Question about Singer CE-100 Futura Computerized Sewing Machine
THe needle hits the bobbin case. The timing seems to be out about 90 degrees to 9:00. Can you help? Thanks so much. Karen
  • flgramme Aug 14, 2008
    The bobbin no longer hits the bobbin case and sews a good seam in the sewing mode but in the embroidery mode it still makes a bobbin mess, which is what started the original problem. :>( Also I didn't find the manual for my machine at that link. Thanks
  • flgramme Aug 15, 2008
    How does one adjust the top thread tension? THe only dial with numbers seems to be the one that has E and S and some numbers. Can this be changed from the E when embroidering? Maybe I do need a manual or just learn that one only gets what one pays for. My friends have much more expensive machines. Thanks for your help. I will post ratings when all done cause I'm not sure if that ends my session or not. So much to learn. Thanks too for your patience. Karen
  • 3,037 Answers
Hi, your timing can be adjusted. Possibly a gear slipped inside.
One of the four diagrams on this link should help you readjust it.
http://www.sewusa.com/Sewing_Machine_Repair/Sewing%20Machine%20Hook%20Timing.htm
You can also get a manual from
http://www.singerco.com/support/parts_charts.html
let me know if you have further questions along the way
good luck
Posted on Aug 07, 2008
  • 1 more comment
  • Benjamin Patri
    Benjamin Patri Aug 07, 2008
  • Benjamin Patri
    Benjamin Patri Aug 14, 2008
    Can you tell if anything is broken (or bent) in the bobbin? Basically the tension is probably off and can only be adjusted by the top thread tension. Just not a good embroidery machine. If you still want a manual, let me know.
  • Benjamin Patri
    Benjamin Patri Aug 20, 2008
    I'm sorry, I've been terribly busy
    You know what, to make this easier, go to http://www.futura-support.com/futuraMach...
    to get the manual and if you have any immediate questions then call
    1-800-4-SINGER
    Monday through Friday, 8:00 a.m. to 4:00 p.m. C.T.
    and I am sure they would be glad to help you out on the phone while adjusting it which should make it a 100 times easier
SOURCE:
I broke a needle while sweng,now my needle hits my bobbin case on my 2030
it's very possible that when you broke the needle it caused the machine to go out of time & would have to be retimed at a sewing machine repair shop
Mar 12, 2012 | PfaFF Tiptronic 2030
Whenever I sew the top thread breaks. The machine seems to sew but then jams when I take the material off the top theard is all cut on the underside of the fabric and the bobbin thread is just there. ...
to see if a needle & thread are compatable, take a strand of the thread your going to use & the needle your going to sew with & put the thread thru the eye of the needle & hold it at a 90 degree angle & see if the needle goes down the thread easily
check the needle plate to see if there's any burrs or sharp edges & the bobbin case also
make sure the top thread does not come off the thread take up lever,cause that can make it jam also
it also possible that the machine could be out of time & would need to be serviced at a repair shop
Aug 12, 2011 | Singer 2932 Mechanical Sewing Machine
I have a Confidence 7470 purchased in May 2009. I was sewing tulle today and the thread kept snapping while sewing. I assumed it was catching in the tulle. The last time it snapped, the thread jammed in...
Sounds like your machine is off timing, When the machine is properly timed, you should see the hook passing behind the eye of the needle when the needle is on it's upward stroke. If this is not correct the machine will not pick up the bobbin thread. You may have to take it in for adjusting, unless your a bit machnical.
May 11, 2011 | SINGER 7470 Sewing Machine
Needle hits bobbin case
If the needle hits the bobbin case the are only 2 things that could be wrong. Lets hope its the easy one, there are more than one length of needles, if the needle is to long or it is not all the way up in the neelde bar, the needle will hit the inside of the bobbin case. Now if that is not the problem then the machine is out of time. ALWAYS check the easy stuff FIRST.
May 20, 2010 | Sewing Machines
Needle hits the white plastic where the bobbin case sits.
It may be as simple as you didnt get the needle pushed all the way up in the needle bar. Get new package of needles and try a new needle and make *sure* it goes up as far as you can push it. the reason I suggest a new pkg of needles is if one is bad in the pkg, they are probably all bad. If that doesnt fix it then the needle bar timing/height is off and need to be repaired/adjusted by a tech.
May 05, 2010 | Elna 7200 Computerized Sewing Machine
Needle hitting bobbin case model 750
This is a timing problem the hook timing needs adjustment, and possible the needle timing also
Oct 12, 2009 | Sewing Machines
Singer 301A stitch jam
your machine threads from right to left. the needle flat spot faces left. big loopy things means that the upper part of the machine is not threaded properly. as far as the needle hitting the bobbin case, it sounds as if someone removed the hook (part that holds the case) and put it back on 180 degrees off.
Jun 01, 2009 | Singer Quantum XL-1000 Computerized Sewing...
Needle hits the bobbin holder and doesn't grab the bobbin thread
Check you have the right size bobbin case the gap where the needle enters should be 13mm approx at the widest point. A lot of other pfaff bobbin cases seem to fit and can be easily be mistaken. I have two pfaffs and have accidentally mixed the cases and had a similar problem.
Mar 04, 2009 | PfaFF Creative 7570
Needle hits bobbin outer casing
Your hook/needle timing is off and it needs to be seen by a technician before you damage the hook. Some dealers can do a 24 hour repair for an additional charge.
sewman7
Jun 07, 2008 | PfaFF Creative 7570
Singer CE-100 Futura Computerized Sewing Machine Logo
79 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Kelley Buchanan
Kelley Buchanan
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
