Question about Candy CDC266 Dryer
Cdc266 tumble dryer
Dryer is cold when drying clothes. the filter light keeps coming on but the filter is clean?
Hi you have to clean the inside of the machine I.E. remove the drum and on the back of the machine there are two heat sensors, the ceramic sensor is possibly faulty and needs replaceing
Posted on Sep 22, 2008
Dryer is taking a longer time than normal to dry unless we switch it to timer. Replace sensors?
  • Remove and clean the lint filter each time it is used. The filter can be washed with warm soapy water to remove fabric softener residue from the screen.
  • Check the household fuses and circuit breakers. Most household dryers use two fuses or circuit breakers. It is possible for only one of them to trip and the dryer still tumble, but not heat.
  • The washer controls may have been improperly set. If the clothes are wetter than normal, coming from the washer, this could be the difficulty. If the gentle speed is selected for a normal load the washer will not spin adequately. High speed or extended spin removes more water from clothing decreasing drying time
A lint filter that is full of lint will restrict airflow and lengthen dry times. To keep your dryer working correctly, clean out the lint folder after each and every use. Check the lint filter for any buildup of fabric softener that will restrict airflow and wash with soapy water to clean. If the filter is damaged then replace it.
Nov 09, 2017 | Dryers
Where is the filter on tumble dryer AWZ241
Hi Angie, The filter is at the back right in the middle, You pull the cover off and clean off the lint.........CHEERS..
Apr 27, 2016 | Electrolux IQ-Touch EIMED55IIW 27"...
What does it mean when the filter check comes on. The dryer works but doesn't dry well.
May have to remove cabinet and check inside appliance for a lint build up around blower etc. check ur venting out of appliance and into wall as well. lastly u may have a heating element going out,
Feb 13, 2015 | Samsung Dryers
I have a Candy Grand 8g vented tumble dryer. No matter which programme I put it on, it starts drying for a few seconds, then ALL the lights flash and it stops. I have cleaned the filter and do not know...
Its a wierd coincedence I have the exact same problem this morning,and my identical unit is 6 months old.Misery loves company,I will read the on line fault finder manual for this unit and hopefully find an answer
Regards Quiggers in Ireland
Nov 28, 2010 | Candy CDC266 Dryer
My dryer is not drying the clothes. It is a self venting dryer and I clean the filter everytime but the clothes are not drying. The filter light keeps flashing and I think the dryer is turning off.
check the out side vent and make sure that it is not blocked with lint also make sure that the ducting is not kinked or has to many curves in it that will hamper the effects of proper drying
Jun 09, 2010 | Dryers
Dryer is running longer than usual, it's tumbling,
no make listed here...I would pull the hose off the back of dryer and see if a lot of air is blowing out of vent. if not, heres your answer a clogged filter area ..if air blowing out leave vent hose off and dry clothes with vent off for one cycle. if clothes dry with vent hose have a venting issue and need your vent cleaned out...
May 15, 2010 | Dryers
I have the Candy C1C60, the "clean Filter light will not go off
I had the same problem, cleaned the whole machine until it was back to show room condition but the light was still on. Turns out my heater had packed in, bought a replacement and fitted it and it down the trick (no light and drying clothes)
Jan 03, 2010 | Candy CDC266 Dryer
Candy CDC266 Dryer Logo
388 people viewed this question
Top Candy Dryers Experts
Gerry Harvey
Gerry Harvey
Billy Detlefsen
Eddie Dalton
Eddie Dalton
Are you a Candy Dryer Expert? Answer questions, earn points and help others
