Question about Fuji FinePix S5700 Digital Camera
Changing Shutter Speeds
The manual says to use the +/- button but there is not one on the S5700.
There is on the S5500.....
How do I change shutter speeds when in M (manual) mode?
  • valvestem May 11, 2010
    Sometimes the writers of the directions forget that we might not be as familiar with the camera as they are. Maybe the -/+ is the zoom lever for this adjustment, just a thought.
The +/- button is located on the bottom right corner on the back of the cam. If you do not find it on your cam, probably "you are not using a Genuine Fuji S5700".
Posted on Oct 16, 2008
Changing shutter speed
Like many point&shoot cameras the JZ300 doesn't give you direct control over the shutter speed; you're expected to just point and shoot.
You can indirectly affect the shutter speed by changing scene modes. For example the sports mode will try to use faster shutter speeds while the landscape mode will narrow the aperture for greater depth of field resulting in a slower shutter speed.
Mar 03, 2013 | FUJIFILM FinePix JZ300 Digital Camera
After using our e-520 for about a year we have a problem. After taking a photo. When looking though the view finder all is black, as is the screen when switching to the lcd. Is it possible the shutter is...
digital cameras do have a "shutter", kind of. IT is electronic, just powers on/of the sensor that captrures the image. Some digital cameras have regular swhutter also, that makes it possible to get real fast shutter speeds for flsh. Take off the lens and look inside, It is possible that the mirror is locked in the up position. Read your owners manual and see if there is a reset button for the camera. Remove the battery, tuen camera on/off switch 2-3 times,replace battery and look again. Try reset switch(if available). My Nikon has a mirror locxk up function available throough its menu. Read your owners manual and see if you have the same. If you can reead menu on LCD, and manual says you have mirror lockup, then try changing settings.
Oct 26, 2010 | Olympus E-520 Digital Camera
The shutter speeds on my Horizon Perfekt do not change when i adjust the dial.
The shutter speed is controlled by the width of the slit exposing the film. So, the lens will swing at the same speed when set at 1/500 or 1/60 (White setting), therefore it appears on the outside that the shutter speed has not changed. The swing has only 2 speeds, White fast, Yellow slow, selected by the switch on the left beside the rewind knob.
To confirm that the width of the slit is changing (actual shutter speed), open the back and fire the shutter on Yellow 2 (half second), you will see the slit is fully open as the lens swings. Next try Yellow 8, you will see the slit is less than half open, so it exposes the film for a shorter time by having a narrower slit , not faster swing.
This is the same principle in many cameras with curtain shutter.
I hope this answers your question.
Oct 13, 2010 | Horizon Perfekt Film Camera
How do I change the shutter speed on the Fuji S8000fd
Set the camera to Shutter Priority AE by turning the mode dial to S. Press the +/- button to open the setting screen, then press up/down to select the shutter speed.
You control the shutter speed the same way in Manual mode. You also select different shutter speed/aperture combinations the same way in Program mode.
You can indirectly control the shutter speed in Aperture Priority AE by changing the aperture and letting the camera set the appropriate shutter speed.
May 27, 2010 | Fuji FinePix S8000fd Digital Camera
How do you change the shutter speed on the finepix s5500?
That depends on the selected shooting mode.
In Program AE, press the exposure compensation button and then up/down on the 4-way button to change the shutter speed/aperture combination.
In Aperture Priority AE you can control the shutter speed indirectly. Press the exposure compensation button and then up/down on the 4-way button to change the aperture, and the camera will adjust the shutter speed to suit.
In Shutter Priority AE press the exposure compensation button and then up/down on the 4-way button to change the shutter speed. The camera will adjust the aperture to suit.
In Manual press the exposure compensation button and then up/down on the 4-way button to change the shutter speed. You'll have to press left/right on the 4-way button to select the appropriate aperture.
Mar 08, 2010 | Fuji FinePix S5500 Digital Camera
How do you change shutter speeds on the Samsung digimax S500? I need to know how to change the shutter speeds and how to use the manual option on the camera in order to perform motion blurs and such.
Select Manual mode by turning the mode dial to M. Press the +/- button, then up/down to change the aperture or right/left to change the shutter speed.
This is on page 14 of my copy of the manual.
Sep 25, 2009 | Samsung Digimax S500 Digital Camera
Shutter speed
When you set the camera to "Full Manual" mode, you should be able to dial in your shutter speeds, for most film cameras, including the N55 30 Seconds is the slowest shutter speed. If your camera features a "Bulb" mode, then the shutter stays open as long as you are holding down the shutter release button.
Apr 12, 2009 | Nikon N55 35mm SLR Camera
Changing shutter speed for 35mm Canon E0S Rebel camera
You should download a manual.
Specs say it is an autofocus and autoexposure camera with limited manual input required.
Sep 11, 2017 | Canon Photography
Shutter Speed
If your shutter speeds are off you can compensate by changing the film speed setting,
quicker ( than should be ) shutter speeds require you to set the film speed to slower ASA .. KC
Sep 01, 2008 | Canon EOS-AE-1 35mm SLR Camera
No picture taken when shutter release is pressed
if you see no reation of the pressing of the button i.e. no focusing, no error message nothing , then most probably a simplest problem , the shutter release button may not be working for few reasons : 1) defective switch. 2) defective flex cable. 3) camera exposed to some physical jerk or dropping resulting into disalingment between inner switch and the shutter release button.
Jul 09, 2006 | Fuji FinePix S5500 Digital Camera
Fuji FinePix S5700 Digital Camera Logo
118 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
