I have a nw MAT19W127 tv and cannot receive BBC!, BBC2 and BBC3 on the freeview service (BBC4 is OK) Message shown is "No Signal". I have tried reloading the channels but still nothing. Othe machines in my home are working OK.
    Genius:
  • 1,011 Answers
Dear,
in tv a device used called Hyperband, means
Hyperband
In the service channel network, the frequency used for distributing TV stations (300 - 470 MHz). It is the range of choice for digital transmissions according to DVB-C.
sometimes, it happens that the hyperband installed in tv doesnt catch/recieve the frequency of the channels. i think your case is like this..
you have to change it .. its not very costly..
there was a problem in my LG tv that i was not recieving the Discovery channel freq. then i had to replace this part. now i can see it..
regards,,
Posted on Aug 07, 2008
On my Techwood it as built in freeview but every other channel is right except bbc1 and bbc2 both channels say bbc wales,How do i get them back to bbc1 and bbc2 please PLEASE HELP.THANK YOU.
What you need to do is retune the TV, but when it is finished look at the regional settings. Or if the regional option is available before retuning, retune selecting your area so then you get normal BBC channels. It's likely that at the moment the channels for BBC are located at the very top end of the channel list say? - channel 800+.
You are clearly picking up signals from many transmitters. With regional settings you can change it to the area you live in.
But you will have to take into account how good your aerial is. Otherwise the signal quality will not be good on same transmitters. So the set may only suggest those with the best quality signals.
ITV stations might also change.
When done it will move the channels you mention to the top end of the guide, to 800+.
Note many HD channels have no regional options. For example here in Yorkshire we only get ITV Granada and not Yorkshire TV on the HD channel for ITV1. And BBC1HD does not show any programmes when local news comes on.
Jul 02, 2016 | Televison & Video
My humax won't;t record bbc channels. I have tried retuning the tv.
This could be too much signal thanks to the Freeview retunes going on. Your aerial is more sensitive at some frequencies, so there's more signal power higher up the frequency range. The signals for BBC and ITV are among the strongest ones broadcast. If they are now at a point on the aerial's range where they are too strong for the TV then the tuner will over-saturate. The result is the same as no signal.
Have a look online for a Variable Signal Attenuator. It's a device that can be added to a aerial signal cable just before it goes in to the tuner. The adjuster allows the signal level to be reduced. Watch the TV's signal quality and signal level displays if it has them. As signal level (power) reduces you'll actually see signal quality increase. If you go too far then quality will start to go down again. The optimum point is where quality is highest.
Oct 08, 2014 | Humax Televison & Video
Panasonic lcd tv model no. tx-26lmd70. since switchover day 6/4/11 i have not been able to receive bbc1, bbc2, bbc3 channels auto tuned 3 times a day to no avail. panasonic helpline is jammed with other...
This This is a difficult one . You may have to go online to get an Upgrade for the TV..You will need a flash drive and of course there must be a USB socket on your tv... Other than that im stumped. Sorry.
hope this helps
Apr 08, 2011 | Panasonic Televison & Video
Can't get BBC1 or2 since the switchover with Durabrand DPVR801
So you think I'm gonna answer my own question then tell you how I did it, so that you can then CHARGE someone else for MY answer?! I don't think so! An excellent 'service' you have here - I DON'T think.
Nov 11, 2009 | Televison & Video
Since retuning Novemder 2009 cannot receive BBC1, BBC2 or BBC3
sounds like power surge. try unplugging unit from wall. wait 2 minutes. this reset the microprocessor in the tv. plug back in and enjoy!
Nov 09, 2009 | Toshiba 50H81 50" Rear Projection...
After retune no bbc 1 2 bbc news channels tv with
Sounds like you haven't retuned the set correctly. Use the factory settings/ default setting if poss. Look out for too much signal if you are on a booster.
Nov 06, 2009 | Pace Televison & Video
Satellite works fine in the day but no signal in
I have run into this problem a couple of times, once a loose connection at the LNB, other times it has been due to moisture build up (dew) in the loose connections, check all connections from the LNB through the tuner, and any other devices involved (a line map maybe?) that will most likely resolve the problem.
Sep 15, 2009 | Televison & Video
No freeview bbc channels
just solved the problem
with the variable attenator fitted i did a rescan still didnt work
but when i did a rescan to the restore factory settings it now works
Nov 24, 2008 | Televison & Video
Goodmans GTV69RFDT Television had all freeview now only getting 3 channels
First ensure that the TV input is set on the Freeview channels, just in case.
Then check the antenna, when Freeview does not get all channels, it is always the aerial (antenna).
Many areas in UK have still poor reception. If you use an internal antenna, go to Argos or Currys and buy an amplified antenna for freeview, that will improve the signal.
Oct 15, 2008 | Goodmans W280NS Television
Televison & Video Logo
95 people viewed this question
Top Televison & Video Experts
Electro Med Services...
