Question about Canon PIXMA iP90 InkJet Printer
Canon pixma ip90 green light flash then orange light flash 4 times then back to green
  • Anonymous Mar 14, 2014
    CANON PIXMA MX410 how do you turn orange light off
  • 1,498 Answers
Hi there SWCopiers,
Four flashes indicates 'Ink tanks installed incorrectly' or 'Printer needs repair'.
Click here for iP90 ink tank install procedure.
Click here for reset procedure.
Click here for instruction on contacting Canon Support. They have been very helpful. If it turns out that one of your ink tanks is faulty, they have replaced them at no cost in the past.
Hope this helps.
Remember: Good things come to those who Rate!!
Mike
Posted on Aug 07, 2008
What do errors messages 5100 and 5C00 indicate when offered by my Canon Pixma iP90?
1.With the printer powered off but connected to a power source,
press the Power button while pressing and holding the Stop/ Reset button.
2. When the Power is lit, press the Stop/Reset button two times
while pressing and holding the Power button.
3. When releasing the Power button and the Stop / Reset button (regardless of order),
the printer will move into a service mode. (Waiting for menu selection)
4. When the on/off lights in green, press the Stop/Reset button the
specified number of time(s) according to the function listed in the table below.
(Each time the Stop/Reset button is pressed, the LED lights alternately in orange
and green, starting with orange.)
Note: press 4 times for waste ink counter reset.
The number of the Reset button pressing LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5.Turn off the printer.( it must be turn off) then turn it on again
Nov 19, 2010 | Canon PIXMA iP90 Mobile Printer
Ip 90
According to Canon, your ink cartridge has been installed incorrectly.
Feb 15, 2008 | Canon PIXMA iP90 Mobile Printer
My canon ip90 printer cartridges is stuck to the right of the printer. And the light keep flashing orange 5 times. Can someone please help me fix it.
LED blinking in Orange color 5 times = Print head is not installed properly or the print head has reached to the end of life.
May 29, 2010 | Canon PIXMA iP90 Mobile Printer
My canon ip90 does not print, continue to get 5100 error msg
you can try this method to reset the error..
First close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.), then while holding the Power button, release the Resume/Cancel button but do not release the Power button.
While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange. During initialization, the LED blinks in green. When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. Pls note each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.
Then press the Power button, the LED lights in green, and the
selected function is performed. When the operation completes, the printer returns to the menu selection mode automatically. Last just power off then back on and test.
May 28, 2010 | Canon PIXMA iP90 InkJet Printer
MY CANON IT NOT WORKING IT'S FLASHING 8 TIMES
Hi there you can try.
Following step by step resetting canon Pixma iP90 :
  • Before resetting printer canon iP90, start with printer power off.
  • Press resume button coincide with power button.
  • While pressing power button, release resume button.
  • Press resume button 2 times and then release both button
  • Green LED indicator will blinking and then stopped blinking.
  • When the Power LED lights in green, press resume button 4 times.
  • Press power button and the printer power will off. Otherwise off, depress again power button.
  • And the turn on the printer again, your printer canon iP90 should be response as normal.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 21, 2010 | Canon PIXMA iP90 Mobile Printer
Waste inki absober is full. The indicator orange
You can remove the top of the printer to remove and clean the pad or reset the printer and continue without cleaning.
These are the instructions which worked for me on my Canon pixma ip470 and has work on many other Canon models:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Feb 15, 2010 | Canon PIXMA iP90 Mobile Printer
Would not print, oraqnge light blinks 5 times then one green flash. Open the door to ink and the head does not move to center as it used to.
This is a waste ink code and needs to be reset. follow instructions below.
Canon pixma iP90 released almost at the same time with canon Pixma iP 1880. Canon iP90 is printer with single function. Cartidges which used in canon Pixma iP90 is BCI-15BK, BCI-115C dan BCI-16C. Resetting procedure canon iP90 almost the same as manual reset canon iP1880. You can use combination of button in the printer to reset the printer.
  • Before resetting printer canon iP90, start with printer power off .
  • Green LED indocator will blinking and then stopped blinking.
  • Press power button and the printer power will off. otherwise off, depress again power button.
Please rate my help++++Thanks for using FIXYA
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
Nov 24, 2009 | Canon PIXMA iP90 Mobile Printer
I have a flashing orange light on the printer, no error messages, any iseas?
Tell me how many orange flashes between the green flashes, and I'll tell you the problem...
Aug 03, 2009 | Canon PIXMA iP90 Mobile Printer
I have a Waste Ink Absorber problem that will prevent printing
Try this to reset the error.
Apr 07, 2009 | Canon PIXMA iP90 Mobile Printer
Error 5100 canon ip90
You may try this to rest the 5100 error:
5) Press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
Dec 07, 2008 | Canon PIXMA iP90 InkJet Printer
Canon PIXMA iP90 InkJet Printer Logo
576 people viewed this question
old marine
old marine
