Question about Hoover Vacuums
I have a hoover 1800w alyx and the dust is flying out of the rear filter!?
SOURCE:
reddevil6
  • 1673 Answers
SOURCE: Hoover Vacuum not working - Dust Manager Cyclonic 1800W
Sounds like it got plugged up. I doubt if you can get it exchanged, but to try you would have to take it back where you bought it. But you have a years warranty, take it in to a warranty repair shop to get it repaired. Just take proof of purchase with you.
Posted on Jan 15, 2008
SOURCE: filter keeps clogging
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=719779
Generic problem for all Vacuums
Filter keeps clogging
Posted by ozandcaza on Jun 29, 2008
Report abuse
Dust etc collects in the filter above the dust container. The dust container remains empty. Hoover then over heats and cuts out. Collect in replaced new filters in Hoover but problem still remains.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. My question is how old is the Hoover vacuum? If it less than a year you should really see an Authorized Hoover vacuum cleaner dealer that the problem might be covered under a factory warranty. This should not be happening and it sound to me like there is a clog somewhere in the vacuum fill area that is causing it to do this to you and the vacuum. You are lucky that you have a thermal switch that does shut it off. If not and it is over the one year factory warranty then you should see a local vacuum cleaner dealer in your area or contact Hoover Cust Serv @ the website and or phone 3 listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 03, 2008
SOURCE: Hoover Alyx Pets 2000w Hoover Model
not getting any suction. there are no blockages.
Posted on Jul 21, 2008
  • 97 Answers
SOURCE: Overheating Hoover
Most likely caused by a lack of airflow. Check to see if you have airflow at the end of the hose. If not, Remove all of the hoses and ensure that they are not clogged. If there is airflow through the hose; check the air inlet immediately aft of the brushroll, inside the nozzle. This is a very common place for clogs to form.
Also note: contrary to some manufacturers claims, you can not clean (or wash, for that matter;) a hepa filter. The small particles are too embedded in the filter media to ever get completely removed, and the act of cleaning tends to damage the filters, even if you can't see the damage. This is why bagless life-spans, on average, are half the length of the life-spans of bagged vacuums.
Good luck,
-R
Posted on Aug 01, 2008
ukvacfan
  • 328 Answers
SOURCE: Hoover Alyx 2000w, no power. Help!??
Its a possibility then that if the fuse has been replaced that the cable inside has either come apart or you have a broken switch. If its only a year then you should be covered automatically with Hoover's guarantee.
Posted on Mar 06, 2009
My new Hoover Wet & Dry Vacuum Cleaner-1800w sucks dust from the carpet but it also blow abt 50% of the dust out into the room. Everything is covered in a layer of white dust. The hose is fitted 100%
It seems it must be blowing out from somewhere. Try to figure out where by feeling for air blowing to try to determine where it's coming from and why.
Mar 16, 2018 | Hoover Vacuums
My Hoover pure power 1700w upright, bagged vacuum cleaner shuts down after 5 minute's use. Although I purchased the pure Hoover power 1700w upright vacuum cleaner around eight years ago it has not u
Are the brushes worn down too far? As they wear the springs tension gets weaker. The brushes can also get stuck inside the channel they slide in. Could also be a buildup of dust etc inside and around the internal fan or commutator, etc.
Jan 18, 2015 | Hoover Vacuums
Hoover alyx 2000x. Machine stopped working while in use.
If it has a fuse, maybe it blew...check your manual to see if that is a possibility and how to reset it.
Jul 18, 2011 | Hoover Vacuums
No instructions
I need a manual for my hoover alyx 2000w model No TC1202 001
Jun 05, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Dirt Devil Extreme Quick Vac - Won't turn on
Check that the filters are completely clear and not blocked - especially the top filter on top of the bin assembly. If its clogged completely brush it free of dirt and then reassemble. Make sure the inner cone filter and mesh filter is also completely clean. Then check the hose and main dust channel - something is clogged that makes this machine overheat and stop working - and often with this model (Hoover also make it in the UK under the Alyx name) its down to clogged filters or small clogs of dust in the dust channels.
Don't forget to rate, thanks.
Mar 06, 2009 | Vacuums
Mar 05, 2009 | Hoover F5411 SteamVac Jr. Canister Vacuum
Overheating Hoover
Good luck,
-R
Aug 01, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Jan 12, 2008 | Vacuums
Vacuums Logo
227 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Kirk Thompson
Level 1 Expert
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
