Question about Mitsubishi VS-50111 50" Rear Projection Television
Picture flickers for 5-10 minutes then goes black
When I first turn on this exhibit in our museum the picture flickers and is jumpy. The problem gets worse, then the screen goes black in 5-10 minutes. The jumpiness is in narrow horizontal bands from top to bottom.
  • 813 Answers
Change the power capcitor its has been damged or bed if have no idea u have to go with a professnol repairer
Posted on Aug 07, 2008
    Genius:
  • 1,011 Answers
Dear Sir/madam,
1)Try Hard Reset. Unplug the power cord for a full 4 hours. Then power it up again.
2)Give some adjustment on the brightness to keep it away from the flicker threshold.
If it is not fixed it may be convergence problem. U can replace convergence IC's or replace the convergence board. And also i I suspect it to be the HV and HOT area, very common in these models. You will need a tv tech on this one.
Thanks
good luck
  • 594 Answers
In the back of the t.v. there is a mother board. on the mother board ( im not sure what it is called so i will describe it)
it looks like a black tune. it has a red wire comeing out of he top going to the front of the t.v. connecting to the picture tubes. now see what happens is that tube will heat up and sometimes loose connection. what i found to be helpful is to stick a peice of cardnpard under it so it gets a good connection again. but do becarful because it is high voltage....... so if you decide to try to work on the t.v. please unplug it first.
What is wrong with Sharp Aquos LC-40C32U Picture
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Search the site with the keyword "Line fault"
Jul 01, 2015 | Sharp Televison & Video
How to fix a Sharp Aquos LC-40C32U Picture
No picture on intermittent basis -
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 27, 2012 | Vizio GV47LF Television
SCREEN TURNS OFF AND GOES BLACK
The picture board on your monitor is faulty or bad, since it goes black after few minutes, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board or any service center because the fault is not something you can fix yourself. in order not to complicate issues.
Take care.
Apr 21, 2010 | HP w1907 LCD Monitor
When tv is turned on picture flickers really
When it goes black can you see a ghost image? It will be a normal tv picture but very faint black and white looking, you may have to get close and look at an angle to even see it. If so that means your backlight system is failing. If you don;t see an image then it is a problem with the power section of the board inside the tv.
Check if it is covered by warrenty and get a quote if it isn't. A 42 inch is new and big enough that it should still be worth repairing but it may cost you anywhere from $100 to $250 depending on the shop to fix.
Apr 12, 2010 | Vizio GV42L 42 in. LCD Television
47in Phillips-tv picture goes black still has
Could be the signal board has a bad cap, in this case it sounds like you are getting intermitten power to the inverters....when the tv goes down and of course you have audio....Shine a flashlight on to screen and see if you have a picture...look carefully. If this is the case..you have the above problem!
Nov 23, 2009 | Televison & Video
Samsung LCD TV, no picture only sound
is the picture clear when on? if yes, does the screen go black after a few seconds. if yes, sounds like you need a back light inverter!
Sep 13, 2008 | Westinghouse LTV-30W2 Television
Screen goes crazy after about 1 minute
try it on tuner mode to seperate the fault from video to rf input,if gone the video pc board is at fault.
Aug 11, 2008 | Samsung HLN467W 46" Rear Projection HDTV
Acer AL1716 monitor flickers
i Have the same problem, this screen is used on the spare computer we have in a loft conversion and the room does get rather cold, Warming the screen up with a fan heater for a couple of minutes gets rid of the problem. When the fault occurs the buttons on the front to adjust the picture quality don't work they just turn off the monitor.
Dec 08, 2007 | Acer AL1716 17" LCD Monitor
Mitsubishi VS-50111 50" Rear Projection Television Logo
90 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
