You can send files to another email adress by an email click start all programs accessories open windows explorer my computer you should see your drive click to open it from there you select the files right click on the file/s right click copy navigate back to the destination drive right click select paste or select the files hold the mouse cursor the file/s drag them to scan disc then drop them hope this helps
open up your new email type in the company adress then you should see attachment depending on which email you are using select attachment then you will open up a browse window navigate to you resume select it then click send
To Transferring Playlists If you want not only your content but also your playlists to exist on your new computer, you will want to transfer a copy of all your playlists from your old computer. To do this, choose File > Library > Export Library on your old computer. Save the XML file that is created to your desktop. Send the playlists file to yourself as an e-mail attachment, use an external drive, or use file sharing to move the playlists file to your new computer. Once the file is on your new computer, open iTunes and choose File > Library > Import Playlist. The import process will remove any items from the playlists that you didn't share via Home Sharing. Source:http://support.apple.com/kb/HT4527 Alternative Method: http://helpmerick.com/how-to-transfer-your-itunes-library-playlists-to-a-new-computer.htm
