Bios recovery Asus motherboard P4V8X_X
When I started my pc i got the message " bad bios checksum. starting bios recovery. as I no longer have my Asus P4V8X-X support cd. I went to the asus website and downloaded the latest bios for this board but when i put The disc into the pc i get the message reading file P4V8X-X.rom then P4V8X-X not found. what am i doing wrong
  • geoffmorgan4 Aug 07, 2008
    thanks i will try that now
  • 2,794 Answers
Did you run the utlity to put the firmware onto a floppy disc or cd so that it can boot up on the disc to install it?
The utility is available for download in the same section that you got the firmware update from.
Posted on Aug 07, 2008
  • 3,037 Answers
Go to this link, it tells you specifically what to do
http://www.fixya.com/support/p362915-asus_p4v8x_x_motherboard/manual-11149/page-39
Do exactly as it says and check twice. If it still fails to work, let me know.
good luck
    Master:
  • 397 Answers
You shouldn't need a BIOS update, just resetting the BIOS should sort it out.
If you still have the motherboard manual look uo how to reset the BIOS using the motherboard jumper, if not, remove the power cable from the back of your machine, remove the motherboard battery. Leave the battery out for approximately fifteen minutes.
Put the battery back in first then replace the power cable.
Reboot your machine, you might see the BIOS report a "Bad Check Sum error" don't worry it's just telling you that the time and date are wrong, boot up into Windows and reset your clock, this will reset the clock in the BIOS and everything should be OK.
  • 13,433 Answers
In the disk you burned, the bios can't read a zip file, the file needs to be extracted and as far as I remember you need to use a diskette instead of a cd. but I will look into it now.
  • 2 more comments
  • Ekse Aug 07, 2008
    Bios warning
    Please note, BIOS update is only recommended when experiencing technical difficulties with your system, And is not recommended to be performed regularly.
    Moreover, due to the nature of BIOS update, there is certain level of dangers involved. BIOS update must be performed with extreme caution . During BIOS update process, your system must be maintained without interference or power loss to prevent unexpected damage.
    In case of BIOS update failure, please follow instructions in your User's Manual for guidelines on BIOS recovery via CrashFree BIOS. In the event that BIOS recovery is not recoverable via CrashFree BIOS, please contact your place of purchase for further assistance on BIOS recovery.
    Source Asus
    You can get the bios from here
    http://support.asus.com/download/downloa...
    Get the 1008 version
    its under Bios and 3rd entry, all os version 1008
    File is in zip format, needs to be extracted.
    the rom file inside needs to be placed in a diskette.
  • Ekse Aug 07, 2008
    Diskette or if you can get the bios to read a cd then that is fine also.
  • Ekse Aug 07, 2008
    if the setup is looking for a file named as
    P4V8X-X.rom
    it may be required to rename the PV8XX08.rom to P4V8X-X.rom
    But im not perfectly sure what you are trying todo or why it is asking for it. il have to look into this more.
  • Ekse Aug 07, 2008
    As I suspected, BestDarnGood linked us the manual and the correct page about the problem. it confirms that the file has to be renamed and placed in a floppy.
    Thanks BDG
    http://www.fixya.com/support/p362915-asu...
2 Suggested Answers
Pyrhyc
  • 2028 Answers
SOURCE: when I started my pc
This sounds like a bad burn. try burning another copy of the download. If the download is in a zip file, make sure the files are unzipped before burning.
Posted on Aug 06, 2008
Asus p4v8x-x bad bios checksum checking for floopy floppy not found checking for cd-rom start reading P4V8X-X.ROM could not find P4V8X-X.ROM
Hi, you can download the bios file here:
http://support.asus.com/Download.aspx?SLanguage=en&m=P4V8X-X&p=1&s=15
Please select your windows version.
Select bios and click on global for download.
You have to unzip the file before you install it.
You might have to change the cmos battery out with
a new one:
ghost2233_59.jpg So the bios can remember its settings.
Thats why you get a bad bios checksum.
A reminder flashing the bios with a wrong one WILL destroy the mainboard.
Sep 12, 2011 | ASUS P4V8X-X Motherboard
Asus motherboard bios recovery
Ekse
Rank:guru_s.gif Guru
Rating: 85%, 1169 votes
Comment by Ekse, posted on Aug 07, 2008 Bios warning
Source Asus
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P4V8X-X
Comment by Ekse, posted on Aug 07, 2008 Diskette or if you can get the bios to read a cd then that is fine also. Comment by Ekse, posted on Aug 07, 2008 if the setup is looking for a file named as
P4V8X-X.rom
But im not perfectly sure what you are trying todo or why it is asking for it. il have to look into this more. Comment by Ekse, posted on Aug 07, 2008 As I suspected, BestDarnGood linked us the manual and the correct page about the problem. it confirms that the file has to be renamed and placed in a floppy.
Thanks BDG
Aug 07, 2008 | Computers & Internet
Asus p4v8x-x bad bios checksum checking for floopy floppy not found checking for cd-rom start reading P4V8X-X.ROM could not find P4V8X-X.ROM May i know what's wrong with it? i've rename the .rom file...
This problem could be caused by a near flat BIOS battery. Replace the BIOS battery and go into the BIOS configuration and set the Date and Time etc.
Apr 11, 2011 | ASUS P4V8X-X Motherboard
When I started my pc i got the message " bad bios checksum. starting bios recovery. as I no longer have my Asus P4V8X-X support cd. I went to the asus website and downloaded the latest bios for this...
Instead of updating your bios try removing the bios battery and then wait for about 5 mins then plug it back in to reset it. Most often that fixes the problem faster and easier.
Aug 06, 2008 | Computers & Internet
P4S800D.ROM not found
check the the bios battery, it should be 3volt not less,and press dell to in the bios page setup set and set everything you need to do.and don't forget to save it,. good luck
May 10, 2009 | ASUS P4S800D Motherboard
Asus k8v-vm mother board drivers
boot block compatible version ver 003
bad bios checksum, start recovery
is alone window seen in my computer
Dec 26, 2008 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
Bad BIOS checksum.... CMOS bad checksum errors
BOOT BLOCK COMPATIBLE VERSION VER .005
BAD BIOS CHECKSUM
CHECKING FOR CD ROM
READING FILE "P5SD2VM.ROM"
NO CD-ROM FOUND
CHECKING FOR FLOPPY DISK
NO FLOPPY DISK FOUND
Does someone already fix this problem??????
Nov 15, 2007 | ASUS M2N-MX Motherboard
Computers & Internet Logo
623 people viewed this question
David Payne
David Payne
