Question about Hitachi 46UX24B/25K 46" Rear Projection Television
Hitachi voltage regulator
I read that my problem could be the voltage regulator but do not know how to locate it to replace it myself. My tv is an Hitachi 46ux24b/25k. Does anyone know how to replace this part? Thanks.
2 Suggested Answers
  • 280 Answers
SOURCE: Will not come on.
On the high voltage board the connections on the Horizontal output transistor are probably bad or other connections. I have had several of these and that is what I found..
Posted on Mar 27, 2009
TV cuts back off after I turn it on
It sounds that the start voltage to SMPS [Main power supply regulator board] has some problem. It should be checked. Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
Apr 18, 2014 | Panasonic VIERA Televison & Video
92 jeep wrangler map sensor,positioning sensor, all read maxium voltage I was sold an external voltage sensor but I cant find its location. not on firewall. how do I fix problem
A little more info would help. Throttle position sensor? How do you know they are reading max voltage? Are you trying to replace the voltage regulator?
Nov 01, 2013 | Jeep Cars & Trucks
My hitachi plasma 42 PD7800TA does not turn on ,not even the standby ,the fuse is fine ,dont know what else to do? thanks Tony.
Hello
The power regulator board in your Hitachi is not switching. It is an SMPS [Switched Mode Power Supply]. Normally for plasma TVs the power supply repair will be almost impossibele due to lack of component availability. If the fuse is OK, definitley the switching process has failed it it. There is an IC which oscillates at high frequency, whic its oscillation signals are given to MOSFET transistors to chop the incoming AC, converted DC voltage. These switched voltage is passed through SMPS transofrmers which it turn generates secondary voltages that goes to different circuit boards of your TV. The power board is the most important section in a Plasma TV. it must be perfect in every respect in terms of secondary voltages. If any one of this voltage goes over than specified, the main boar will get damaged. So it is adviced to replace it as card basis, rather than making "sugery" to it. The power supply board can be had from Authorised Hitachi Service centers. You just give the the exact model number of your Hitachi TV. They will give you the orginal power supply board. Never play experiments with Plasma TV. OK.
Jul 15, 2011 | Hitachi PlasmaSync CMP4202U 42 in. HDTV...
I have a 50 inch hitachi tv and its come on but its cuts off
on this tv u have bad could solder connection on the power supply board and also u need to replace the voltage regulator , average repair on this unit is about $200 , i would recomment to take to a repair shop because it require a lot of xperience to do this knine of repair
Aug 25, 2010 | Hitachi 50UX57B 50" Rear Projection...
Blank Screent with flashing pink bands
hitachi bs always have bad voltage regulator ic's like an STR6301,Need to replace
May 05, 2010 | Hitachi 51F500 51" Rear Projection...
Tv has a 3d look what can be done to fix it hitachi 43fwx20b
The convergence board is bad. Replace the STK voltage regulators and any associated discolored resistors.
Mar 13, 2010 | Hitachi 43FWX20B 43" Rear Projection...
Hitachi 65F598, Horizontal Distortion
You might can get you a schematic for the tv and troubleshoot it yourself, if you know how to use a multimeter. Check the voltages at the horizontal outputs,voltage regulator. I get mine at www.servicemanuals.net and they are the factory manuals at a low price, you download them to your computer
Feb 24, 2010 | Hitachi 65F59 65" HDTV
Green leds turn on momentarily when first plugged in then shutoff
ok , on hitachi pro tv is very common with bad power supply u may want to replace the voltage regulator which is next to the fuse u already replace , also loose connection on all the power supply seccion , also u may want to check the resistor close by the convergence ic 2.2 ohn if this are smoke replace stk392-110
May 07, 2009 | Hitachi 50SBX78B 50" Rear Projection...
Hitachi 50vs69a
have power supply normally the voltage regulator gose bad normally start str f668b
Apr 21, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
TV will not turn on
look for a blown fuse where the power comes in.
Nov 27, 2007 | Hitachi 53FDX20B 53" Rear Projection...
Televison & Video Logo
230 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
