Question about Frigidaire ATF6000ES Front Load Washer
Door buzzing/not locking
My wahser quit in mid cycle -- the door started buzzing and even though it shows as door locked - it opens easily.
  • 725 Answers
Press cancel. (turns off washer)
press start/pause (wake up)
hold cancel and start/pause 10sec
last error code will come up.
E47 door lock error
check wires connections to the door lock..
replace door lock..
hope it helps
Posted on Aug 13, 2008
Eratic, sometimes door lock doesnt activate, when it does wahser starts but stop mid cycle and wont continue. Replaced door switch and pump
Repair needed on Maytag Neptune washer - Home Improvement ...
www.dslreports.com > ... > Home Improvement
DSLReports
Aug 5, 2007 - 19 posts - ‎8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
Maytag Washer Troubleshooting - YouTube
Dec 02, 2015 | Maytag Washing Machines
Agitator starts wont quit
see this causes and fix it. God bless you
Lid Switch Assembly If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
see the diagram
Sep 30, 2012 | Frigidaire Washing Machines
I have a hotpoint few12 washing machine and have just replaced the interlock door lock as door locked indicator kept flashing even though door was closed,sometimes happened mid cycle,and had to open...
hi
check the spring on the door handle/catch,the easiest way to check this if you close the door and it indicates that the door hasnt locked,push the inner part of the handle towards the machine,if it locks then the spring is worn.(this is more commen than the interlock).
Aug 03, 2009 | Washing Machines
Door locked with over full load, in mid-cycle
Take out the drain hose and syphon off the water into a bowl. When empty lock will open.
Mar 07, 2009 | Westinghouse Washing Machines
Tappan electric range door locked
Check the door lock switch/solenoids. You'll have to unplug the range/stove. Remove the solenoid and check to see if it has continuity or if the solenoids are stuck.
You also might have luck resetting the clean cycle. Even though the lock is engaged, try to open the oven door a little. Start the clean cycle, then cancel it.
Dec 13, 2007 | Kitchen Ranges
Front loading wash machine
It sound like door lock unit is broken or removed from the door. Good luck !
Jun 17, 2007 | Kenmore 44042 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
421 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
