all the way in. If the gun fires , adjust the safety to depress the trigger valve completely. If the gun does not fire, replace firing valve, or remove and check /lube o-rings in valve. Good luck
Jul 11, 2015 | Air Tools & Compressors
Why doesn't the trigger do anything on my NS289000 framing nailer?
Nailer not firing is caused by lack of lubrication in the headvalve (lube with white grease) or driver stuck/bent (make sure driver moves freely) or safety foot not depressing the firing pin on the trigger valve all the way in. Easy to check. Remove the trigger to expose the firing pin. With no nails in gun, connect air and depress the firing pin with finger all the way in. If the gun fires, adjust the safety foot. If the gun does not fire, lube headvalve and check driver piston stuck. Good luck
Dec 03, 2013 | Campbell Hausfeld Ns2890 Framing Nailer...
Why does my Hitachi nv45ab gun double fire nails?
This gun should be bump-fired only. Do not place the gun on the work and press trigger. Make sure that the safety spring is in place and has good tension. The spring helps to push the foot off the trigger so that it fires once. You could also adjust the screw that pushes on the firing valve. Turn in or out several turns till head of nail is correct when bump firing then lock the nut. The safety foot fits rather loose on the gun and should still work ok but can get so loose that it falls off the nose. Good luck
Jan 23, 2013 | Hitachi Air Tools & Compressors
Framing nailer won't fire nails
Usually safety foot is not making full contact to trigger mech. First test trigger valve. Remove nails, remove the trigger to expose the trigger firing pin. Connect air and test fire by pushing in the firing pin with your finger (dry fire onto wood or old coiled rubber hose, use very quick pushing action against trigger pin). If the gun works, replace parts and adjust the safety foot so that the lever below the trigger is pushed all the way up and lever depresses the trigger pin all the way in. Good luck
May 26, 2012 | Air Tools & Compressors
1993 40 HP 4 cyl. Mercury outboard: Running along
I solved it with no help from the professional assistant team. Thanks for no help till I send money...DON'T THINK SO!!! Thanks for wasting my time.
Sep 03, 2009 | Boating
Trigger button on Saitek ST290 is stuck in fire position
I've disassembled the ST290 to get at it's internals. It wasn't easy. It's not something I would recommend and finding the exact same lever switch to replace the damaged one would be tricky, not to mention soldering in the new switch and all.
I have seen the ST290 at Radio Shack stores for less than $20. You might be less frustrated just getting a new one.
May 27, 2008 | Saitek ST290 Joystick
Pelican Xbox Eclipse II Wireless Controller (XBECIIWICO) Logo
77 people viewed this question
Top Pelican Video Game Consoles & Games Experts
James Wishart
Are you a Pelican Video Game Console and Game Expert? Answer questions, earn points and help others
