Question about Kitchen Appliances - Others
Water hardness I recently had to install a new electric hot water heater. There were no problems with the old heater other than a leak. Water hardness measurements indicate the hardness from the well is 40 grains of hardness. After the softner hardness measured 0 grains indicating soft water. Measurements of water from new water heater showed a hardness of 9 grains with some oder. Contacting the distributer and manufacturer about this problem proved fruitless. The only thing I can think of to cause this problem might be the anode in the heater. I am told the material is magnesium. Could another anode material cure this problem?
  • 25 Answers
Magnesium Anode rodes will make water smell like rotten eggs. If you can for your heater get a aluminum anode rode and replace the one you have.
Posted on Jan 19, 2009
Easy way to replace it
Replacing a water heater is no very difficult if you follow the steps.
1. If it is electric turn of the breaker and check to be sure it is the right breaker. If it is gas turn off the valve close to the water heater.
2. Turn off both the hot water and cold water valves
3. Drain all water out of the heater.
4. Disconnect the electric wiring if electric and if gas disconnect the gas line.
5. Disconnect both water lines which may have to be cut depending on how they are connected.
6. Now you can remove the water heater and discard.
7. Place new heater where old one was removed and reconnect both water lines and be sure you have a new pressure valve installed on the water heater.
8. At this point you can turn on water and check for leaks. you should also open a hot water faucet to purge the air out.
9. If no leaks go ahead and hook up the electric or gas lines and if gas is used turn it on and check for leaks using a leak detector or a spray bottle of soapy water and look for bubbles. If no leaks you can go ahead and light the heater according to its instructions.
10. If electric is used turn it on.
11. Take a long hot shower.
Feb 01, 2016 | Water Heaters
I have water in the junction box on top of my hot water heater and into the electrical conduit leading to the hot water heater.
I do not see your earlier post with photo.
The problem could be the conduit.....
-disconnect the conduit and wires from water heater
-run wire into a junction box set lower than top of water heater... -then run another #10 wire from the junction box up to water heater...
-So if water is coming from conduit, it will accumulate into junction box and not in the water heater wiring cavity.
Next thing....
... a water softener can cause rusted tank.
-Softened water adversely affects anode rod...
-causing anode rod to deplete faster...
-once anode rod is gone, then tank begins to rust.
-Here are details for checking anode rod each 2-3 years:
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/How-to-maintain-water-heater.html
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Gene
Water Heater Timers Save Money
Mar 05, 2015 | Rheem 82v52-2 Tall Electric Water Heater...
Water heater
Guessing that you have 240Volt residential non-simultaneous electric water heater? And that you have 30 amp breaker and 10 gauge wire. And that water heater is located within 100 feet of breaker box. And there are no leaks running hot water out of tank. And that you installed fully brand NEW elements of same wattage as old elements. And that fully brand new thermostats were installed, and wiring exactly duplicates wiring that was present before. And that factory-insulation was re-installed over elements and thermostats.
1) Guessing the 'hot water shut off' means the ECO red reset button located on upper thermostat keeps tripping and cutting off electric power to water heater?
http://waterheatertimer.org/images/WH-w-combined2-1000.jpg
http://waterheatertimer.org/How-to-test-water-heater-wires.html
2) If the ECO is tripping, then water is getting too hot, or there is shorted wire located near the upper thermostat, .
Typically replacing both thermostats and replacing elements will solve this problem .... assuming that new thermostats and elements are good, and wiring correct.
Double-Check your wiring on upper and lower thermostats.
Test wires for short.
Make sure factory-insulation is re-installed over thermostats so cool room temperature will not affect temperature reading.
Check that thermostats sit flat against steel tank.
Many short draws hot water can also cause stacking event that will trip circuit breaker.
3) Add comment and say what you find using checklist above.
Be careful to explain findings fully, using same words found on links above, so illuminated diagnosis can be made.
Dec 28, 2012 | Water Heaters
No hot water
test the thermostat and the heating elements --also there are resets that can pop push and make sure they have reset
May 17, 2017 | Water Heaters
It is leaking out of the top. not out of the hot or cold valves but out of a nut by the cold side.
Your tank is rusted out and needs to be replaced.
Link below is a troubleshoot for leaking water heater.
http://waterheatertimer.org/Leaking-water-heater.html
Protect yourself first:
If your tank is rusted, there is danger of rupture.
My friend welded his leaking tank, but he assumes the risk.
Ruptured tank can cause massive damage and water runs until it is shut off.
Hot water tank is under pressure because hot water expands and pushes against tank wall.
Turn off water to tank.
Turn off power supply:
Electric: turn off circuit breaker.
Gas: rotate knob to pilot so pilot stays lit but burner will not fire. To turn back on, rotate knob to ON.
Open hot side bathtub valve and relieve pressure on tank.
You can limp by with rusted tank by turning water heater on when hot water is needed.
Shower uses 5-9 gallons hot water
Bath uses 12-15 gallon hot water
Ordinary gas heater makes 41 gallons hot water per hour
Ordinary electric heater makes 20 gallons hot water per hour.
I buy water heaters at Lowes, Home Depot, Ace.
Look for scratch and dent models.
Buy drip pan for water heater.
Wrap electric heater totally with insulation except TP valve.
Buy new flexible connectors for water lines.
Offer 15% less than marked price on tank, because the store makes money on additional items.
> Most people can install their own electric heater since you just connect water pipes and electric wire, and it's done. Read link below since there are tips that help you buy and install electric.
> Generally people are nervous about installing gas water heater, so step-by-step instructions are shown on link below. Remember gas line is under less pressure than water line, so if you can install a water pipe, you can install gas line to water heater with crescent wrench, and soapy water to check for leaks.
How to install gas water heater:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on water heater, or any do-it-yourself project.
Jan 13, 2011 | Water Heaters
Rheem water heater model #82V661 serial # RH0106D11663 leaking water at lower panel. Water is coming from above wiring and control panel. Is this fixable or need to be replaced? Mfg date is 01/2006
You have 240volt electric water heater
Check both elements for leaking.
Check top of tank for leaking pipes.
If water heater is leaking from side of tank, then tank is rusted out and could rupture.
This tank must be replaced.
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html
My friend welded his tank to get more life out of tank, but he assumed the risk.
Hot water heaters are under pressure from heated water which expands.
If tank ruptures, water will flood out of tank and water will run until shut-off is turned OFF.
This causes major damage inside home.
Protect yourself first, and then let's talk more.
1) Turn off water at shut off located on cold water line above tank.
2) Turn off power to water heater:
Gas heater, rotate valve to 'pilot' so pilot is lit but burner does not turn ON.
Electric heater, turn off circuit breaker.
3) Open tub spout on hot side and let run a bit to relieve pressure.
4) Now your property is safe.
You can limp along with failed heater if leak is slow.
Turn heater ON when you need hot water.
Typical Gas heater makes 41 gallons hot water per hour.
Typical Electric heater makes 21 gallons hot water.
Shower uses 5-9 gallons hot water, bath uses 12-14 gallons hot water.
http://waterheatertimer.org/images/Water-heater-reference-guide-2.jpg
If you are going to install heater yourself:
Look at label on side of old tank to identify size and particulars.
I buy ordinary heaters from Lowes and Home Depot and always buy scratch-n-dent models when possible, because superficial damage to outer tank does not lower lifespan of heaters I have installed.
Buy same size heater if it worked fine before.
Buy new flexible water connectors.
Set water heater in drip pan.
Offer 10% less than price shown. Make them deal with you. Shop Ace hardware, Lowes, Home Depot. Kick the tires since you have a bit of time.
I know you have electric heater, but many folks read these answers, so I include info on gas too.
#1 rule) tankless heaters are a rich-man's toy, because tankless will never pay you back, and will become major money pit if you encounter 1 repair. Electric tankless heaters require larger electric service box. Gas tankless require larger gas line (larger gas line, more gas consumption, bigger bill unless you cut consumption)
2) How to install gas heater:
http://waterheatertimer.org/How-to-replace-gas-water-heater.html
3) How to install electric heater:
Read link above because many of same steps apply to electric.
The difference with electric, is turn off power, disconnect wires, and reconnect wires exactly like before. Set electric heater directly on insulated surface like dense blue styrafoam. Cut styrafoam in circle so it fits inside dip pan. Wrap entire electric heater with insulation blanket, except don't cover TP valve.
4) Connect bare copper jumper wire between hot and cold pipes to prevent stray current corrosion which will shorten life of tank. Make sure cold water line is grounded.
Also read:
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Add a comment for more free assistance.
For a price, fixya expert speaks to you via phone about any do-it-yourself problem.
Jan 07, 2011 | Rheem Water Heaters
We have a reliance 606 50 gallon electric water heater. recently we noticed it has an internal leak. I removed the top and removed some of the insulation. the pipe fittings are dry but when you put water...
I wrote a page on leaking water heaters.
With a checklist.
It sounds like you've done quite a bit already.
The element can leak around the gasket.
The TP valve can leak where it screws into side of tank.
Otherwise a leak on side of tank sounds like the tank is rusted through and needs to be replaced.
http://waterheatertimer.org/Water-heater-leaking.html
You should turn off electricity and water to the tank, and open tub valve on hot side to relieve pressure so the tank will not rupture.
Then you can limp along with a failed water heater by turning the water and electricity on only when hot water is needed.
This will buy you time until a new heater is installed.
A typical electric water heater produces 21 gallons of hot water per hour.
A shower uses 6-9 gallon of hot water, so heater only needs to be turned on 20-30 minutes for a shower, more if the incoming water is very cold.
To economize with your next heater, you might read the following two pages:
Nov 08, 2010 | RELIANCE ELECTRIC WATER HEATER
If my 50 gallon water heater is leaking can i replace it with a smaller water heater?
There should be no problem replacing a 50 gallon heater with a smaller size heater as long as the codes for your city/town allow it. You may also need to pull a permit for the installation, check with your municipality. Some codes state that a home with X square feet or whatever measurement they want to go by, will need at least a 50 gallon hot water heater. Obviously all installation instructions and codes apply to any new hot water heater installation.
Sep 10, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
My electric water heater is 4 years old. It has
Your expansion tank is probably bad, it devoloped a leak, and lost it's charge. The replacement of the tank should solve the problem. Hope this helps
Jan 14, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Kitchen Appliances - Others Logo
325 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
