Question about Mitsubishi VS-45607 45" Rear Projection Television
RE: vs-45607 thank you very much for the information. Is there a manual or schematics that I can go by, it would be very helpful in assisting me in fixing the problem. It's been awhile since I have worked on a tv and I want to make sure I do it correctly. Thank You, chefkenny
  • 927 Answers
Good Day, chefkenny;
I don't think you will need the manual to perform this task. Like I stated the concern is on the signal board. Looking at the TV from the back the signal board will be on your left, the parts of concern will be on right side of "signal" PCB, toward the center of said board. You can see part location numbers easier from the bottom.
Good Luck, big IRISH.
Posted on Aug 08, 2008
DOES ANY BODY HAVE A SCHEMATIC FOR SPEED CONTROL BOARD OF GLTF2940EE0
Thank you for your post, Gamaliet Figueroa!
Based off the information you have provided you are searching for a schematic of your speed control board for your Frigidaire washer. I was unable to locate a wiring schematic but I was able to find additional manuals that could be of better assistance. I hope this information is helpful. -Matt
Frigidaire Manual Search Results
Nov 09, 2014 | Frigidaire Washing Machines
Picture is blurry like the tracking is off? what is the fix?
Your TV is out of focus. It is difficult to mention the whole procedure of fixing of blurred picture in VS-60707. It is a very long procedure & requires some instruments for adjustment. To make it easy for you please visit the following link & download 11 files. Although you see the download for VS-45607, the service manual is also for VS-60707. http://www.eserviceinfo.com/download.php?fileid=32177
First three files are archived in .rar format & rest are schematic diagrams in pdf formats. After extracting files from the first three files go to page no. 35 & adjust the focus accordingly
Aug 13, 2011 | Mitsubishi VS-60707 60" Rear Projection...
Is this Tv HD? Molel # VS-45607 Mitsubishi
I am sorry to say that your set is not compatable with HD.
Although you should still get a good picture.
I hope that this helps.
asnowman
Jul 22, 2010 | Mitsubishi VS-45607 45" Rear Projection...
NEED TO REPLACE BULBS IN mITSUBISHI VS 45607 cAN NOT FIND THEM
This doesent sound like a bulb problem to me at all! it sounds like a few capaciters need replaced! Look put the screwdriver down and call a pro because you could ruin the set trying to do a minor fix and causing a major problem!
Dec 11, 2008 | Mitsubishi VS-45607 45" Rear Projection...
I am trying to remove the screen on my Mitsubishi VS-4561 rear projection tv to clean it, how do I remove it? I know it slides up, anyone have a manual???
For my VS-45607 I had to first take off the speaker grill. Then there is a panel just below the screen that can be removed with screws; I removed this just for wire clearance. Then there are a few screws that are along the bottom of the screen that you take off and you should be able to slide the screen up and off. Good luck.
Dec 02, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Vs-45607
This the fix ya you are looking for;
CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
Aug 07, 2008 | Mitsubishi VS-45607 45" Rear Projection...
VS-45607
Good Day, rmorales;
Does the buttons on the front panel work properly? I would suspect a bad button assembly.
I hope this helped, good luck, big IRISH.
Jul 22, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi TV VS-45607
Good Day;
This model is known for the front control panel going bad. You could unplug it, control panel cable, from the front of TV, by removing the speaker grill, and just use the remote.
Jul 21, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-45607 Picture flickers and dims
It could be a bad solder connection that opens up as the set warms up. It could also be caused by a couple of bad capacitors, C2p05 (100uf/16v) Located By Ic2p01 and check C2c52 (10uf/50v) Located near Q2c51. A technican will be able to fix it for about what you paid for it I suppose.
Jan 24, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
55 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
