Question about Sharp LC-42D64U 42 in. LCD HDTV
Stereo/Mono Fluctuation Screen Display Problem
About once every 5-10 minutes my Sharp LC-42D64U will flash a blue box in the top right hand portion of the screen showing that it is switching between stereo and mono sound settings.
While the sound switch is barely noticable, the blue box constantly poping up in the top right is incredibly annoying.
help please!
  • 2 more comments
  • Anonymous Oct 20, 2008
    Same problem on the 32" model. Considering using an external cable tuner to avoid this.
  • Anonymous Oct 22, 2008
    we have the same issue with the sharp 46". Called support and was told our cable power needs a booster. Called cable, they installed a booster, problem persists. Interesting this does not occur when watching a dvd. Still have 70 days to return set and exchange for something else.
  • Grannyjones Dec 09, 2008
    I have the same problem with 32" model only the box is constantly flickering on local channels and frequently on some satellite channels. Does anyone have a solution??
    SJ
  • majacal Dec 13, 2008
    I have an older 32" Magnavox that has this exact problem.  We lost the remote and can't even get to a menu screen to figure it out.  We beg of you to find a solution.
I had the same problem.
All I did was unplug the standard cable wire from my tv and used RCA cables to connect my TV to my digital cable box the the Input 1 jack in the back. It also increased the video quality.
Posted on Jan 03, 2009
I have Sharp TV Model LC-42D64U sound cuts out after two hours or less. Sound only comes back after leaving TV off for about an hour.
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/
Feb 23, 2017 | Sharp LC-42D64U - AQUOS 42" High-def 1080p...
Sharp LC42D64U Wont power on. two lights blink twice then one lite blinks.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts...
Nov 30, 2016 | Sharp Aquos Lc-42d64u 42in Lcd Tv lc42d64u
Darker screen on the right hand side of my Sharp
try going to menu and center the screen both vertically and horizantal, the manual should help
Feb 25, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
No sound from ps3 when connected with hdmi to sharp lc-42d64u lcd, connected to sony dav-hdx589w via digital optical cable
on your PS3 go setting>sound setting> audio output settings to adjust settings for the audio device (OPTICAL or HDMI)
Dec 05, 2009 | Sharp LC-42D64U 42 in. LCD HDTV
My new sharp LC-52D65U tv continuously gives the sound display on the top right hand corner when it switches from mono to stereo etc. It dosn't do this all the time but for a while it will start again.
Make sure it isn't the source causing the problem. I.E. Cable box, dvd player, xbox or ps3. Try switching the wires. If all else fails, replace the main board.
Dec 05, 2009 | Sharp Televison & Video
Audio keeps switching from mono to stereo
on every channel ? then av board is failing
on a single channel then it is their signal not you set
Nov 24, 2009 | Sharp LC-32SB21U 32 in. LCD TV
My Sharp Flat Panel Television LC19SB25U has Picture but No Audio
Sharp has had a few problems with their audio boards, not finding any bulletins on this model, but a few complaining about low audio on amazon reviews section. If using an antenna you will experience some channels with low audio. If using cable you should get good sound on all channels..
the 9.1 and 9.2 are digital channels and sharp does display them for at least a few seconds when you switch to that channel. Check all your setting in the audio to Stereo never SAP. To options for you are get a cable box, first check in the back and see if there is another coax in, if there are two try both rescanning after connecting.
GD lk
Eric
Aug 16, 2009 | Sharp LC-19SB25U 19 in. LCD HDTV
Is it possible to replace a broken lcd screen on the Sharp LC-42D64U or is it just toast?
Sorry to say, it's pretty much toast. The screen is most of the cost of an LCD TV, so if it gets physically damaged you're better off replacing the set.
May 08, 2009 | Sharp LC-46D64U 46 in. LCD HDTV
TV INPUT ON BACK OF TV, GIVE AN ERROR
I recomend that before doing anything else, unplug your TV (from power) for at least 5 minutes and then plug it back in. See if this solves the problem.
Feb 24, 2009 | Sharp LC-42D64U 42 in. LCD HDTV
Sharp LC-42D64U 42 in. LCD HDTV Logo
241 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
