Question about GE Spacemaker Over-the-Range Microwave
How do I install the Spacemaker Xl? Where does the cord go?
  • grantlyn Aug 10, 2008
    thanks a ton!
  • GE Master
  • 9,098 Answers
You can download GE owner's manuals and installation instructions here.
You'll need your model number from the tag.
Posted on Aug 10, 2008
  • William Miller
    William Miller Aug 11, 2008
How to remove ge spacemaker xl
You want to take the microwave off the wall, is that correct. 1st unplug the microwave--plug should be in the cabinet over the microwave. Next--in the same cabinet you should see 2 or 3 phillips head screws with big heads going through the bottom of the cabinet into the microwave top. Have someone hold up on the microwave while you remove the screws. They are about 3 inches long. Once the screws are out, the microwave should tilt forward and downward at the front. The back of the MW sits on 4 tabs on the wall mount plate so to get it off completely you have to lift the back up slightly off the tabs about 1 inch. Feed the power cord down through the cabinet and you are done.
Feb 28, 2015 | GE Profile Spacemaker XL 1800 36"...
I need the dimensions of the GE Spacemaker XL Model JVM1653WH01
For dimensions look at the GE Appliance web site at: http://www.geappliances.com/ then search for JVM1653WH01
This will take you to the product information page for the JVM1653WH 1.6 Cubic Foot Over the Range Microwave Oven with weights and dimensions, installation instructions etc.
Oct 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Need installation instructions so I can remove a GE spacemaker xl model jvm1330wwc.
You can also download GE owner's manuals and installation instructions here.
You can find handy exploded views and order parts by model number
here.
If you need simple do it yourself repair tips or a free estimate, let us know.
Aug 22, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Strange smell no heat
actually the two things you mentioned are a pretty reliable indicator :/
The only way to be positive is to check for power from the high voltage transformer. If you are not trained to work around electricity, i wouldn't mess with it because it can most certainly kill.
if there is no power coming from the HV trans, you then trace power back toward the cord. The component that has power going in but not coming out is the culprit.
Apr 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave GE XL 1800 Spacemaker Not Heating
have you check the fuses, maybe its open, orthe hv diode.
Sep 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My GE Spacemaker XL 1800 was working fine and
check fuse inside unit microwave has a fuse around 15 to 25 amps get at local hard ware store u should discharge capacitor before installing fuse not nessary in microwave
Jul 25, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile Spacemaker XL JMV1460 Turns On by Itself
Sounds like there is a stray piece of wire or other metal floating around inside the case. Remove the cover and any breakables in the microwave (the power cord is unplugged for this), turn it upside down over a table and shake it, pound the bottom, and shake it some more--likely the offending piece will drop out onto the table. If so, put it back together and whack it to see if that fixed the problem (cord plugged back in). This process can be repeated.
Jul 17, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemaker XL Microwave Oven Model #JVM1460WA1- After removing the 3 bolts at the top, what are the next steps to remove the oven?
Jun 05, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Intertnal light in spacemaker xl 1800
if there is no plate to unscrew in front of the bulb , then the only way it can be changed is to open the microwave
WARNING: HIGH VOLTAGE CAPACITOR INSIDE WILL STILL BE HOLDING HIGH VOLTAGE
if you are not familiar with this then don't attempt the repair!
then you will need a technician
electech
Oct 29, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Over-the-Range Microwave Logo
1,219 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
